WVHillbilly520H 10,376 #26 Posted September 18, 2018 Pulled the nasty filthy leaking (from ethanol) Q-jet carb disassembled soaked and put a renew kit it and back on, also installed new plugs and wires, performance distributor cap, rotor button and coil, valve cover gaskets and removed about 50 pounds of useless A/C pump and lines, next up oil and filter change. Runs and idles so much better. 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #27 Posted September 19, 2018 Here's the after clean rebuild pics...still the O.E. non adjustable emissions carb from '79 I need to get the pressure washer and purple power out and give it a real degreasing. 3 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #28 Posted September 23, 2018 (edited) F.I.L has a couple of these square body C/K trucks and happened to have a seat cover laying around and I asked if I could put it to use, so at least now I'm not sitting on shredded vinyl anymore and picture of the "3 Amigos" plus his '79 K3500. Edited September 23, 2018 by WVHillbilly520H 2 2 Share this post Link to post Share on other sites
Pullstart 68,521 #29 Posted September 25, 2018 Such clean sheet metal! I’ve had a couple square bodies... or what was left of them. That ‘82 long box was a beast of a plow truck! Had long tube headers and dual purple hornies dumping straight down at about the transfercase. A bungee cord was strung behind the seat to hold the doors closed! The blazer had zero body mounts intact. Once I figured that out, I finished the plow season with it, then parted/scrapped it out. I didn’t allow any passengers, not even my 2 year old or newborn (who both frequented the truck before I knew how bad it was) 1 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #30 Posted September 25, 2018 (edited) @pullstart, Kevin that seems the worse about a GM the body falls off but the drivetrain just won't die. This other one is hiding out in a garage nearby as well, big block under hood and it could be available 🤔... Edited September 25, 2018 by WVHillbilly520H 4 Share this post Link to post Share on other sites
Pullstart 68,521 #31 Posted September 25, 2018 This is how I occasionally wash the ice worms out of my truck... ya know, in my best efforts to keep it clean! This super duty had 35” tires, for reference. And don’t tell anyone I used to own one of those “F” word vehicles 4 Share this post Link to post Share on other sites
Achto 30,183 #32 Posted September 25, 2018 (edited) 2 hours ago, WVHillbilly520H said: that seems the worse about a GM the body falls off but the drivetrain just won't die I worked at a body shop from '88 - '98, in that time I redid a lot of square body GM's. 2 outer fenders, 2 inner fenders, 2 doors, 2 rockers, 2 cab corners, & 2 box sides. Some times a tail gate & some floor pans. It was almost like being in the movie "Ground Hog Day" I still like those old trucks though and it is still fairly reasonable to put new bodies on them. Edited September 25, 2018 by Achto 4 Share this post Link to post Share on other sites
Pullstart 68,521 #33 Posted September 25, 2018 Hmmm..... @Achto was your 88-98 stint of redoing square bodies GM’s way of knowing it was time to roll out another body style in 99? coincidence? 1 Share this post Link to post Share on other sites
Achto 30,183 #34 Posted September 25, 2018 39 minutes ago, pullstart said: GM’s way of knowing it was time to roll out another body style in 99? That could very well be. You think they would have thought of that sooner though. The '73 models were already starting to rust out by '77. Albeit '73 & '74 were the very worst ones for rusting. 1 Share this post Link to post Share on other sites
PeacemakerJack 10,837 #35 Posted September 25, 2018 it would be interesting to see where they got their metal from for those body panels in the 70’s!!!? Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #36 Posted September 25, 2018 1 hour ago, PeacemakerJack said: it would be interesting to see where they got their metal from for those body panels in the 70’s!!!? I believe it was the beginning of recycled steel and crappy coatings . Share this post Link to post Share on other sites
953 nut 63,000 #37 Posted September 26, 2018 While living in upstate NY where everything rusts, I bought a new '70 Chevy 1/2 ton. Put it on the lift the day after I bought it, already had surface rust. I pressure washed the underside and gave it a couple coats of lacquer. Saw the truck about ten years later and it was in much better shape than most. I think they wanted them to rust so people would replace them. 1 1 Share this post Link to post Share on other sites
Sarge 3,470 #38 Posted October 1, 2018 We had an old square body full-size Blazer at the shop - used it to move trailers and such around a lot and other pulling chores. Tried to pull start a semi one day with it - when the strap took up the slop the body kept going while the chassis came to a stop - that was the end of that one. Took 2 of us about an hour to remove it's outer carcass barehanded, wow. Sarge 1 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #39 Posted October 5, 2018 @Machineguy, @PeacemakerJack, @pullstart, @Achto, here's the first load this old fella hauled since bringing it home, 2760 pounds of junk metal and plastic the F.I.L had laying around, went across the scales loaded at 10680 total, so around 7900 "empty". 8 Share this post Link to post Share on other sites
PeacemakerJack 10,837 #40 Posted October 6, 2018 Put the old dude to work that’s what I like to see! 2 1 Share this post Link to post Share on other sites
19richie66 17,765 #41 Posted October 6, 2018 Always nice to make more room 1 1 Share this post Link to post Share on other sites
Pullstart 68,521 #42 Posted October 9, 2018 Is that all you can get in there? Sheeesh, my Colorado could tackle that haul! 5 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #43 Posted October 9, 2018 5 hours ago, pullstart said: Is that all you can get in there? Sheeesh, my Colorado could tackle that haul! I needed your guidance but you were too far away, I was going load it up over flowing, but my F.I.L was done for the day. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #44 Posted October 13, 2018 The scrap payout helped reshoe the rear axle...just got them put on this morning at our local "Wally World"...same brand as the fronts just a bit more aggressive tread. 2 Share this post Link to post Share on other sites
Pullstart 68,521 #45 Posted October 14, 2018 I love a set of 215/85’s! Grab you some tire chains and you’ve got a dozer! 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #46 Posted October 14, 2018 4 hours ago, pullstart said: I love a set of 215/85’s! Grab you some tire chains and you’ve got a dozer! I think I have a set of army tire chains going to see if they fit sometime soon. 2 Share this post Link to post Share on other sites
squonk 44,860 #47 Posted October 14, 2018 Didn't that Crochruster have the knock out plugs for the mixture screws? Also looks like you needed $10 worth of vacuum line. If I had a Dollar for every Q-jet I redid I'd have a bigger garage. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #48 Posted October 14, 2018 4 minutes ago, squonk said: Didn't that Crochruster have the knock out plugs for the mixture screws? Also looks like you needed $10 worth of vacuum line. If I had a Dollar for every Q-jet I redid I'd have a bigger garage. Yeah it has the aluminum welch plugs in front of the mix screws just didn't bother them this round, changed a lot of vacuum lines out while I was in there, runs much better than the day I brought it home. Share this post Link to post Share on other sites
squonk 44,860 #49 Posted October 14, 2018 How's the Quadra-Bog? I've seen guys adjust the tension on the secondary air valves way too loose thinking they'd get more power. Whilst the opposite was true. Again if I had a dollar...... Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #50 Posted October 14, 2018 25 minutes ago, squonk said: How's the Quadra-Bog? I've seen guys adjust the tension on the secondary air valves way too loose thinking they'd get more power. Whilst the opposite was true. Again if I had a dollar...... No bog just a bit of a stubble and if indeed the original engine at 220k I believe it's a Cam lobe or 2 worn down, had a 79 Malibu years ago one of the best Q-jets I ever had no bog, stubble or hesitation from cold start up to running at operating temp, I am a firm believer in these old carbs when adjusted correctly on a overall good condition engine. 1 Share this post Link to post Share on other sites
