oliver2-44
WH 520XI for sale near me? What to do?
oliver2-44
So I'm going to ask the WH "Lions Dens" opinion on this one?
As the story always goes I was searching 'that for sale site", usually looking for that rare old round hood and I came across this ....1997 Model 520xi Toro Workhorse, Number 73540 Kohler 20 hp, engine, Eaton 11 Hydro, 2 speed Uni-Drive® transaxle with a hydraulic lift 52" Side Discharge Mower. Seller is asking $600 and is selling due to moving from larger property to a small property across the country (He is the 2nd owner and has maintenance receipt's back to 2002 when he bought it. Last fall it had +$300 of service, (belts, blades, engine & transmission oils & filter changes. It runs good, no smoke, and has a few paint scrapes and the hood bottom front piece is broken, seat has cracks, tires seem good, Eaton transmission seemed to work OK but I did not get to get it hot and spin the tires with it against a tree,  deck appears solid, reportedly garage kept.
 I really don't need a 52" deck and would end up putting my 42" on it.  I'm a little concerned about all the electronic circuits on it (I sort of like the simplicity of my older 312 and C-160)
I have a John Deere LT150 :text-imsorry:as my mower tractor that I could sell to my sister and almost be no money out of pocket. I've only physically seen one of these, so I'm a rookie on these later model WH's!  I 'm on the fence of why this one interest me, so here's my questions:
1. Am I correct it does not have the "swept front axle"?  (I've read most 97's do not)
2. It does not have power steering....would I regret that?
3. Am I correct that my current attachments that fit my 1985 312-8 (42" deck ,long frame doze blade, grader blade, and tiller) will fit this tractor (since they fit all 300, 400, 500 series tractor)?
4. WH are somewhat rare in my area which means there usually a little pricier, but they all do show up for sale over time. So if I want a newer model should I be holding out for power steering and a swept front axle?
5. Yes I have the WH addiction, but do ya'll see anything in the pictures and price that I'm missing
Irv
I'd jump all over that, even if I didn't need it! And no, your 42" deck won't fit. XI series attachments mount differently than 300-500 series.
DennisThornton
While you are racing over to buy it (or why aren't you?)  do note:
classic attachments do not fit and "xi" attachments are much harder to locate.
Some of the 20hp Kawasaki had a plastic cam gear that disintegrate.  I don't have access to the year & serial right now but I'm pretty sure that yours is not affected.
I thought all the 520xis had power steering!  Pretty sure only the classic style 520s has a swept axle but you're most likely referring to the reduction steering that some had.  Never heard of the "xi" s having that.  If indeed it does not have PS then don't ever ride one that does.  It is wonderful!
The "xi"s are not only physically bigger but in my opinion a big step up from the classics.
shallowwatersailor
My first words are: Buy it!  This actually a 1998
This 520xi is one of the five 5xi models offered by Toro Wheel Horse. I have a 520xi .along with a 518xi and 523Dxi. There was also a 520Lxi that had a water-cooled Kawasaki engine and power steering. The one downfall is that only the attachments made for the 5xi fit so your other Wheel Horse attachments won't fit. You won't be able to attach your 42" deck. I'm not sure how the widespread the marketplace was in your region for these tractors. It may affect finding other attachments, but they are out there. The plastic valance is probably cracked on 75% of these tractors. There actually is a sturdy steel bumper behind it.
  All of the 5xi models have a 52" wheelbase with the swept axle and a refined steering reduction system. It does have what they call "Smart Turn" which automatically, through a mechanical linkage, slows the tractor while turning. It was intended to keep the tractor from flipping if the operator had the cruise control engaged.
Two of my three do not have power steering. I actually find them to be more precise in driving. My Dxi has an additional 100 pounds on the front axle because of the diesel engine so I'm glad that one does. It is just personal preference.
The dozer blade may possible be able to be adapted but i am pretty sure the others won't without a lot of rework. The 52" is a good size deck for this tractor.
I wouldn't hold out considering the price on this one.
Just check the hydro like you mentioned.
Good luck and post any other questions.
  • Like 4
bmsgaffer
If you could be no money out trading that green thing fgor this beast its a no brainer... you should already be on your way.
As mentioned above, any 300,400,500 series attachments do not fit the XI series (even though they too have a 500 number.)
This has a 20 HP Kohler as its a 520xi not a 520lxi, no cam gear issues but no power steering. I dont think you will miss it without having any super heavy front attachments as they have a very good steering mechanism.
Adams94
Seems like a steal to me!
WHX??
Last pic on the right Ollie looks like there might be some oil on the RR wheel from a leaking seal?? Pic next to it doesn't show it so maybe nothing. That deck looks to be a beast!  Good luck if you should snag it.
oliver2-44
Thanks for the info. It kind of hurts that my attachments won't fit as I've finally acquire the main attachments I've wanted.
