ebinmaine 80,198 #17251 Posted October 2, 2022 10 minutes ago, peter lena said: @ebinmaine stay after that front end greasing , with that extra load drag , sure you are aware , lucas green , pete I still have a gun with Red n Tacky in it. 4 Share this post Link to post Share on other sites
Andy N. 2,806 #17252 Posted October 2, 2022 6 hours ago, OldWorkHorse said: I like red but not everything red, so I try to break it up here and there your plow looks great! If you need new decals check out redoyourhorse.com good price great product. Ordered them last night from him! 2 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #17253 Posted October 2, 2022 Airing the old girls out... Don 6 3 Share this post Link to post Share on other sites
Panther416-8 342 #17254 Posted October 2, 2022 11 hours ago, ebinmaine said: Nice amount of weight! That'll certainly help. How well do you feel those front tires work for steering in snow n ice? Ever run front chains? Ever tried reversing the tread as discussed a few posts up? @ebinmaine they've worked well with my 48" plow in the snow/hard packed except when angling the plow. I may add some chains to the front to see how that helps this winter. @peter lena I greased up the front end while suspended today but I switched over my grease gun to that red lucas high temperature grease when I did my PTO recently. Is that no good for the axle/spindles/hubs? 1 Share this post Link to post Share on other sites
ebinmaine 80,198 #17255 Posted October 2, 2022 12 minutes ago, Panther416-8 said: may add some chains to the front to see how that helps this winter. I've been thinking about doing the same on my 20" fluid filled turf tires I use as steers for the snow plow tractor. 13 minutes ago, Panther416-8 said: . Is that no good for the axle/spindles/hubs? IMHO: Red n Tacky is perfectly fine for that application. Share this post Link to post Share on other sites
Heatingman 977 #17256 Posted October 3, 2022 (edited) Just about finished with the B-80 overhaul. Still need to put in the lifing arm, head and tail light, make the trim for the headlight, and a few other odds and ends. Gotta wait a few weeks before I put the decals I got from redoyourhorse.com on. So the paint can cure some. I was able to make the seat cover and cushion from @Burnerman work, and the headlight I got from him should work aswell. I did not notice when I first got the replacement seat cover that it was a touch taller then the original, so to get it to fit, I had to trim about an inch of foam from the back rest, and trim the vinyl to get the windlace to secure it properly Edited October 3, 2022 by Heatingman 4 13 Share this post Link to post Share on other sites
ebinmaine 80,198 #17257 Posted October 3, 2022 2 hours ago, Heatingman said: B-80 overhaul Looks excellent!! 1 Share this post Link to post Share on other sites
ebinmaine 80,198 #17258 Posted October 3, 2022 On 10/1/2022 at 1:07 PM, ebinmaine said: add some weight Back on Saturday at 1 PM I posted about adding the weights to the front of my C160. VERY glad I did... I tested it yesterday by pulling 4 loads of wood out of the forest. Even with that beast of a weight hanging around out there it still gets a tad bit light in the steering here n there. Had a couple split second pucker inducing moments. It'll do though. 1 Share this post Link to post Share on other sites
Ed Kennell 46,879 #17259 Posted October 3, 2022 Four days of cold rain and no sign of any sun for a few more days till Ian decides to head across the Pond. So I pulled the 312H in to the heated shop and started the switch from lawn mowing to snow plowing. Pulled the 42"SD and gave it a greasy Pete winterizing treatment. No sun so it'll have to dry inside this winter. Changed engine oil and greased all zerks. Except that dag blamed steering block. Guess I gotta take the belt guard off to get to it...nuther day. The rubber tire chains and the 48" snow plow will go on for the winter. 3 9 Share this post Link to post Share on other sites
squonk 47,848 #17260 Posted October 3, 2022 On 10/2/2022 at 9:19 AM, ebinmaine said: I still have a gun with Red n Tacky in it. Greased everything in the shop yesterday. 20V Dewalt gun. Ran out of R & T halfway thru. Had another tube on the shelf. Goody!!! One of my favorite jobs! Refilling the grease gun! Went to get a pair of nitrile glove and I find an empty box! Went to where I thought I had my stash of gloves and all I find there is a Hornet's nest!! now I need more Brake Kleen to deal with the hornets. Wood Bees have been bad enough now this! 2 1 Share this post Link to post Share on other sites
squonk 47,848 #17261 Posted October 3, 2022 12 hours ago, ebinmaine said: Even with that beast of a weight hanging around out there it still gets a tad bit light in the steering here n there. Just lean forward! 1 3 Share this post Link to post Share on other sites
peter lena 10,000 #17262 Posted October 3, 2022 @Ed Kennell glad to see that winterising oil soak going down , the opposite of wet / moldy for months lets the oil soak in and feed that metal . my decks are stained black , zero rust / grunge , leave them on the back side , so the treatment is held there . after weeks , use a spring to hold them up against the wall . no oil drip issues , been working for me , pete 4 Share this post Link to post Share on other sites
