pyroplegic
sinngle stage CL score!
shallowwatersailor
Isn't there an adjustment using the washers between the flag and lift tube for leveling? Also the Dial-A-Height should be dialed out.
Racinbob
That's just for how high it lifts. Add washers....more lift. :)
Rick53
On 2/5/2018 at 7:46 PM, WVHillbilly520H said:
:text-yeahthat:
So Willy My Unit is exactly what you show in the right Picture : Can you read My Thread below this thread in regards to Broken belt and maybe answer my issue
Forest Road
Very nice score! As others said the wings are backwards OR upside down.
Chain tension is very important. If the idler sprockets are worn down to a point they need to be replaced as well as the chain. If the chain should let loose it's not unusual to have to toss the blower. It can do a lot of damage.
Chain and sprockets are are readily available and cheap!
Good luck w her!
pyroplegic
On 2/8/2018 at 4:58 PM, WHX14 said:
Also want to check the chain tension and oil after every use. Chain adjustment is done with the idler circled and speaking of idlers check them often for looseness. They get water in them and wear quickly but replacement ones are at TSC.
I don't see how this will adjust, it's does not look to be a slot to slide the idler in to add or release tension in the chain.
. To adjust, loosen the bolt that secures idler sprocket to left side housing. (Fig. 28). 3. Slide idler sprocket in adjustment slot until chain is snug, but not tight (Fig. 28). 4. Tighten idler sprocket securely
Edited by pyroplegic
WVHillbilly520H
Yes, the lowest nut on the left (3/4" wrench/socket), you will need to loosen it up quite a bit if not all the way the slot is most likely rusted/painted over not much adjustment there 1/2"-1" max after getting the scale out of there tighten back up to "snug"/loose then use a "prybar" on the idler sprocket to move/add tension without getting the chain too tight approximately 1/4" deflection on the chain from top to bottom idler sprockets (you will need to remove the chain guard for access) rotate auger a few times double checking the tension till you get it right then firmly tighten the sprocket nut, Jeff.
Edited by WVHillbilly520H
pyroplegic
Bust the paint out for sure
doc724
On 2/8/2018 at 5:06 PM, shallowwatersailor said:
Another "tool" to use to set the height are paint stirrers from Lowes/HD/paint store. The small gallon-can ones are 1/8" thick and handy for walk-behind snowblowers. For a tractor-mounted snowthrower/snowblower the five-gallon stirrers are about 1/4".
Great minds think alike John.  I use paint stirrers also, only the gallon size though :-)
pyroplegic
This didn't come with a spring and I found a #150 punching bag spring on Amazon for $8.
We jacked the blower higher than the lifter bar would lift,
Attached the spring to the eye-bolt, that had the nyloc nut backed nearly all the out
Attach the bell of a 1/4" shackle through the other end of the spring, and the pin through an existing hole in the frame just in font of the floor board,
Tighten nyloc nut to apply tension to the spring
Lower jack and enjoy your lighter blower
(black is rust-converting primer I-H Red tractor paint is going on tomorrow)
pyroplegic
Any idea what this part is? it looks like a lower retention ring on the bottom of the chute. perfectly broke off with the part number on it. the chute now has 1/2" slop at the base, are there barrings to look out for in that area?
pyroplegic
are there multiple of these holding the chute on?
WHX??
'Fraid so ...three but  CRS ...get ready to buy more than one.
pyroplegic
yess searching is $15-$20 ea
peter lena
nice looking unit, my response is  LUBRICATION IS KEY , on this . I use LUBRIPLATE CHAIN AND CABLE SPRAY,  its made for brutal applications. I spray before use and after. never let that gear to chain dry out. also lube the double pulley spring tension frame , this will insure that the spring tension is smooth and constant on your Kevlar belt. found that just going over all metal drag contact points with lube, like chute guide wheels and mounting point to blower ,along with the auger adjustment rod , makes things effortless. wheel horses are always starved for lack of lubrication, don't keep that mind set going. been there , pete
Ed Kennell
Before I switched to all hydraulic lift tractors, I had three springs (garage door sections) on my blower lift.
Pullstart
On ‎2‎/‎5‎/‎2018 at 7:46 PM, WVHillbilly520H said:
:text-yeahthat:
@WVHillbilly520H   Nice trucks!  Sorry, off topic...:unsure:
  • Haha 1
WVHillbilly520H
The green Chevy is my F.I.L's does run but needs some attention and the yellow Ford is a neighbor's who he was supposed to fix the brakes on 3 years ago but needs to lift the radiator cap and drive a new one under  :think:...
  • Haha 1
Ed Kennell
                  :text-yeahthat::ROTF:
Never thought of that.     I have repaired a few that this would have been a better fix.
  • Haha 2
  • Similar Content
    • FarmallFarmer09
      By FarmallFarmer09
      I recently purchased my first wheel horse with a number of new attachments, And included in that bundle was a Wheel Horse snow blower. I would love to use it, But as it seems, Its missing a few key components to use it. Its missing the 2 side caster wheels, Along with the lift rod. does anyone know where i could potentially pick up either of these things?
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
    • jebeli
      By jebeli
      Lets make a deal. The whole collection for $3000 or one tractor and half the items listed below for $1500.
      I am moving to town so am willing to do a partial trade for a wheelhorse more approproiate for a suburban lot- lawn ranger, surburban models, bcs walking tractor, other?
      I could possibly deliver or meet half-way or ship.
      Both tractors run great and are in good working order. Second owner of both machines. I work with these machines everyday so they are not perfect but are, in my opinion, in excellent shape.
      42in high-shoot snow blower
      42 in rear discharge deck
      Snow blade
      Front mount deck hanger with 42in side discharge deck
      30in lawn seeder
      Brinly single bottom plow with cleavis or sleeve hitch
      50in grader blade
      Extra transmission
      36in rear tiller - leaks a little
      Full set of tire chains for each tractor
      Various body pieces
      7.5 cubic ft pull behind cart - may need tires
      Extra set of rims
      All required belts, pullys, brackets, manuals, too much to list.
    • 83mercedes
      By 83mercedes
      i am going to be getting a 518h with a snow blower as i am new to having a snow blower one thing i noticed was that the chains have a fair amount of play how much is to much ,and would like  a service manual or a manual that would give me these facts,thanks
