WVHillbilly520H
4x4 in the near future?
ACman
:naughty:... As long as it's not green and yellow :sleeping-drool:!...:lol:
  • Like 4
WVHillbilly520H
It's Daedong powered, same as my Kioti, which is Kioti's parent company so I'm hoping (if I get it) that by owning the Kioti for 4+ years now and no major mechanical/engine problems, I should be fine especially with a 7 year warranty as long as I do my part, and in the end it's just a glorified 4x4 "lawn & garden" tractor, all cast iron front and rear axles, it's smaller than my Kioti ck20 but bigger than the xi's (true sub compact with true cat 1 3pt), but with 2+ acres of my lot mostly steep slopes I believe it would do me better in the mowing season while keeping a couple horses for snow and mowing right around the house, maybe by tax time? We shall see,Jeff.
shallowwatersailor
Jeff, are you going to spring for the hard cab version? :occasion-snowman:  It looks pretty nice compared to the soft cab. It is $4K more - but considering the OTC cab for the 5xi is now $1K new  :-o that is not bad.
WVHillbilly520H
John, I had them quoted out from 22hp gear to the 25hp hydro hard cab model that came (with all the goodies I wanted) in at $28k, I can't do that, then to use it as I intend the hard cab just isn't practical for me, I'm looking into a left over model that's been sitting longer than the dealer likes, so it was offered at "invoice" till it's gone, tractor mmm FEL definitely and hydraulic front blade maybe for now, then as I pay it down add cab tiller ect,Jeff.
shallowwatersailor
Jeff, is that the dealer in Fishersvile? Sounds like a plan!
WVHillbilly520H
John, yes it is ,10 mins from the house and we had a good talk about TORO Wheel Horse with the Daihatsu diesel engine (he likes them) and the Simplicity/Massey Ferguson as well and all kinds of tractors of old, even if I don't get the 4x4 I have a new friend and place to go "hang out" if I need help otherwise,Jeff.
Razkid
Looks like a nice setup Jeff! I couldn't justify a hard cab for my Kubota but did get the fiberglass top for sun protection. I figured I could buy a few more goodies for the price of the hard cab. When I got the snowblower I took that top off, made a tube frame that bolts to the loader frame and bolted a piece of plywood between the tube frame and the ROP. The soft cab fits over that. I've never put the fiberglass top back on.
Have you looked at a Kubota BX series tractor?
WVHillbilly520H
Razkid, I have looked at quite a few, Kioti was at the top of my list because of the ck20, Kubota, Massey Ferguson, TYM, LS, Branson,Yanmar and even JD then went to a fellow I know who has worked at a few different dealerships and opened his own place(just used equipment/repairs for now) and in his "unbiased" opinion value vs price vs reliability ect on the subcompacts ,Mahindra/Kubota topped his list then Massey/Kioti/TYM/Branson/Yanmar/LS/JD in no particular order, Kioti better in the ck line up vs their SCUTs, Massey was good but $ ,JD has support but have to watch the transaxle and $, the rest hit and miss was his thoughts, then when I drove the Mahindra it was wider/ seemed more planted on a slope, and invoice price on that particular tractor, plus the guy I was dealing with we just clicked plus the Deadong(Kioti) engine and the front blade option ,7 year warranty and it's RED :bow-blue:...Jeff.
  • Like 4
Razkid
You've definitely done your homework on this purchase Jeff! May I be the first to congratulate your upcoming purchase of your new toy.....I mean much needed piece of equipment!
WVHillbilly520H
Unfortunately I have to clear some of the :wh: herd :no:but to get that new toy and keep the "boss" happy, I suppose I'll have to comply then hope the eMax is still available :sad-bored:...unless you guys want to hide a couple for me :violence-blades:till things cool down...:laughing-rofl:...Jeff.
Razkid
I'm sure there are a few places near you that would be good hiding places! Does the "Boss" know exactly how many you have? If not, tell her you already got rid of a few to make room. If I was closer I'd foster a few for you until the dust settles! :D
  • Like 3
T-Mo
When I retire I might get me a small 4x4 SCUT.  It probably will be a John Deere 1-Series or maybe a Kubota BX.  I have a dealer for each close by.  There isn't a Mahindra dealer, nor a Kioti dealer close by, so those are pretty much ruled out.  I don't see anything in the New Holland nor the Case IH lineup that interests me enough to want one of those brands.
WVHillbilly520H
@T-Mo, I really don't have anything against JD, the older ?50-?70 series (sub)compacts were very good solid capable little tractors, cast iron and steel, the 1R (of my knowledge) cast aluminum rearends? and plastic body panels and the Kubota has plastic also but cast iron rear, the Mahindra is a compilation of several different brands under one,some have Daedong some Mitsubishi engines ect, they also have TYM,Branson,LS under their umbrella as well,so whether I'm making a wise decision or mistake,time will tell, when I bought the 520H anniversary new JD and CC was expected to do better last longer but I believe I made the right choice there, so all things being realative, THEY ALL should last a very long time if properly taken care of ,and with good dealer support where JD/Kubota usually does,Jeff.
