ebinmaine 81,003 #1 Posted August 13, 2019 Trina has done a little soldering while making a couple of stained glass pieces in the distant past. I don't recall ever trying it before. We're going to learn how tonight while we are making a canoe dolly. I'll share some info on that Dolly later today. As usual, we've read some stuff and watched a few videos and it looks pretty easy. Any advice or teachings would be appreciated. 1 Share this post Link to post Share on other sites
stevasaurus 23,859 #2 Posted August 13, 2019 Eric, you are going to soldier a canoe dolly?? Are you using copper tubing?? I can see brazing, but unless you are going to put lights on the dolly...not sure where or what would be strong enough when soldiered. I've done tons of soldiering, but outside of some copper plumbing, most of mine would be closing up lead sleeves for phone company splices. 1 Share this post Link to post Share on other sites
ebinmaine 81,003 #3 Posted August 13, 2019 1 minute ago, stevasaurus said: Eric, you are going to soldier a canoe dolly?? Are you using copper tubing?? I can see brazing, but unless you are going to put lights on the dolly...not sure where or what would be strong enough when soldiered. I've done tons of soldiering, but outside of some copper plumbing, most of mine would be closing up lead sleeves for phone company splices. We're making one out of copper pipe. 3/4". Normally they're made from PVC or aluminum so copper should be plenty strong. We're using copper because that's what we have on hand... Especially after removing part of the heating system. We figured it would be a great way to learn a new skill as well. 1 Share this post Link to post Share on other sites
stevasaurus 23,859 #4 Posted August 13, 2019 AHH!! OK. Copper is too expensive to buy for that, but if you have it lying around...excellent. Clean all joints to be soldiered with wire mesh or sand paper...inside and out. Coat with flux, the cleaned areas. With a butane torch, heat the joint from the bottom...it does not take a lot of heat As the joint becomes hot, touch the soldier to the top of the joint. Remove heat, the soldier will flow all around and inside the cleaned areas. You can wipe with a damp cloth, before the joint cools, to get a nice looking joint. If you have a lot of that copper, that works great for the runners for building an ice fishing sled. Just sayin' 2 2 Share this post Link to post Share on other sites
ebinmaine 81,003 #5 Posted August 13, 2019 1 minute ago, stevasaurus said: have a lot of that copper yeah well we have enough that we are removing the entire hot water heating system so... We should have enough for a couple of arts and crafts projects. 1 2 Share this post Link to post Share on other sites
Lee1977 7,805 #6 Posted August 13, 2019 After cleaning the pipe and fittings and adding flux, 3/4" takes a lot of heat before the soldier is drawn in. A butain torch might not get it hot enough. I had to get my acetylene torch to get some 3/4" fittings soldiered when building my house. 1 Share this post Link to post Share on other sites
Pullstart 71,466 #7 Posted August 13, 2019 Map gas works too... but never heat the soldier, heat the copper and test swipe the soldier for melting point now and then. 4 1 Share this post Link to post Share on other sites
stevasaurus 23,859 #8 Posted August 13, 2019 Here are some ice fishing sled ideas. I saw a nice sled built out of conduit at a bait shop out side of Traverse City, Mich. Just some ideas here. Check this one out...I want to make this. 7 3 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #9 Posted August 13, 2019 47 minutes ago, stevasaurus said: AHH!! OK. Copper is too expensive to buy for that, but if you have it lying around...excellent. Clean all joints to be soldiered with wire mesh or sand paper...inside and out. Coat with flux, the cleaned areas. With a butane torch, heat the joint from the bottom...it does not take a lot of heat As the joint becomes hot, touch the soldier to the top of the joint. Remove heat, the soldier will flow all around and inside the cleaned areas. You can wipe with a damp cloth, before the joint cools, to get a nice looking joint. If you have a lot of that copper, that works great for the runners for building an ice fishing sled. Just sayin' Beautifly done steve! 1 Share this post Link to post Share on other sites
Ed Kennell 47,694 #10 Posted August 13, 2019 @stevasaurus has you covered Eric. When joining metal, tig, mig, flux core, stick wire, lead solder, silver solder, or brazing, cleanliness to the bare virgin metal is imperative. Be careful not to contaminate the clean surfaces with a dirty flame. The solder will go to the heat. Heat the fitting and draw the solder into the joint. 2 1 Share this post Link to post Share on other sites
ACman 7,749 #11 Posted August 13, 2019 (edited) .... clean clean clean . I preferred map gas myself and I always tried to heat the backside of fitting (where pipe goes into fitting) then moving to the front before adding the solder . The solder will follow the heat around and just for reference a 3/4” fitting should use about a 3/4” length of solder and a 1/2” fitting should take about a 1/2” length. Try not to over heat as the flux will burn turning black and making the solder not to take as good. Edited August 13, 2019 by ACman 2 1 Share this post Link to post Share on other sites
JoeM 10,317 #12 Posted August 13, 2019 Best part of this EB is the joints will not be inside of a wall of your house. Great bunch of tips.........go for it! 1 1 Share this post Link to post Share on other sites
wallfish 20,705 #13 Posted August 13, 2019 I see no one mentioned to clean the surfaces so be sure to clean the surfaces well. 6 Share this post Link to post Share on other sites
953 nut 69,933 #14 Posted August 13, 2019 7 hours ago, Lee1977 said: acetylene torch If you use an oxy/acetylene torch do not go to a neutral flame like you would use for brazing and gas welding, much too hot! A plumber's torch uses air and acetylene and is much cooler. 2 Share this post Link to post Share on other sites
ebinmaine 81,003 #15 Posted August 14, 2019 Great pile of excellent tips. Thanks guys!! I love this site ... Ask a question and within a few hours ya get a dozen people trying to help you out. AWESOME. 2 Share this post Link to post Share on other sites
wallfish 20,705 #16 Posted August 14, 2019 (edited) 18 hours ago, stevasaurus said: Check this one out...I want to make this. Personally I like the boat idea probably because it's a little crazy but that little driving sled is certainly cool too. Is the idea to use the ice auger engine to power yourself out there and then also use it again for the ice auger? Never mind, found this. https://www.outdoorhub.com/news/2015/01/08/ice-fisherman-develops-ice-auger-doubles-go-cart/ Edited August 14, 2019 by wallfish 1 Share this post Link to post Share on other sites
Lee1977 7,805 #17 Posted August 14, 2019 (edited) 2 hours ago, wallfish said: Personally I like the boat idea probably because it's a little crazy but that little driving sled is certainly cool too. Is the idea to use the ice auger engine to power yourself out there and then also use it again for the ice auger? Never mind, found this. https://www.outdoorhub.com/news/2015/01/08/ice-fisherman-develops-ice-auger-doubles-go-cart/ Pick up a vertical shaft Wheel Horse and adapt it for an ice-auger engine. And go in style. Edited August 14, 2019 by Lee1977 1 Share this post Link to post Share on other sites
JCM 11,419 #18 Posted August 17, 2019 Eric, If you need some help learning to solder Sept 7 would be a good time to let you practice while you and Trina are here. I will help the both of you become Pro's in no time and have plenty of scrap copper with new copper fittings that I will donate to the cause. Looking forward to the M & G and some teaching you both the correct way IMO to be the one of the best soft solderer in Hiram! Have a great weekend to the both of you. 1 2 Share this post Link to post Share on other sites
ebinmaine 81,003 #19 Posted August 17, 2019 @JCM You're a gentleman and a scholar. Thank you! 1 Share this post Link to post Share on other sites
