ebinmaine 79,127 #1 Posted August 18, 2019 I've messed around with carburetors big and small for maybe 25 or 30 years? This is definitely the one that is absolutely the worst condition I've ever seen. Several different types of corrosion and there is white and tan colored gel built up all inside of the fuel bowl area. Corrosion inside a couple of the galley holes blocked them so much I didn't even realize they were there. I took it all apart and carefully scraped it out and it is now soaking for a few days. One serious question though. The main jet is screwed into the bottom. That hole was literally filled with rust. I found that a little odd considering the carburetor is aluminum and the jet is likely brass? Maybe the bottom bolt holding the bowl on is steel and that's where the rust came from. That jet does NOT want to move. Is it super important that I take it out and clean in there or should I be able to just spray through or blow through with compressed air... 1 Share this post Link to post Share on other sites
pacer 3,180 #2 Posted August 18, 2019 YUCK!! Thats a nasty one. I've had a couple almost that bad and there was no way that jet was coming out. I'd think it'd be time to order up one of those $15 carbs off the bay. 1 Share this post Link to post Share on other sites
pfrederi 20,658 #3 Posted August 18, 2019 That is ugly. i would try cleaning you are very likely to damage the jet fighting with it. Be interesting to see if there are Chicom knockoffs carbs for the big iron K series Twins Share this post Link to post Share on other sites
ebinmaine 79,127 #4 Posted August 18, 2019 32 minutes ago, pacer said: YUCK!! Thats a nasty one. I've had a couple almost that bad and there was no way that jet was coming out. I'd think it'd be time to order up one of those $15 carbs off the bay. 11 minutes ago, pfrederi said: That is ugly. i would try cleaning you are very likely to damage the jet fighting with it. Be interesting to see if there are Chicom knockoffs carbs for the big iron K series Twins I haven't looked yet. I wasn't impressed with the one I got for the Cinnamon Horse. This carb throat is very large. I'll let it sit in the soup for a few days and see if it'll clean up. The needle itself was not too awful so hopefully the seat will be ok. Share this post Link to post Share on other sites
diesel cowboy 263 #5 Posted August 18, 2019 1 hour ago, ebinmaine said: That jet does NOT want to move. Is it super important that I take it out and clean in there or should I be able to just spray through or blow through with compressed air... Most of the time I can't get them out either. I usually spray carb. cleaner into it and blow it out with compressed air and most of the time have good luck doing that. As for a new carb. this place sells them: https://isavetractors.com/carburetor-for-kohler-k582-engine-4805306s/ It's a bit more expensive than $15 but I've put a few on different machines from him and haven't had any issues. Had to adjust the high speed needle on one a little bit but the rest of them went on haven't had to touch them since 1 Share this post Link to post Share on other sites
ebinmaine 79,127 #6 Posted August 18, 2019 @diesel cowboy Yeah I saw that listed in a quick search. I may very well go that route. I've not bought anything from Norman yet but I've spoken to him by phone or email a couple times. Great guy. Share this post Link to post Share on other sites
CountryRock 199 #7 Posted August 18, 2019 That is one nasty carb. 1 Share this post Link to post Share on other sites
WHNJ701 4,172 #8 Posted August 18, 2019 soak it in Berryman, it can be saved 1 Share this post Link to post Share on other sites
Lee1977 7,638 #9 Posted August 18, 2019 Guitar strings are great for cleaning those little holes in carburetors along with soaking in cleaner and blowing out with the air compressor.. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #10 Posted August 18, 2019 3 hours ago, ebinmaine said: @diesel cowboy Yeah I saw that listed in a quick search. I may very well go that route. I've not bought anything from Norman yet but I've spoken to him by phone or email a couple times. Great guy. Have you tried any of this chem dip! 1 Share this post Link to post Share on other sites
ebinmaine 79,127 #11 Posted August 18, 2019 2 hours ago, jabelman said: soak it in Berryman, it can be saved 29 minutes ago, Lee1977 said: Guitar strings are great for cleaning those little holes in carburetors along with soaking in cleaner and blowing out with the air compressor.. 4 minutes ago, The Tool Crib said: Have you tried any of this chem dip! Can't remember if it's berryman's as a brand but it's soaking in a gallon can of carb cleaner for the next few days at least. Share this post Link to post Share on other sites
