Shynon 7,477 #1 Posted September 3, 2017 (edited) I picked up my second 520 awhile back from @DeterminingFactor that had no spark. Changed out the 9 pin connector from @rmaynard as the red wire was already routed around the 9 pin. Found the coil was bad and replaced. Motor runs good and now on to the next step. PO said hydro was leaking I think I found the problem so tomorrow I will open up the hydro and replace all seals and gaskets. Plan on wet sanding all the tins and repaint, new decals will need to be ordered. Now if I could only convince @ACman to release the rights to the wheel a matic decals, other wise it may end up being the patriotic series decals. This one may take a while as still working 10hr days and Saturdays. I'll try to post as much as I can. Also picked up an Ark loader for it. Need to build subframe, new hoses and modify a few other things Edited September 3, 2017 by Shynon Add pics 14 2 Share this post Link to post Share on other sites
ACman 7,639 #2 Posted September 3, 2017 @Vinylguy has my blessing to sell the 520Wheel-a-Matic decal set especially if he can make some $ and keep fellow members happy. I had the idea but he pulled it right out of my head and did the hard work . Terry and Lola for supporting our hobby 2 2 Share this post Link to post Share on other sites
Shynon 7,477 #3 Posted September 3, 2017 Thanks to @Vinylguy and @ACman for the creation and release of this great looking set of decals. Now Minnesota will have one and maybe even two 520 Wheel-a-matics. Terry let me know how I can order a set then maybe I can be sent with the toy tractor you are working on . Thanks Again for all you do 3 Share this post Link to post Share on other sites
AMC RULES 37,194 #4 Posted September 3, 2017 Toy tractor? 1 Share this post Link to post Share on other sites
ACman 7,639 #5 Posted September 3, 2017 I'm thinking maybe a 1/16 scale 520h made from a White Field boss toy tractor? Share this post Link to post Share on other sites
Shynon 7,477 #6 Posted September 11, 2017 Had some time this week to open up the differential and fix the leak, put in new seals. Thought I would wet sand the tins, but no had to blast some of them. Put some primer on may paint later this week. Need to get with @Vinylguy and get some decals ordered. 6 Share this post Link to post Share on other sites
Shynon 7,477 #7 Posted November 18, 2017 (edited) Got the differential back together, painted the tins. Now on to the loader. Edited November 18, 2017 by Shynon 7 1 Share this post Link to post Share on other sites
prondzy 3,889 #8 Posted November 19, 2017 Looks like your missing a subframe how are you ever going to figure that one out 1 1 Share this post Link to post Share on other sites
Shynon 7,477 #9 Posted November 25, 2017 Well got everything pulled out for the loader install. And this is were I left it as I am spending a few days in bed under the covers 1 2 Share this post Link to post Share on other sites
953 nut 59,539 #10 Posted November 25, 2017 16 minutes ago, Shynon said: spending a few days in bed 5 1 Share this post Link to post Share on other sites
Shynon 7,477 #11 Posted November 28, 2017 Got back to it today, subframe almost done. Pretty much an exact copy of a Wheel Horse subframe. 3 6 Share this post Link to post Share on other sites
dclarke 4,078 #12 Posted November 28, 2017 Nice work, Tom! 1 1 Share this post Link to post Share on other sites
R. L. Addison 299 #13 Posted November 29, 2017 Do not understand all I see, but I will keep watching to see if the light comes on. 1 Share this post Link to post Share on other sites
WHX?? 51,567 #14 Posted November 29, 2017 Real nice work Tom ...like that rear rubber 1 1 Share this post Link to post Share on other sites
Shynon 7,477 #15 Posted December 9, 2017 Subframe completed, waiting for paint to dry 8 1 Share this post Link to post Share on other sites
Shynon 7,477 #16 Posted December 10, 2017 Loader is on, now need to make some upright support braces and pump mount. 10 Share this post Link to post Share on other sites
Shynon 7,477 #17 Posted December 16, 2017 (edited) Got the loader bracing done today. Went to see @wheelhorseman to punch some holes and bend some steel. Welded it up today. Pump brackets next. Pump is done. Edited December 16, 2017 by Shynon Added pics 6 4 Share this post Link to post Share on other sites
AMC RULES 37,194 #18 Posted December 17, 2017 Can't wait to see the shakedown video Tom. 2 Share this post Link to post Share on other sites
Shynon 7,477 #19 Posted December 17, 2017 Got a couple new hoses made, new belt, filled her up with oil for a shakedown. Scraped off the sidewalk everthing seemed to work as it should. Here's a short video. 7 6 Share this post Link to post Share on other sites
AMC RULES 37,194 #20 Posted December 17, 2017 So sweet... have the rear weight box Tom? 1 Share this post Link to post Share on other sites
Shynon 7,477 #21 Posted December 17, 2017 3 minutes ago, AMC RULES said: have the rear weight box Tom? No, up next will be weight box and full set of cast weights, oil filter for the loader. Gonna have a new bucket made as this one is in bad shape, gonna figure out how to put some forks on it also 3 Share this post Link to post Share on other sites
AMC RULES 37,194 #22 Posted December 17, 2017 Very inspiring stuff... have to get mine back on it's feet. 2 Share this post Link to post Share on other sites
ACman 7,639 #23 Posted December 18, 2017 I could see some costume Load-R-matic decals in the future...Awesome job ! 1 Share this post Link to post Share on other sites
WHX?? 51,567 #24 Posted December 18, 2017 Nice...clamp on forks on the bucket work for ya or too much weight out front.? Always thought some kind of quick attach setup like a skid steer for bucket and forks??? Bring the weight closer back?? 3 Share this post Link to post Share on other sites
Sarge 3,465 #25 Posted December 18, 2017 Now you can properly grease that front axle - without having to bend over as well....great ! Sarge 4 Share this post Link to post Share on other sites
