SylvanLakeWH 31,919 #376 Posted December 28, 2023 1 hour ago, Pullstart said: not a pile of road signs holding it together. No offense @SylvanLakeWH Are you insinuating that road sign poles may or may not have been harmed in the creation of the WHrat WHrecker??? Er... uhm... well... 2 Share this post Link to post Share on other sites
8ntruck 9,140 #377 Posted December 29, 2023 On 12/27/2023 at 8:09 PM, 953 nut said: Presuming this build will be High Wide and Handsome so the tire won't be up inside the wheel well I would suggest a cut and paste job. Cut the body at the rear door opening and under the chrome strip, slide it back where it needs to go be, spot weld it in place and make a patch to cover the opening. It was easy to do on the computer, shouldn't take you very long once you finish up your other projectsd. @Pullstart potential project really intrigues me, so I have done some digging and thinking as to how I might construct the beast. The 4 door wheelbase is 122 inches. The 2001 2500HD wheelbase ranges from 133 inches to 166 inches. Kevin wants to put the axle on the centerline of the trunk for 5th wheel towing. I will assume that the donor chassis is 133". @953 nut how far did you move the rear axle when you doctored the pictures? If it was 10 inches, it looks like the hitch is going to be really close to the edge of the back window. Since the station wagon rear window is closer to vertical, a set of station wagon rear doors, bits of station wagon roof, rear window, and tailgate would make more room for the hitch. Another idle thought - would Chevy 4 door wagon roof and doors graft directly onto the Pontiac. They would bprobably be easier to source than Pontiac parts. This would make a great discussion and possible build thread of its own, rather than cluttering up this thread. 2 Share this post Link to post Share on other sites
953 nut 67,966 #378 Posted December 29, 2023 23 hours ago, Pullstart said: If it wasn’t mentioned, I really think having the axle in the centerline of the trunk will allow for a 5th wheel hitch. That wasn't mentioned but I was thinking it might happen. 1 Share this post Link to post Share on other sites
953 nut 67,966 #379 Posted December 29, 2023 8 hours ago, 8ntruck said: @953 nut how far did you move the rear axle when you doctored the pictures? If it was 10 inches, it looks like the hitch is going to be really close to the edge of the back window. No measurements were used, I just slid the wheel well opening back as far as I could without interfering with the bumper. With the larger tires not going up into the wheel well too far the centerline of the rear axle could go back a bit further without looking freakish, not that this won't look a bit abnormal anyway. 1 Share this post Link to post Share on other sites
PeacemakerJack 11,022 #380 Posted December 29, 2023 On 12/28/2023 at 2:11 AM, '67Craftsman's said: Thats a BEAUTIFUL color, I wish more cars came in it!! Do we know what its called? It remind me of Chrysler's FK5 deep burnt orange. (Not my car.) I wish I had had the opportunity to speak with the owner of that ‘66 GTO and get the information about the color—including the name. I would guess that it was something from the vast GM color palette 🤔 1 Share this post Link to post Share on other sites
8ntruck 9,140 #381 Posted December 29, 2023 4 hours ago, 953 nut said: No measurements were used, I just slid the wheel well opening back as far as I could without interfering with the bumper. With the larger tires not going up into the wheel well too far the centerline of the rear axle could go back a bit further without looking freakish, not that this won't look a bit abnormal anyway. Ah. You used the TLABR method - just like @Pullstart would do during a build..... 1 1 Share this post Link to post Share on other sites
Pullstart 70,955 #382 Posted December 29, 2023 5 hours ago, 8ntruck said: Ah. You used the TLABR method - just like @Pullstart would do during a build..... Huh? Share this post Link to post Share on other sites
8ntruck 9,140 #383 Posted December 30, 2023 1 hour ago, Pullstart said: Huh? TLABR - That Looks ABout Right 4 2 Share this post Link to post Share on other sites
