S.J.
Mower Deck Compatibility
S.J.
Hello! I have a 1975 C-100 lawn tractor, and it's in pretty decent shape. Only problem is the mower deck is shot. I've been browsing for used decks, but I'm not seeing any of the original part number, s-0622. So I'm wondering, what other decks would be compatible with this model?
Thanks!
daveoman1966
The correct deck model # is 5-0622.  That translates to a 36" wide deck.  You can use most any deck that has the 'Tach-o-Matic' attachment feature...but the 10hp engine of the C-100 will limit you to a 36 or 42" width.  The Tach-o-Matic system started in 1973 and still in use to the last production year of the decks....2007 (?).
Although a 48" deck would mount, I doubt that the 10hp engine would serve it well. Anyway, here are a few pics of 42" decks that will work. One is side discharge and the 2nd is rear discharge.
ps... Where are you in PA.  I can give you a 36" deck shell if you want to come and get it.  It is rusted out some, but may suit for a couple years yet. I am 80m north of Pittsburgh.
Edited by daveoman1966
953 nut
:WRS:
Dave is right on with the deck size, I have used a 42" rear discharge for years and love it. The list below will show you what decks etc. are compatible to your :wh:
S.J.
I'm about 40 miles south. Sounds like a good road trip. What are you asking for it?
S.J.
13 minutes ago, 953 nut said:
:WRS:
That looks incredibly useful! Thanks!
  • Similar Content
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • CS-17
      By CS-17
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $950 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • PAguy
      By PAguy
      Hello gents!
      I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
      I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
      Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
      Appreciate your guys help and thoughts.