ebinmaine 80,198 #17263 Posted October 3, 2022 2 hours ago, squonk said: Just lean forward! Man I'd have to sit on the weight and steer from the front. 1 Share this post Link to post Share on other sites
ebinmaine 80,198 #17264 Posted October 3, 2022 @squonk here's the heaviest load I've tried to pull up the new ramp. That's a 17 cubic foot Ohio Steel trailer that's mounded over with wet maple. Note I said tried. The underlayer of VERY soft sand stopped me from getting all the way up the new ramp to the new building site. Not a big deal. I just backed down and went around to the backyard access gates which was an easy climb. I'll be starting a thread looking for ideas about how to address that situation. 6 Share this post Link to post Share on other sites
lynnmor 8,999 #17265 Posted October 3, 2022 22 minutes ago, ebinmaine said: @squonk here's the heaviest load I've tried to pull up the new ramp. I'll be starting a thread looking for ideas about how to address that situation. I wonder how much rolling resistance is caused by the heavy front end pushing the ag tires into the soft surface. Share this post Link to post Share on other sites
ebinmaine 80,198 #17266 Posted October 3, 2022 Just now, lynnmor said: I wonder how much rolling resistance is caused by the heavy front end pushing the ag tires into the soft surface. Nowhere near enough... Odd as that sounds. With that heavy load on the rear hitch the front of this tractor is still QUITE light by the time I get to the top of that ramp. Like light enough that it barely steers. 1 Share this post Link to post Share on other sites
lynnmor 8,999 #17267 Posted October 4, 2022 I have a similar trailer hauling similar loads of wood, my 23" turf tires spin easily going up a grade that isn't much. I have wheel weights but don't use the chains. What I do is put the hammer down before the grade and keep it down. 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,962 #17268 Posted October 4, 2022 On 9/30/2022 at 6:52 PM, WHX?? said: I was gonna tell ya it was off the ultra rare C-184 ...I'd really been pulling yer stump tho... I probly would have taken that bait too 2 Share this post Link to post Share on other sites
ebinmaine 80,198 #17269 Posted October 4, 2022 45 minutes ago, lynnmor said: I have a similar trailer hauling similar loads of wood, my 23" turf tires spin easily going up a grade that isn't much. I have wheel weights but don't use the chains. What I do is put the hammer down before the grade and keep it down. Yessir. Done did that too. I have Cinnamon Horse's K341 top RPM set at 3300. That in 3rd high is what began the approach. With a less loaded trailer it'll easily climb the hill but at the top I have to kill the RPMs or I can't make the slight left turn due to floaty front tires. Share this post Link to post Share on other sites
SylvanLakeWH 32,075 #17270 Posted October 4, 2022 21aa gravel might do the trick… sand spreads under load. 21aa locks up. 1 Share this post Link to post Share on other sites
ebinmaine 80,198 #17271 Posted October 4, 2022 5 minutes ago, SylvanLakeWH said: 21aa gravel might do the trick… sand spreads under load. 21aa locks up. What is that by size of rock? Share this post Link to post Share on other sites
8ntruck 9,204 #17272 Posted October 4, 2022 Roto roller and Portland cement? Share this post Link to post Share on other sites
Lee1977 7,746 #17273 Posted October 4, 2022 7 hours ago, Ed Kennell said: Four days of cold rain and no sign of any sun for a few more days till Ian decides to head across the Pond. So I pulled the 312H in to the heated shop and started the switch from lawn mowing to snow plowing. Pulled the 42"SD and gave it a greasy Pete winterizing treatment. No sun so it'll have to dry inside this winter. Changed engine oil and greased all zerks. Except that dag blamed steering block. Guess I gotta take the belt guard off to get to it...nuther day. The rubber tire chains and the 48" snow plow will go on for the winter. Ed I just went and checked all my Wheel Horses, the steering block grease fitting is on the left side, just where I though it was. Don't think the removing the belt guard will help you. 2 Share this post Link to post Share on other sites
Ed Kennell 46,879 #17274 Posted October 4, 2022 2 minutes ago, Lee1977 said: the steering block grease fitting is on the left side I took the left side panel off, but there is another panel under that one . To get that one off, I would have to remove all the hydraulic lift hoses and the brake linkage. I'm not going to disturb the hoses. I'll jack it up and see if I can get a U joint on the zerk from below. Thanks for the info. 2 Share this post Link to post Share on other sites
Lee1977 7,746 #17275 Posted October 4, 2022 10 minutes ago, Ed Kennell said: I took the left side panel off, but there is another panel under that one . To get that one off, I would have to remove all the hydraulic lift hoses and the brake linkage. I'm not going to disturb the hoses. I'll jack it up and see if I can get a U joint on the zerk from below. Thanks for the info. I have though of using a hole saw to fix that problem, just haven't done it yet. 1 1 Share this post Link to post Share on other sites
