Oldskool 6,678 #126 Posted March 17, 2020 8 minutes ago, 953 nut said: Rear half of the Sub-frame for the GT-14 attaches to the rear axle and bolts to the frame near the center. The other half is attached to the frame at the front and attaches to the uprights making it a rigid unit. The whole idea is to transfer the stress and added weight to the wheels, not the frame of the tractor. Thanks for the pics. Which make/model FEL is that? Share this post Link to post Share on other sites
953 nut 67,435 #127 Posted March 17, 2020 17 minutes ago, Oldskool said: Which make/model FEL is that? It is a Johnson Workhorse which was mounted on the GT-14 when I bought it. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #128 Posted March 22, 2020 Going to try to get something done today. I think I will start with deck removal. Ive tried to find a pdf to tell me how. Could someone point me in the right direction? Not having much luck navigating with this new smarter than me phone lol. Share this post Link to post Share on other sites
ebinmaine 79,709 #129 Posted March 22, 2020 50 minutes ago, Oldskool said: smarter than me phone Took me a few (weeks/months/years) and still learning. Important to remember: Smartphone is NOT a PC and pages don't offer you the same information. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #130 Posted March 22, 2020 14 minutes ago, ebinmaine said: Important to remember: Smartphone is NOT a PC and pages don't offer you the same information. You can say that again. Share this post Link to post Share on other sites
ebinmaine 79,709 #131 Posted March 22, 2020 3 minutes ago, Oldskool said: You can say that again. Important to remember: Smartphone is NOT a PC and pages don't offer you the same information. 3 Share this post Link to post Share on other sites
pfrederi 20,870 #132 Posted March 22, 2020 1 minute ago, ebinmaine said: Important to remember: Smartphone is NOT a PC and pages don't offer you the same information. That is why I have a laptop sitting in my workshop. 3 Share this post Link to post Share on other sites
ebinmaine 79,709 #133 Posted March 22, 2020 Because of needing to be able to work from home, Trina had internet installed here at home after a 2 year hiatus.. It's nice to see the sites on the big screen again... 1 1 Share this post Link to post Share on other sites
Oldskool 6,678 #134 Posted March 22, 2020 So how does the deck come off this GT anyways? Share this post Link to post Share on other sites
Oldskool 6,678 #135 Posted March 22, 2020 Just now, ebinmaine said: Because of needing to be able to work from home, Trina had internet installed here at home after a 2 year hiatus.. It's nice to see the sites on the big screen again... My desktop had crapped out. So I picked up this cheap phone. Basically to keep up with forum activity and FB sell sites. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #136 Posted March 22, 2020 I think I have spent more time on line trying to figure out how the deck comes off than in the garage. I can only figure the deck has to be lowered to be able to remove the pin from the lift cylinder. Unfortunately it is in the up position. So I'm kind stuck. Any help would be MUCH appreciated Share this post Link to post Share on other sites
19richie66 17,930 #137 Posted March 22, 2020 (edited) Wish I could help but I don’t have one with a deck on it. Is there anyway you could have someone stand on the deck and push down on the valve lever? Not sure if that would do it. If not, crack a line going to the valve or cylinder till it lowers. Edited March 22, 2020 by 19richie66 2 Share this post Link to post Share on other sites
ebinmaine 79,709 #138 Posted March 22, 2020 @pfrederi @953 nut @19richie66 Who's got GT14 info... 1 Share this post Link to post Share on other sites
pfrederi 20,870 #139 Posted March 22, 2020 Deck Manual may help also can't you remove the hair pin at the bottom of the lift rod see picture 1 Share this post Link to post Share on other sites
Oldskool 6,678 #140 Posted March 22, 2020 Thanks @19richie66 and @ebinmaine. It's off. Not where I figure it should come off. I just unbolted at the closest points to the deck. It will do till info comes along 1 Share this post Link to post Share on other sites
Oldskool 6,678 #141 Posted March 22, 2020 Just now, pfrederi said: Deck Manual may help also can't you remove the hair pin at the bottom of the lift rod see picture I took that hair pin out and it didn't drop. I will check that file 1 Share this post Link to post Share on other sites
Oldskool 6,678 #142 Posted March 22, 2020 Ok that makes way more sense to me. Everything was stuck in place so wasn't sure what was supposed to move. Thanks again guys. Your the greatest Share this post Link to post Share on other sites
Oldskool 6,678 #143 Posted March 22, 2020 Some progress today. Deck is off. The shredded rear tires are off the rims. Tried testing the electric clutch. Provided I did it correctly it is nonfunctional. So until I have an engine or rear tires things will be at a snail's pace 4 Share this post Link to post Share on other sites
Oldskool 6,678 #144 Posted March 29, 2020 Found another little item today. What is this called? What ever it is it's on it's way to a new home. 2 Share this post Link to post Share on other sites
ebinmaine 79,709 #145 Posted March 29, 2020 Haven't the foggiest but it's cool 1 Share this post Link to post Share on other sites
Oldskool 6,678 #146 Posted March 29, 2020 It's made by David Bradley 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #147 Posted March 29, 2020 It's a cultivator. It does look like a David Bradley model. Randy 1 Share this post Link to post Share on other sites
Oldskool 6,678 #148 Posted March 29, 2020 1 minute ago, RandyLittrell said: It's a cultivator. It does look like a David Bradley model. Randy It has the DB metal tag on it 1 Share this post Link to post Share on other sites
Oldskool 6,678 #149 Posted May 2, 2020 Been pretty busy lately. Not so busy that I'm not looking for parts lol. So this is something I ran across a while back but may have finally secured the deal. 1 2 Share this post Link to post Share on other sites
ebinmaine 79,709 #150 Posted May 2, 2020 The man with the loader.... Super cooooool 1 Share this post Link to post Share on other sites
