Xearl 132 #26 Posted April 2, 2018 This is 120 lbs. and works fine for me if I can stop stripping the brass gear . 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #27 Posted April 3, 2018 11 hours ago, Xearl said: This is 120 lbs. and works fine for me if I can stop stripping the brass gear . You have the Dxi diesel, Correct? If so you may have to run at 3/4 throttle instead of WOT, I think John Matthews @shallowwatersailor said something of the torque the diesel has wears on the snow thrower/blowers he had a single stage but Josh @PeacemakerJack has the Dxi 2stage maybe he can weigh in on this, Jeff. 1 Share this post Link to post Share on other sites
Xearl 132 #28 Posted April 3, 2018 After a very cold spell I picked up a chunk of ice that did the dirty deed . I have ordered a new gear ,worm and seals . I hope the rest is still OK because all was new . Thanks for the comment . ED 1 Share this post Link to post Share on other sites
PeacemakerJack 11,039 #29 Posted April 4, 2018 (edited) Thanks Jeff @WVHillbilly520H for the nod. My deuce was getting a bit worn in several places on the rotational mass. I replaced the auger bushings, the drive chain, did some repair work to the auger, and also replaced the impeller shaft bearing. It lent a new lease on life for my Deuce. I typically run it at full throttle as the manual says. I haven’t had much for trouble with it but I’ve also only used it about a half dozen times in the last couple of years. It is a great snow removal combo. Good luck getting yours back up and functioning... Edited April 4, 2018 by PeacemakerJack 1 Share this post Link to post Share on other sites
Xearl 132 #30 Posted April 4, 2018 I REPLACED THE BUSHINGS WITH BEARINGS LAST SEASON. I HAVE FORGOTTEN HOW TO TIGHTEN THE ECCENTRIC BEARINGS WITH THE ROTATION OR AGAINST THE ROTATION. I HOPE SOMEONE CAN HELP. Share this post Link to post Share on other sites
WHX?? 57,810 #31 Posted April 4, 2018 Is this what you need Xearl? Toro Technician Tips Eccentric Collar quality_tips_june.pdf Share this post Link to post Share on other sites
shallowwatersailor 3,221 #32 Posted April 4, 2018 Running the Single-Stage snowthrower at less than full throttle came from the New Haven Toro dealer in correlation to possible warranty work when these were brand new. When I owned my 523Dxi and the snowthrower, I had plans to check the corresponding rpm using an engine tach with a laser tach for the auger. I believe the Single-Stage mass of the auger spins at a higher rpm than the Two-Stage. But with the odd Maryland Winter snowfall sometimes I only used it one season and never checked the rpm of each. Share this post Link to post Share on other sites
Xearl 132 #33 Posted April 4, 2018 Jim , YES .Thank you . I had the info but could not find it . ED Share this post Link to post Share on other sites
Xearl 132 #35 Posted April 4, 2018 John , Thanks for the post . I do not think the 523DXI is at fault . The first gear that stripped was my fault . I went over the whole blower greasing and lubricating the chain but forgot the most important . The oil level in the gear box . The second I caught a solid chunk of ice that got jammed and caused the damage . I will have to be more careful . ED Share this post Link to post Share on other sites
