formariz 12,381 #501 Posted May 14, 2019 2 minutes ago, Ed Kennell said: Thanks, I guess I was expecting this to do more than support a lock core. I am sure Dave will chime in with more, but from what I understand it is easier to pick a lock while holding it in your hand than in actuality installed on a door. This duplicates the actual lock in a door. 2 1 Share this post Link to post Share on other sites
formariz 12,381 #502 Posted May 14, 2019 15 minutes ago, Ed Kennell said: Chemist mixing pot? No, its just a simple container. Think of its age. This is only one, but it had many friends working along with it. 1 Share this post Link to post Share on other sites
Stormin 9,988 #503 Posted May 14, 2019 Neolithic water container? 1 Share this post Link to post Share on other sites
Pullstart 71,145 #504 Posted May 14, 2019 Looks like a pre-glass insulator for power lines to me. But I’m not much of a thinker like some of these chaps! 2 Share this post Link to post Share on other sites
Ed Kennell 47,097 #505 Posted May 14, 2019 Can you give us the size? Is it a container for a liquid? Is the bottom half solid? Share this post Link to post Share on other sites
LengerichKA88 1,885 #506 Posted May 14, 2019 Older than the US..., is it from this continent originally or was it brought over from somewhere? 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #507 Posted May 14, 2019 (edited) Is it a Dolia, for fermenting? Not the right size for a Dolia, but it matched the description I read. Still think it’s for fermenting possibly. Edited May 14, 2019 by LengerichKA88 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #508 Posted May 14, 2019 Was it, along with identical ones, attached to a water wheel for collection/power? 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #509 Posted May 14, 2019 Could we get a shot of it from the mouth down? Share this post Link to post Share on other sites
formariz 12,381 #510 Posted May 14, 2019 We are almost there, some specifics please. Operation description and name would be nice.Not from this continent. Remember it is basically the original method..Will be back in about an hour 1 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #511 Posted May 14, 2019 Is the hole in the bottom intentional? which is closer, fermenting or the water wheel? That’s two opposite directions lol 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #512 Posted May 14, 2019 Make cheese in it? Randy Share this post Link to post Share on other sites
formariz 12,381 #513 Posted May 14, 2019 Hole is intentional that should solidify answer. 1 Share this post Link to post Share on other sites
Mows4three 833 #514 Posted May 14, 2019 Two guesses: Water filtering device? Chocolate pot? 1 Share this post Link to post Share on other sites
Mows4three 833 #515 Posted May 14, 2019 Ok. One more WILD guess.... Is it a really large bowl bowl for a Hooka (sp?). Dave 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #516 Posted May 14, 2019 1 minute ago, Mows4three said: Ok. One more WILD guess.... Is it a really large bowl bowl for a Hooka (sp?). Dave If that’s the kinda bowl you use for Hooka, let me know next time you’re firing it up! 😂😂 1 2 Share this post Link to post Share on other sites
formariz 12,381 #517 Posted May 14, 2019 You just about had it before but you have to be sure. Same culture that invented the Hooka invented this. 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #518 Posted May 14, 2019 It works on conjunction with others to cool an area. They’re stacked and water is introduced which trickles through, cooling the clay and natural air flow helps produce cool air in the direction it is pointed. 1 Share this post Link to post Share on other sites
Ed Kennell 47,097 #520 Posted May 14, 2019 (edited) Water clock or water mill Edited May 14, 2019 by Ed Kennell Share this post Link to post Share on other sites
Stormin 9,988 #521 Posted May 14, 2019 Is it off some kind of air conditioning device? Roman maybe? 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #522 Posted May 14, 2019 (edited) 4 minutes ago, Stormin said: Is it off some kind of air conditioning device? Roman maybe? That’s what I’m thinking, it’s one of many like in the picture I posted. He said it was the same culture as the H-o-o-k-a-h, which would be the region that is now Pakistan and India, as soon as that light bulb clicked I remembered that^ but I can’t for the life of me find it’s actual name. Some company made one a few years back and all the articles hail then as the “inventors” 🙄. I am 99% certain that we’re right lol Edited May 14, 2019 by LengerichKA88 ****** is a curse word 😂 1 Share this post Link to post Share on other sites
Stormin 9,988 #523 Posted May 14, 2019 If not Roman, Middle East maybe. Iran formally know as Persia. 1 Share this post Link to post Share on other sites
formariz 12,381 #524 Posted May 14, 2019 First let me correct myself for the Hooka is not from the same culture although widely used by it. @LengerichKA88 you pretty much had it.about had it a couple of posts before but I wanted you to be sure. Ed @Ed Kennell also pretty much nailed it. So a little history now. The Iberian Peninsula where I am from was inhabited earlier by the Romans towards the North and later by the Moors towards the South. Influences from both in all kinds of areas is prominent including surviving structures and everyday items. My in laws being from the South live in an area with a lot of visible Arab influence. A few years back upon excavating for the foundation of a new structure, they came across an old large well that somehow was in a sort of large underground void . It was almost like a protective structure was built over it prior to burying it. Inside well these pots were found. Most were broken with a few exceptions like this one. No one even knew exactly what they were not even the oldest people in the village. Experts from the National Archeological Museum were contacted. They knew what it was and described its function.They also carbon dated the pots and they are from somewhere in the 1500s. After that time other type vessels were used and eventually that method of lifting water was not used anymore. All other intact pots were donated to museum with the exception of this one which my in laws gave to me along with some other broken ones. This was from a Persian wheel or a"Noria". Ed's model describes it but it is a later version. I have below a photo from the museum's model of the actual type pot was used on. It was operated by a draft animal that was blindfolded so it would not get dizzy. Pot was tied to wooden wheel by a rope around middle recess. Hole on the bottom was so air would escape through it allowing water to go into pot. Found this good description of its history The History of the Noria.pdf 3 1 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #525 Posted May 14, 2019 (edited) That’s why I asked lol. You didn’t ya or ney one or the other so I wasn’t sure what direction to go in. I’ll get more in depth with my guesses from here on out. Another cigar for @Ed Kennell @formariz, we’re there any hoops to jump through to keep it? What ever became of the area it was excavated from? That hole was throwing off my searches, but if anyone wants to buy a Tangine steaming pot I have several websites for you 😂😂 Edited May 14, 2019 by LengerichKA88 2 Share this post Link to post Share on other sites