Pullstart 70,955 #384 Posted yesterday at 07:42 PM This has sat long enough. 1984 S10 short bed, 305/700R4, stock bore, mild cam, the perfect stance. By 10 am this morning, I had dug into the barn far enough to air up the tires. By noon, Rylee and I had it pressure washed. By 2:45, well…. copy_4308E088-940F-4E64-A79E-0CD621CF6DCA.mov 1 3 Share this post Link to post Share on other sites
JCM 11,336 #385 Posted yesterday at 07:53 PM It's not everyday you get to see a smoke show on RS. 2 1 Share this post Link to post Share on other sites
ebinmaine 79,976 #386 Posted yesterday at 07:57 PM 14 minutes ago, Pullstart said: S10 You bring that to Maine. We'll babysit it for you. 1 Share this post Link to post Share on other sites
Pullstart 70,955 #387 Posted yesterday at 08:13 PM 19 minutes ago, JCM said: It's not everyday you get to see a smoke show on RS. You saw it first on the inter webs 1 1 Share this post Link to post Share on other sites
squonk 47,600 #388 Posted yesterday at 10:07 PM Had an 88 S-10 like this only dark blue. Bought it at the dealer I worked at when I got married. Picked it up after our honeymoon. 4.3 TBI with the 700R4 and 3:53 gears. Snapped your neck leaving the stop light. Towed our travel trailer to Pocono Raceway with the bed full of firewood. Got over 20MPG with the AC on! 5 2 Share this post Link to post Share on other sites
Pullstart 70,955 #389 Posted 23 hours ago 2 hours ago, squonk said: Got over 20MPG with the AC on! no ac on this truck, and I promise no 20 mpg, even with the 700r4 1 Share this post Link to post Share on other sites
Pullstart 70,955 #390 Posted 21 hours ago For those who can’t load videos off of RedSquare… 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 2,983 #391 Posted 19 hours ago (edited) Since we’re sharing muscle cars, here is My father’s 67 Mustang coupe It has a 68 302 with a 4 speed. It’s a transplanted 6 cylinder car that he and I and one of my three brothers helped him swap. It’s eventually going to be a clone of the Mustang he had in high school. he’s about 3/4 of the way now to that, but it still needs work. Edited 19 hours ago by MainelyWheelhorse 2 3 Share this post Link to post Share on other sites
ML3 2,447 #392 Posted 13 hours ago My 1st brand new vehicle was a 1991 S10 Tahoe. I was 18yrs old. Had 4.3 w/3:42 posi rear end. Did a few performance bolt ons to engine, headers, exhaust, shift kit, etc. It ran pretty good after that. Lowered trucks were the trend at that time. 3 1 1 Share this post Link to post Share on other sites
953 nut 67,966 #393 Posted 10 hours ago (edited) 12 hours ago, Pullstart said: no ac on this truck, and I promise no 20 mpg, even with the 700r4 probably twenty tires per gallon would be a closer call. Edited 10 hours ago by 953 nut 1 1 Share this post Link to post Share on other sites
Handy Don 17,119 #394 Posted 7 hours ago 13 hours ago, Pullstart said: For those who can’t load videos off of RedSquare… Man do you have courage burning rubber and trusting the long-sitting-and-in-unknown-condition front brakes while pointed into your garage! 1 1 Share this post Link to post Share on other sites
Pullstart 70,955 #395 Posted 4 hours ago 2 hours ago, Handy Don said: Man do you have courage burning rubber and trusting the long-sitting-and-in-unknown-condition front brakes while pointed into your garage! I shut it off, because the throttle was stuck and I was about to run into the door frame 🤠 1 2 Share this post Link to post Share on other sites
ebinmaine 79,976 #396 Posted 4 hours ago 2 minutes ago, Pullstart said: I shut it off, because the throttle was stuck and I was about to run into the door frame 🤠 ppffppffftttttt Whatever.... No sense of adventure. 2 Share this post Link to post Share on other sites
Pullstart 70,955 #397 Posted 3 hours ago I grabbed these 2017 Corvette Z06 wheels and tires for $250 today. $100 worth of spacers and they should fit the S10! 3 1 Share this post Link to post Share on other sites
953 nut 67,966 #398 Posted 1 hour ago 3 hours ago, Pullstart said: the throttle was stuck I used that line once, the judge wasn't amused at all. Guilty as charged. Share this post Link to post Share on other sites
