RJcollector
RJ-58 Side cover
RJcollector
Hi, I'm rebuilding an RJ-58 tranny and its all together except the left side cover will not go on because the brake shaft is not lining up with the bearing. Its off by about 1/16th of an inch. The bearing on the other side cover is not cocked. The only parts that are not original in the tranny is the big differential gear and a couple bearings but they are the correct size bearings. It is the correct gear, its just out of another unit. Same part number and everything-3502. Did those big gears vary slightly in size during production? because it seems like if the big gear was about 1/16 smaller, I would be able to push the gears together and the cover would slight right on. Any help would be appreciated. Thanks
stevasaurus
post 147 in the link Jeff gave is the one you want.  It probably is not the brake shaft not lining up, but the cluster gear shaft.  You should be able to either swing the plate around or use a screw driver to push the brake shaft to get that started.  It's that last 1/4" that is the cluster gear shaft that is listing to port.  Use a piece of fishing line to go around that shaft and pull it a little to line up the bearing.  Make sure you can pull the line out when you get it to go.  :)
  • Like 6
formariz
Nothing more reassuring than to hear the voice of experience!
  • Like 5
RJcollector
@stevasaurus @ACmanThank you for the idea. My problem is that I cant even get the brake shaft started in the bearing hole. Its not just the last 1/4".  Ive tried moving both shafts every which way and the brake shaft seems to be too far towards the front of the transmission by about 1/16th of an inch and it will not go into the bearing. Ill try to get a few good pics so you can see what going on.
stevasaurus
Yep, want to see some pictures.  I'm wondering if you have the compatible mushroom gear and bull gear.  There are 2 sets of these, and you need the right pair.  Count the teeth on the small part of your mushroom gear...it is either 8 or 11.  If it is 8, you need the older style bull gear (it has larger teeth).  If it is 11, you need the bull gear with more and smaller teeth.  A picture of those would tell me.  Also, your left side cover plate...does it have a needle bearing or the ball bearing for the brake shaft??  :think:
RJcollector
That has to be it!  My mushroom gear has 8 teeth and it didn't really seem like it was meshing correctly with the bull gear but I figured it had to be right because they came from an RJ. That makes perfect sense now because if the gears meshed correctly, that's the 1/16 I need for the brake shaft to slide into the bearing.  I didn't know there are 2 different gears. I guess early RJs had one gear and later ones had the other? Also I have a needle bearing for the brake shaft in this side cover. I have another spare side cover that has ball bearings for the brake shaft. Which one of those is early and later? Thank you for all this information. I appreciate it. I took a few pics but they're not uploading for some reason, Ill keep trying.
stevasaurus
Has to be what is going on.  Here is a link to the manual...check out the service notes page on page 14.
492-4004.pdf
Edited by stevasaurus
RJcollector
@stevasaurus Thats it exactly. Thanks again. Now I can start the search for the correct gears :woohoo:
stevasaurus
Here is a pic of the pair that has the 11 teeth on the mushroom gear and the correct bull gear.  You can see the difference in the bull gears with the one you have.
Here is a couple of pics of the older style bull gear.  Notice the teeth and the number of.
The needle bearing is newer.  If you are going to try to use the older style, you are going to want the ball bearing plate.  Do you have the older style bull gear??
RJcollector
I have the bull gear like the 1st pic and the incorrect 8 tooth mushroom gear. My older style bull gear looks worse than yours in the 2nd pic. :text-lol:
stevasaurus
actually, those pictures are from a couple of transmissions that @Jake Kuhn had that I was fixing for him.  :)  He may have the parts you need.  :)
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • bigbuck
      By bigbuck
      I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
    • RJcollector
      By RJcollector
      Ive been thinking about selling my 4 RJ-58s and all the attachments and parts I have. I have 4 tractors-2 have Kohler K91T , 1 has the Clinton and one has no engine. Only 1 is missing the serial number decal. Kohlers run. Clinton needs a carb. I have original exhaust shields AND belt guards for 3 of them. 3 mower decks, 2 plows, cart, 2 spare transmissions, parts breakdowns, original manuals and sale tags, seats, tires.  Not sure if I should sell it as 1 big collection or break it up. And also a good starting price?  I'll post pics when I get a chance. Thanks
    • wh315-8
      By wh315-8
      The RJ58 was the big hit for spectators this year at my local festivals here in Carroll County OH.
      the children loved getting their pictures sitting on it, then they discovered the bicycle horn under the steering wheel. It’s always a joy even in parades. Just love showing off part of my collection every year and hearing all the stories from those that had WH in their lives at one time. Can hardly wait to get to retirement so I can get some of my other models back to their glory in working order and be able to attend other shows/festivals throughout the year. My fellow tractor enthusiasts always know when a spectacular starts asking about WH, they point in my direction. I study up on the history of the different models and always intrigue those that didn’t know much about how WH came to be. This website is one place that has helped me learn so much about the WH history and I thank you for sharing your knowledge that I am able to pass on to keep WH alive and well.
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