WVHillbilly520H
Went back by the Mahindra dealer today to check a few more things and told him he would need to throw some "swag" in to sweeten up the deal so he showed me this T-shirt that work just as well for us :wh: fans too, maybe Terry or Glenn could run with this,Jeff.
WVHillbilly520H
The old saying "you snooze you loose" really came through today as I got an email from the Mahindra dealer, another customer came in today and committed to buy the one I was "slowly" dealing on (as I hadn't put a deposit on it in it was fair game) eMax 22 Gear at invoice, was working on a deal to thin my herd before committing myself to buy the new 4x4 but that stalled, anyways if we're to order another one in like that it'll cost me $4k more guess I'll be mowing and blowing with good ole :wh:s a while bit longer ,not a bad thing but a bit of a disappointment :( was kinda looking forward to a do it all little tractor for here reckon I'll have to get a bigger trailer and tote the Kioti back and forth ,Jeff.
JAinVA
Bummer Jeff.I know the area of the state you live in and a 4x4 tractor would be of great use.I would suspect that the Mahindra of this age are the Kubotas of the past.You had problems getting parts for the Kubotaswhen they first started selling here.The Mahindras may have had the same issues as well but seem to be well built quality machines.A good friend was looking for a midsized tractor for his business 15 years ago and he and I looked at every model from every manufacturer.New Holland,Massey Fergusen,JD and Kubota.He went with the Kubota and he still works it today.Hope you get what you need.Luck,JAinVA
Edited by JAinVA
JERSEYHAWG /  Glenn
Sorry to hear that Jeff, I know when you have your mind set on something and it falls apart. But there will be another deal come your way.
Glenn
WVHillbilly520H
Thanks guys maybe it was for the best, really like the hydro it has an independent PTO with the gear drive when you clutched it the PTO would shut down till it you released it I was thinking cheap (saving $ vs exactly what I wanted) so maybe after I get a couple projects caught up and things paid for I'll look in to again, plus I do have the Kioti a bit over kill for lawn mowing but it does have the loader and 4x4,Jeff.
WVHillbilly520H
Update, as fate would have it, after I found the Dxi Daihatsu engine to be more than expected the Mahindra dealer gave me a ring and the guy who had "committed" to buy backed out, so I got my chance again and I didn't wait around so now I'm an owner of what TORO should have built as the Xi series, anyways here it is compared to the 520xi I still have as not long after the eMax showed up the Dxi left for another home, Jeff.
  • Like 8
JERSEYHAWG /  Glenn
Jeff, best of luck, what a nice machine.
Glenn
WVHillbilly520H
Glenn
Thanks, just hope it's as reliable as long a Wheel Horse ,Jeff.
WVHillbilly520H
Well I got a couple (toys) attachments a 3pt quick hitch from HF for mounting the new 5' Dirt Dog rear scraper blade (not only does it angle left/right forward/rear facing but tilts for pulling side ditches or crowning driveways and can be offset father left or right of center) for the the new (toy) eMax and been putting that FEL to use filling some low spots in the yard and remove last year's weeds and leaves, Jeff.
slim67
My employer got a Mahindra 4540 two years ago and its been fine. Supposedly Mahindra is the largest manufacturer of tractors in the world. Ours is a hi-lo range trans instead of a hydro.It came down to that or a Kioti. They do make a nice compact though.
WVHillbilly520H
I have a Kioti CK20 gear drive with FEL in WV at my parents' place I bought used about 4 years ago just too big to mow with and tote back and forth, this is the eMax 22 gear drive with the Daedong(Kioti engine), not much bigger than the Xi's, so far I'm happy with it even without the hydro, Jeff.
  • Similar Content
    • CS-17
      By CS-17
      Sold!!!
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • PWL216
      By PWL216
      About a year ago I bought a C-121 auto with the intention of using it as my go-to mower. Shortly thereafter I got a great deal on a low hour 314-8.  It ran perfect and had several attachments - it became my new go-to mower.  So, I decided to repurpose the 121 to be a front end loader. After purchasing the build plans from P.F Engineering (which are excellent), I realized I couldn’t build it for less than $2k in material. I decided to look for a used one and found a Thompson TC10 local to me, mounted on an “end of life” 1077, for $1,000.  The loader swap itself was pretty straight forward. The only modifications needed were drilling a couple of mounting holes in the tractor frame, grinding away a little of the loader top frame so the hood opened/closed and welding in a new hydraulic pump mount. I have a few things to button up still and the bucket itself needs attention but it’s fully functional. I also bought a pair of clamp-on pallet forks.
      I also did a “refresh” of the 121. The total project cost is shown below. Roughly $2,300, with just the FEL itself being around $1,300.
      Tractor
      C-121 Auto $500
      Solid engine mounts $50
      Front End Loader
      Johnson 10TC $1,000
      Hydraulic fluid $35
      Spare hydraulic hose $40
      Ignition
      Battery $35
      Battery cables $20
      Points & Condenser $20
      Fuel
      Carb & Gasket $65
      Electric fuel pump $60 (later removed)
      Air filter $10
      Fuel filter $15
      Fuel line $10
      Spark plug $5
      Decals and Paint
      Decals $115
      Paint $30
      Lights
      Headlight Lens $45
      LED Headlights $25
      Rear lights $25
      Misc $200
