Similar Content
By KC9KAS
Need assistance! 1977 Wheel Horse C-120 hydro. I sold it to a young fellow last fall. His dad said he put a new battery in it but it still failed to turn over to start. I checked the only safety switch (with an ohm meter) and it is working correctly. I checked all the wires (ohm meter) and they tested ok. I did come to the conclusion the 20 amp AMP gauge was bad. I installed an old one that I had and it turned over and started right up. I already had the voltage regulator wires disconnected and read 36 VAC from the stator. When I attached the wires to the (fairly new) voltage regulator it would immediately cause the engine to sputter and die. The voltage regulator is grounded directly to the negative post on the battery. Once the wires were removed from the voltage regulator it would fire right back up! I am at my wits end trying to figure this one out! Would a bad voltage regulator cause the engine to quit running? I may have to remove a voltage regulator from another known good machine and try it. Anyone have any suggestions? -
By Bach-Ed
I need a little part number help. I'm looking for the part number of the idler pulley that tensions the drive belt on my 857. The diagram shows the left side of the tractor. And I can't seem to locate the pulley on the parts drawing. The bearings have gone out on my tractor's idler.
By Bach-Ed
I needed to disassemble the brake/cluch linkage on my 857. Am I missing something or do 2593 Clutch Rod, 5544 Parking Brake Lever and 3935 Brake Rod all need to be in place on 4899 Clutch Rod Pivot Arm before I can struggle to align the holes with that of the 3950 Idler Arm Shaft to insert the roll pin? I'm using up all my naughty words trying to get this back in place. I'm hope someone can suggest a better way. Or all you can do is extend your sympathies?
By JasonMc
Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
Jason
By Bear G
Sold all three to one guy today..
Sad to see them go, but...
One of the reasons I’m selling is because I’m thinning my personal collection down to custom, modified only. So, I’m selling all my “stock” tractors.
Ilk still have a few “flip tractors”, but hope to get down to about 4 I’m my personal collection.
We’ve been up around a dozen for a year now.. too much to keep up with..
I think these are going to a good home.
