AHS 1,524 #1 Posted August 9, 2019 The photos of of my 70 or 71 Raider 12. It seems like the wire come out of the front of the engine. The rectifier wires come out of the other side of the engine. What wire is it? Where does it go to? 👍 Share this post Link to post Share on other sites
ebinmaine 71,899 #2 Posted August 9, 2019 I don't know what that is but I'm going to follow along because I'm curious as well. Just as a point of info, you're missing a spacer under the pivot bar that goes to your throttle cable. That's why it appears to be bent and scratching the engine cover at the top. 2 Share this post Link to post Share on other sites
AHS 1,524 #3 Posted August 9, 2019 47 minutes ago, ebinmaine said: I don't know what that is but I'm going to follow along because I'm curious as well. Just as a point of info, you're missing a spacer under the pivot bar that goes to your throttle cable. That's why it appears to be bent and scratching the engine cover at the top. A spacer in behind it? It looks bent! 1 Share this post Link to post Share on other sites
ebinmaine 71,899 #4 Posted August 9, 2019 40 minutes ago, AHS said: A spacer in behind it? It looks bent! Yep it is. I can get a pic tomorrow or you can hunt around for one here. There's a spacer maybe 3/8" thick that's missing. 1 Share this post Link to post Share on other sites
AHS 1,524 #5 Posted August 9, 2019 1 hour ago, ebinmaine said: Yep it is. I can get a pic tomorrow or you can hunt around for one here. There's a spacer maybe 3/8" thick that's missing. Yup, there is one on my 73 wheel horse “ mowing tractor!”, it’s a little dark and blown up! But that’s the spacer! It’s always nice to have a tractor to refer to!👍😄 2 Share this post Link to post Share on other sites
AHS 1,524 #6 Posted August 9, 2019 Ok, now what’s it for? What does it go to? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #7 Posted August 9, 2019 That spacer has a step in the OD. The flat piece is free to pivot when the mounting bolt is tight. Is the loose wire the one that went to the breakerless ignition coil? Garry 1 Share this post Link to post Share on other sites
AHS 1,524 #8 Posted August 9, 2019 4 minutes ago, gwest_ca said: That spacer has a step in the OD. The flat piece is free to pivot when the mounting bolt is tight. Is the loose wire the one that went to the breakerless ignition coil? Garry Ok, the points and the condenser go to neg. and the ignition goes to pos. ? What does it go to? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #9 Posted August 9, 2019 1970 Raider 12 model 1-6251 - Uses Kohler K301S-47371c with breakerless magneto ignition Sounds like you no longer have the breakerless ignition or the engine has been replaced. If you have points and condenser and an external coil you now have battery ignition. Tuck the spare wire out of the way and forget about it. Is is not uncommon to add points condenser and external coil when the very expensive breakerless ignition system fails. Garry 2 Share this post Link to post Share on other sites
AHS 1,524 #10 Posted August 10, 2019 28 minutes ago, gwest_ca said: 1970 Raider 12 model 1-6251 - Uses Kohler K301S-47371c with breakerless magneto ignition Sounds like you no longer have the breakerless ignition or the engine has been replaced. If you have points and condenser and an external coil you now have battery ignition. Tuck the spare wire out of the way and forget about it. Is is not uncommon to add points condenser and external coil when the very expensive breakerless ignition system fails. Garry Ok! Is that common a on a 1970, ( not that long ago, right?!) I have a ‘70 and a ‘73 14hp, which is running, and it does not have that wire. Share this post Link to post Share on other sites
Wildhorse 303 #11 Posted August 10, 2019 That wire is from the trigger on breakerless ignition. One wire comes off stator and goes to trigger and then one from trigger to breakerless coil. It was common for those motors and some blocks were pre drilled and tapped for points conversion. A small plug was placed in points plunger hole and screw holes were tapped and ready for points and cover screws. An updated steel points plunger rod was also introduced in the 80's to replace the aluminum ones for longevity purposes. 1 Share this post Link to post Share on other sites
Wildhorse 303 #12 Posted August 10, 2019 You should have two wires coming out of the other side that come from stator and go to AC terminals on rectifier. You have a points cover and appears to be wire coming from points so I'm assuming it is in fact a battery ignition now. Share this post Link to post Share on other sites