I've always been confused when I read "fits 300,400,500 series.  So am I correct that my attachments would fit a 520H, but not a 520 xx  etc.
I'm feeling other attachments for it will be really hard to find around here!...Tough decision time.
(I think my wife is OK with the tractor, but a whole new set of attachments probable wont fly)
WVHillbilly520H
I have 3 520H's and I'm hard pressed not to say they're my favorite but I also have 2 5xi's a 520xi like you're deciding on without power steering and a 60" deck after I brought it home in November I tried it out it steers just as easily if not better that the 520H with a 48" deck and also a smaller/tighter turning radius then of course shaft driven 2 range Eaton 11, better attachment lifts (if you can find attachments) and I hear the 52" is just about the best quality cut of the decks, my other 523Dxi ($800) I bought non running but in the process of correcting that so I haven't gotten to see the difference in non vs power assisted steering, have you pulled the engine shields to check for oil leaks the Kohler commands seem to be bad for? Other than that go buy it,Jeff.
Yes B,C,3,4,500 attachments are all pretty much interchangeable, but the 5xi and 260 series are of a different design and it's just not your area even here where I live the xi series isn't around, even though I know where a N.O.S. unsold 522xi is still setting at my original dealer in WV,Jeff.
Wishin4a416
If that is a good running tractor, it is a 1500.00$ machine around here.
Hours????
obone
I kind of like it when people like you ask these types of questions. Makes me laugh a little. You know what everyone is going to say. GO GET IT NOW! But not me. I'm only going to ask WHERE this diamond is... Nah just joking good luck.
oliver2-44
It has 516 hours and the hour meter appears to work!
Ed Kennell
  do ya'll see anything that I'm missing.
Just the BOAT, if you haven't bought it.
WVHillbilly520H
Let's just say my 520xi with 60" deck clevis hitch and 1100 hours set me back twice that asking price and the paint isn't as shiny as that one, if you want the "Cadillac" of :wh: lawn mowers the xi are the ones and keep the classics for all your acquired attachments as I have a single stage and 2stage blower, cab, snow blade, tiller, 3 48" mower decks and a vacuum bagger for the 520H's ,then just the 48" and 60" deck and snow blade for the xi, with the possibility of a single stage thrower coming soon, Jeff.
can whlvr
wow,only 6 bills,up here with that little of hours she would be 2500
WVHillbilly520H
Thought you might like to see pricing from back in '99 when it was new, and the N.O.S. ,Jeff.
oliver2-44
Thank you for all the good information an I especially thank you for your support during my time of  increased addiction.
It was hard, but I passed on this tractor.  I realize it was a great price but xi attachments are just not found around here. Yes I could have bought and resold it for a profit but ...Also a tractor to put a loader on is high on my list and I realized power steering is a high loader priority as I'm not as young as I used to be
Thanks again, it was a good learning lesson
Let the flogging begin
Edited by oliver2-44
DennisThornton
Oh indeed!  I missed that "L"!
WHX??
We get it Ollie......ever consider moving??? And not by @Racinbob...worse down ther I hear! Guess as  the song goes gotta know when to hold em and when to fold em.
Racinbob
Ya thunked there's any other reason for wanting to move back to northern Indiana? :)
I really can't blame you for passing on it Jim. The XI series intrigues me and must be great by all the things I read and hear about them but the attachment thing has always been a stopper for me too. I must say though, that seems like a smoking deal. :)
  • Similar Content
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • Bill Murray
      By Bill Murray
      Looking for a replacement headlight assembly. I just bought a 520XI with a snowblower and I’m looking to fix the broken headlight before winter. Not sure if anybody knows of anybody selling one. I’ve been looking for a few months now. Thanks for any help.
    • ToroMan
      By ToroMan
      Good afternoon, looking for some help regarding a plow assembly for a 1999 520xi model # 73542.  I'm told that a traditional Wheel Horse plow assembly will not fit this tractor, that the xi series requires a special plow assembly.  Problem is, most of the people selling plow assemblies don't seem to know what they have, and I don't know what I need!  I have included the supposed model numbers pulled from the Toro website, including that of a retrofit kit, but I'm not sure what that retrofit kit does! Does it enable me to fit a traditional Wheel Horse plow to an xi model? Don't know.  One guy selling a plow knew what type of plow he had and told me it would not fit my tractor, stating "Lift link and handle are in the wrong locations."
      Any help would be greatly appreciated. Just need to know what the hell I'm looking for, which might help me find it!
      From Toro site:
      Model #: 79355
      48" Snow/Dozer Blade
      Model #: 95-4090
      48" Dozer Blade Retrofit Kit
      Thanks!!!
    • Berco
      By Berco
      I have a transaxle from a 518XI that i have as a spare. I would like to put some caps on the two open hydraulic lines, but i am having some hard time figuring out the thread and type to mate with the existing tubing. Does anyone know the specs for can point me to a fitting that will work? thanks!
