stevasaurus 23,859 #176 Posted April 29, 2019 Would the bits for it be for wire rounding? BTW Cas....love those devises for carrying those 5 gallon carboys. or should I Share this post Link to post Share on other sites
formariz 12,381 #177 Posted April 29, 2019 54 minutes ago, stevasaurus said: Would the bits for it be for wire rounding? BTW Cas....love those devises for carrying those 5 gallon carboys. or should I No. Think function for both uses. Caboys are not easy to carry when they are full. Makes it real easy. Share this post Link to post Share on other sites
stevasaurus 23,859 #178 Posted April 29, 2019 Cas, it is a rain day here. I've been searching all afternoon and come up blank...kind of...I know I could use this for not what it was intended for. You are correct, you either know what this is used for or you don't. I do not know. I did find a lot of pin vises that were knurled or machined like your example...makes me think it is from the same company. Just no cigar. Share this post Link to post Share on other sites
formariz 12,381 #179 Posted April 29, 2019 It is from a pocket watch. These things were many times made out of gold. 1 Share this post Link to post Share on other sites
posifour11 723 #180 Posted April 30, 2019 On 4/27/2019 at 7:37 PM, 953 nut said: Looks like a valve gag for preventing a steam safety valve from lifting during testing. Blank firing adapter for an M249 or 240B? Share this post Link to post Share on other sites
LengerichKA88 1,885 #181 Posted April 30, 2019 25 minutes ago, posifour11 said: Blank firing adapter for an M249 or 240B? For the M16, M4, and their variants. Share this post Link to post Share on other sites
formariz 12,381 #182 Posted April 30, 2019 You guys are giving up? It is for a pockets watch and...... What does a watch need to work? 1 Share this post Link to post Share on other sites
posifour11 723 #183 Posted April 30, 2019 1 hour ago, LengerichKA88 said: For the M16, M4, and their variants. A round one? Ok. Share this post Link to post Share on other sites
ebinmaine 81,001 #184 Posted April 30, 2019 8 minutes ago, formariz said: You guys are giving up? It is for a pockets watch and...... What does a watch need to work? Springs... 1 Share this post Link to post Share on other sites
Mows4three 833 #185 Posted May 1, 2019 Got it. I'll bet this is for pressing the hands onto the center spindle thingy of a watch..... Am I close? Dave Share this post Link to post Share on other sites
formariz 12,381 #186 Posted May 1, 2019 Not yet. Think of the two functions. Watch needs what to work? Also how was a pocket watch used? Share this post Link to post Share on other sites
Pullstart 71,456 #187 Posted May 1, 2019 It’s for pulling the winding button and then winding. That’s my final answer! Unless I’m wrong! Share this post Link to post Share on other sites
Stormin 9,988 #188 Posted May 1, 2019 Does it attach to the watch fob chain at one end and goes through a button hole? Are the jaws for gripping when replacing drive wheels? Share this post Link to post Share on other sites
formariz 12,381 #189 Posted May 1, 2019 4 hours ago, pullstart said: It’s for pulling the winding button and then winding. That’s my final answer! Unless I’m wrong! You are sooooooo close . 2 minutes ago, Stormin said: Does it attach to the watch fob chain at one end and goes through a button hole? Are the jaws for gripping when replacing drive wheels? Bingo on the second function. It was also decorative and functional in attaching to a garment. Not the correct answer on jaws which are the most important function. Share this post Link to post Share on other sites
LengerichKA88 1,885 #190 Posted May 1, 2019 34 minutes ago, formariz said: You are sooooooo close . Bingo on the second function. It was also decorative and functional in attaching to a garment. Not the correct answer on jaws which are the most important function. It’s a watch key, the loop is for holding the chains, the jaws are for winding and setting the watch to the proper time. That was my train of thought when I mentioned tension. I guess I should’ve been more specific, but vagueness can reveal a lot 🤷🏻♂️😂 Share this post Link to post Share on other sites
formariz 12,381 #191 Posted May 1, 2019 12 minutes ago, LengerichKA88 said: It’s a watch key, the loop is for holding the chains, the jaws are for winding and setting the watch to the proper time. Correct. It is a pocket watch T Bar Key. Earlier watches used a key rather than a knob to wind mechanism. Key could also be used to adjust hands to correct time. In addition to that it was attached to chain allowing it to be fasted to garment . Very convenient. @LengerichKA88 and @Stormin share the prize. And that is the next Whatizits. 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,691 #192 Posted May 3, 2019 I'm back......and waiting for the next one. @Stormin and @LengerichKA88 1 Share this post Link to post Share on other sites
formariz 12,381 #193 Posted May 3, 2019 1 hour ago, Ed Kennell said: I'm back......and waiting for the next one. @Stormin and @LengerichKA88 Welcome back. Its just not the same without you. What did you catch? 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #194 Posted May 3, 2019 (edited) This one might be a little easier, but we shall see. This tool serves two purposes, let’s see if one person can figure out both. Edited May 3, 2019 by LengerichKA88 Share this post Link to post Share on other sites
ebinmaine 81,001 #195 Posted May 3, 2019 I've got that one. But I'm going to let others go for it. Maybe somebody can break in and cut to the chase.. 1 2 Share this post Link to post Share on other sites
Sarge 3,473 #196 Posted May 3, 2019 Emergency escape tool - the cutter is for cutting a jammed seat belt, and the pointed end is for breaking automotive type glass. Most of those tools don't have the weight to break the glass, just fyi. Sarge 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,691 #197 Posted May 3, 2019 23 minutes ago, formariz said: Welcome back. Its just not the same without you. What did you catch? Thanks, I caught up on some memories with 10 good friends. A very large gobbler did put on a show of strutting and answering my calls for 1 hour and 50 minutes. I was enjoying the show so much, I forgot I was there to bring home the turkey. He eventual got tired of the game and walked away. 1 2 Share this post Link to post Share on other sites
Ed Kennell 47,691 #198 Posted May 3, 2019 Looks like @Sarge is up to post the next one. Share this post Link to post Share on other sites
Sarge 3,473 #199 Posted May 3, 2019 I was going to chime in on the rifle accessory - but figured that one wasn't fair, lol. I'll have to think about it and do some digging later on today. Most likely an old tool, hmmm.... Sarge 2 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #200 Posted May 3, 2019 12 minutes ago, Sarge said: I was going to chime in on the rifle accessory - but figured that one wasn't fair, lol. I'll have to think about it and do some digging later on today. Most likely an old tool, hmmm.... Sarge Issued gear is the only advantage I have on most of you guys 😂 The one we were issued looked more like a 1911 Bushing wrench in shape and size. I did get it to break glass, but not until the 3rd or 4th strike. This one seems to be a better design, allowing for better grip and leverage. Still probably too light as you mentioned though. 2 Share this post Link to post Share on other sites