AHS 1,524 #13 Posted August 10, 2019 51 minutes ago, Wildhorse said: You should have two wires coming out of the other side that come from stator and go to AC terminals on rectifier. You have a points cover and appears to be wire coming from points so I'm assuming it is in fact a battery ignition now. Yup, exactly . Share this post Link to post Share on other sites
AHS 1,524 #14 Posted August 10, 2019 1 hour ago, Wildhorse said: That wire is from the trigger on breakerless ignition. One wire comes off stator and goes to trigger and then one from trigger to breakerless coil. It was common for those motors and some blocks were pre drilled and tapped for points conversion. A small plug was placed in points plunger hole and screw holes were tapped and ready for points and cover screws. An updated steel points plunger rod was also introduced in the 80's to replace the aluminum ones for longevity purposes. Ok! It doesn’t look like this tractor has been used much... before the attach o matic... the Raider 12 has the mower deck (36” RD) in beautiful shape. And it has the updated points/ coil, which could have been done in the early 90’s?? Share this post Link to post Share on other sites
Wildhorse 303 #15 Posted August 10, 2019 The points conversion could have been done at any time not 90's specific. The Raider and other 12hp models of that era also had side discharge decks. They had a side mounted mule drive setup. Your also missing the choke cable bracket that mounts just above pivoting throttle cable bracket that your missing spacer for. You're also missing bracket for throttle cable on valve cover unless I'm just not seeing it in pic. Decks mount just like attach o matic, only difference is mule drive. The Raider 12 will easily handle a 42" side discharge deck. Share this post Link to post Share on other sites
AHS 1,524 #16 Posted August 10, 2019 13 hours ago, Wildhorse said: The points conversion could have been done at any time not 90's specific. The Raider and other 12hp models of that era also had side discharge decks. They had a side mounted mule drive setup. Your also missing the choke cable bracket that mounts just above pivoting throttle cable bracket that your missing spacer for. You're also missing bracket for throttle cable on valve cover unless I'm just not seeing it in pic. Decks mount just like attach o matic, only difference is mule drive. The Raider 12 will easily handle a 42" side discharge deck. Ok! The tractor is on a long rebuild...I have all the pieces.. somewhere! Share this post Link to post Share on other sites
AHS 1,524 #17 Posted August 10, 2019 Ok, so I robbed the coil of the Raider 12, and would like to replace it with something new. It has points. Shouldn’t it be the same as all the other kohler k series? I took the tractor info in to the dealer, and they said it was too old! I’m just looking for a part number. Thanks. Share this post Link to post Share on other sites
ebinmaine 71,899 #18 Posted August 10, 2019 Your local auto parts store might have a usable coil. Perhaps @953 nut @squonk @pfrederi could help with a number? Share this post Link to post Share on other sites
pfrederi 18,566 #19 Posted August 10, 2019 Any 12 volt internally resisted coil would work Cheap on bay 1 Share this post Link to post Share on other sites
953 nut 59,306 #20 Posted August 10, 2019 VW used a 12 volt internally resisted coil. Share this post Link to post Share on other sites
AHS 1,524 #21 Posted August 10, 2019 16 hours ago, Wildhorse said: ok Share this post Link to post Share on other sites
squonk 43,427 #22 Posted August 10, 2019 Napa IC64SB Share this post Link to post Share on other sites
AHS 1,524 #23 Posted August 10, 2019 Ok, I bought coil off a 312 (off eBay). And, I was to think, a 312 doesn’t have points, and mine does... does that matter? Share this post Link to post Share on other sites
953 nut 59,306 #24 Posted August 10, 2019 (edited) If it looks like this you will be fine. If it looks like this, not so fine. Edited August 10, 2019 by 953 nut Share this post Link to post Share on other sites
AHS 1,524 #25 Posted August 10, 2019 27 minutes ago, 953 nut said: If it looks like this you will be fine. If it looks like this, not so fine. Ok!it looks like the top one! I’m good!👍 1 Share this post Link to post Share on other sites
