BPIII
1989 Wheel Horse 208-4 PTO problem
BPIII
My 1989 Wheel Horse 208-4 (well my son's now) PTO has failed.  Can someone point me to a parts list or provide the part number?  Thanks for the help
gwest_ca
Welcome to the forum.
Keep us posted on your progress.
Garry
Adding - There is a 5-page file here that will assist if the problem is electrical
The original 112849 electric clutch has been replaced by 99-8011
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      I need the large metal pulley that houses the needle bearing and ball bearing with the two grooves.  The outer bearing seemingly wallowed out its hole and my welder guy cannot revive it.
      Shipping to Erie PA. 16509.
    • the jeep driver
      By the jeep driver
      My daughter was using the Wheel Horse rider to mow, I was push mowing.  She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving.  I disengage the blades, and re-engage... nothing.  No movement from the belt nor clutch.  Then I notice the smell, and look closer, the belt is so hot is melting on the clutch.  Or rather, the clutch is so hot it's melting the belt.  Melting occurred.
      While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
      So, what did I do now?  Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall.  I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad.  I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
      Some pictures of the clutch, can anyone tell if it's usable from them?
    • decvt79
      By decvt79
      My 1999 270H with 48” deck is having an issue getting power to PTO.   Checked PTO with jumper to battery and it worked fine and I’ve actually been cutting grass using the jumper for awhile.  I checked power from PTO switch to PTO and there is none.  I checked PTO switch and it appeared OK but I replaced it anyway and still no power to PTO.   Then checked brown/tan wire leading to switch and there is none.   Could the issue be the NMIR module and is there a good way to check it.  If bad, where is the best place to get a replacement and do other brands/models have NMIR a modules I can use.    Also, would suppling battery power directly to PTO switch and bypassing NMIR result in switch working.
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • BMW1
      By BMW1
      What direction does the front PTO Pulley turn on a wheel horse D180 with a Kohler K482 as you face the front of the tractor?
      I want to get a hydraulic pump for a Johnson 10 loader I will be mounting to tractor and want to make sure I get a pump that rotates the correct direction.