oliver2-44 11,526 #12 Posted August 18, 2019 I use the small wires on a torch tip cleaner to run through all the holes. spray them out with carb cleaner, then gently run the wire through again, repeat. 4 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #13 Posted August 18, 2019 38 minutes ago, Lee1977 said: Guitar strings are great for cleaning those little holes in carburetors along with soaking in cleaner and blowing out with the air compressor.. That's another great idea lee. I have plenty of old guitar strings laying around. In fact my guitar needs new strings so I'll keep the old ones. 1 Share this post Link to post Share on other sites
JoeM 10,032 #14 Posted August 19, 2019 EB what's that off of? Looks like old Briggs ? Share this post Link to post Share on other sites
ebinmaine 79,127 #15 Posted August 19, 2019 13 minutes ago, OILUJ52 said: EB what's that off of? Looks like old Briggs ? Kohler twin K582 Share this post Link to post Share on other sites
JoeM 10,032 #16 Posted August 19, 2019 I know I have 17 up in the pile no 582 Share this post Link to post Share on other sites
Pullstart 70,103 #17 Posted August 19, 2019 (edited) I believe in you EB and BBT! Edited August 19, 2019 by pullstart Old dog... new tricks 1 1 Share this post Link to post Share on other sites
ebinmaine 79,127 #18 Posted August 19, 2019 6 hours ago, OILUJ52 said: I know I have 17 up in the pile no 582 I have another thread going about it. It was a hand built generator trailer. The engine was likely from a piece of construction equipment originally. Base paint is yellow with blue above that and a couple areas with army od green. I'm hoping to shoehorn it into an old horse. Share this post Link to post Share on other sites
ebinmaine 79,127 #19 Posted August 25, 2019 @jabelman @Lee1977 @The Tool CribCri And others... I'll post more pictures in a few minutes showing the carb itself. This is the cleaner that I use. I've had it for a couple years and I can't remember why I did not buy the Berryman's but I've been very very satisfied with this Gunk brand kit. 1 Share this post Link to post Share on other sites
richmondred01 2,372 #20 Posted August 25, 2019 Not to steal you thread but has anyone noticed that the gunk and Berryman chem dip been getting a blueish green slime on the bottom? Any thoughts? The alcohol in the gas? Share this post Link to post Share on other sites
ebinmaine 79,127 #21 Posted August 25, 2019 30 minutes ago, richmondred01 said: Not to steal you thread but has anyone noticed that the gunk and Berryman chem dip been getting a blueish green slime on the bottom? Any thoughts? The alcohol in the gas? never worry about stealing one of my threads. We are all here to share as much information as possible. The alcohol in the gas could be causing that, yes. I'm only guessing here but when we all see what we refer to as ethanol pearls in the bowl of a carburetor I don't see why that stuff would not accumulate into the bottom of the dip can. The other thing would be the dissolving of the corrosion of copper or brass parts. Note the pictures above ... there was already a fair pile of brown and white and tan slime or sludge inside this carburetor. Of course I did the best I could to wipe that stuff away manually but there's no way I got it all. Share this post Link to post Share on other sites
ebinmaine 79,127 #22 Posted August 25, 2019 Here's a couple pictures of the carburetor in its cleaned up state. I am extremely impressed with the way this thing came out. 2 days soaking. Removed all parts and gently brushed them by hand with a wire brush under lukewarm water. 4 more days soaking. Finished cleaning up with the wire brush and a little sandpaper where it was necessary. 2 Share this post Link to post Share on other sites
tunahead72 2,633 #23 Posted August 25, 2019 That's impressive Eric, it's hard to believe that's even the same carb! 1 Share this post Link to post Share on other sites
ebinmaine 79,127 #24 Posted August 25, 2019 2 minutes ago, tunahead72 said: That's impressive Eric, it's hard to believe that's even the same carb! Thanks! I'm installing it now so we will find out sometime today if it looks as good internally as it does externally. 1 Share this post Link to post Share on other sites
