Similar Content
By JoeM
Good Toro XI Lift Valve and Cylinder Assy.
Hurry this deal won't last! $60 Plus shipping.
By Jrodgers04
Selling a nice deck for the 5xi line. Starting it at $500 on FB Marketplace, open to offers.
Model Number: 78395
Good shape, ready to put to work. Does not include pulley box.
Recently sold the tractor. Was going to make a coffee table out of it but the wife is not interested.
Overall good operating condition. Cuts well, spindles, pulleys, rollers, and wheels are in good shape. Deck is solid, no rot. Very heavy duty, weighs over 300lbs. The only piece not functional is the install wheel. This does not affect the operation of the deck, just installation/removal.
Located in Beverly, MA. Delivery available for right price.
Video is from a week ago.
My Movie.mp4 -
By Berco
Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
By gfullz
Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
By GEnd
Hi all,
New to the group and hoping to tap into your knowledge. Also hoping I'm posting in the right place. Please excuse me if not.
I live in NE Minnesota, and am looking for a WH tractor for mowing and snowblowing.
I have a couple of questions I'd like your opinion/knowledge on, mostly about snow blowers and steering:
Did all 520H/C models after 1991 have gear reduction steering? How do I know if a machine has gear reduction or not?
Do the newer xi series have gear reduction? I think the 520/2/3xi offered power steering as an option, but do non-power steering models incorporate gear reduction?
I'm leaning toward 2 stage blower, just because it seems heavier duty, and it snows a ton in NE MN. Are the 2 stage units worthwhile?
I was lucky enough to work for Toro for a few years, and really want to find a red machine. Lots of green around here, but hoping to stay RED. Thanks for your help.
Greg
