Big haul coming Thursday evening
By
12 hp Kohler, in Wheel Horse Tractors
Similar Content
By CasualObserver
Operator manual
Illustrated parts list
6 pages 3.73MB
Illustrated parts list #A-7136
Includes PSB #023 #052 #058 #060 #080
10 pages 938.48KB
Engines used according to Toro
Clinton B1290-1107
Kohler K91-31307A
Kohler K91-31388A
Electric start kit
Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
6-12 tire chains model TC-12 - Listed for 1958 and 1959
Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
Details & Attachments
2 pages 107.33KB
1958 model RJ-58
1958 serial numbers that have shown up for the RJ-58
Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
00005
00251
01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
01188 - Has round rear wheel hubs
01516
01636
01768
01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
01797
01871
02525
03177
03501 - Located in UK
03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
04041
04883
04885
05000
05619
05714
05798
06528 - May be 16528
06749
06771
07633
07649 - Transmission J12-8 October 12, 1958
07725
08440
08612
09284
09337 - Hard to read
10163
11432
11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
11916
12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
12291
14473
14713
16097
16528 - May be 06528
166x6
16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
18348
June 2023
18500 and lower
Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
2 pages 106.94KB
1959 model RJ-59
1959 serial numbers that have shown up for the RJ-59
Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
18501 and up - Possible 1100 units built
20078 - Located in UK
203xx
21033
21259 - F30-9 trans casting date = June 30, 1959
292xx
21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
K91T-31388A Serial 425251 found on RJ-59
By BuffaloD200
Finally getting around to working on my ark loader. The previous owner said he thinks the problem is with the spool valve.
As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
I noticed the power beyond port is connected to the reservoir return. Is that right?
Anyone see anything blatantly incorrect?
By ccs002
Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
By Tim's Toy Tractor
Seat, New! Universal Garden Tractor / Riding Mower Seat
This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
$49.00 Call Tim @ 1-313-460-8858 (Local Pick-Up Only, No Shipping)
Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
Great for any Garden Tractor or Riding Mower
They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
$99.00 Call Tim @ 1-313-460-8858 (Local Pick-Up Only, No Shipping)
