Brad764
Hello everyone, I am new to the site and new to wheel horse. We just moved into a house with a large yard and I found a Wheel Horse B-165 with mower deck for the cost of renting a trailer and hauling it home. It had been sitting in t garage for many years and the fuel system had not been cleaned out. I have it running on propane with a high pressure regulator and a copper pipe running into the carb. (nothing that cannot be easily reversed). I have been looking for a snow blower for this tractor to use this winter , but I haven't seen anything anywhere near Jericho VT, Has anyone else adapted any other blowers from other manufacturers to work on the B-165? Any ideas or suggestions would be welcome.
Walt
Well come to Red Square. I have not worked with other brands but I'm sure you will get plenty of advice from other members.
I am currently doing modifications on a blower for a vertical shaft powered Wheel Horse snow thrower to work on my horizontal shaft pto.
wallfish
:WRS: Brad
That's what Brad needs, a blower for a vertical shaft powered tractor.
Walt
5 hours ago, wallfish said:
:WRS: Brad
Sorry already cut the shaft and inner bearing mount, and moved mount to location for supporting new shaft I'm making.
Brad764
I think as long as I can attach it to the frame I should be able to use an appropriate belt to run the blower, I guess I could even rotate the belt mid way if it has a vertically oriented fully on the blower. Any thoughts?
wallfish
There's a vertical shaft blower for sale in Williston VT on CL. Right near you.
Bet you can get it cheaper than advertised and it would be much easier to modify to fit on that B165 than any horizontal blower would be.
  • Similar Content
    • Evguy
      By Evguy
      Price reduction!
      B100 8 speed and short chute snowblower for sale near Indianapolis Indiana.
      good deck and tires, kohler engine runs.
      transmission needs axle seals and bearing.
      needs steering wheel also.
      too many projects, not enough room.
    • FarmallFarmer09
      By FarmallFarmer09
      I recently purchased my first wheel horse with a number of new attachments, And included in that bundle was a Wheel Horse snow blower. I would love to use it, But as it seems, Its missing a few key components to use it. Its missing the 2 side caster wheels, Along with the lift rod. does anyone know where i could potentially pick up either of these things?
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • blu_stang
      By blu_stang
      Hi All, It's time for me to sell the D-250 I've had for the last 8 years.  It’s useable as is, or would be a great project bundle for further restoration.
      I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains.  Also included is an extensive part collection, nearly a second tractor worth.  I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine.  I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
      Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts.  There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
      The tractor engine runs smooth.  There are around 1050 original hours on it; It’s a 1976 edition.  Everything works, except the dash lights and the rear lights (disconnected b/c of fender).  I just haven't sorted out the wiring, but it is all there.  Headlights are good and working, as are all of the gears and levers.  The four tires are nearly new Carlisle Multi Trac, with nubs still on them.  The rear tires have been filled (ballasted) with Rim Guard for extra traction.  The hydraulic pump, front PTO clutch and brakes operate but could use a tune up.  I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat.  The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings.  The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows.  The rear fender needs a repair, but all pieces are available.  The plow and tiller are due for restoration.  The Points, Condenser and rotor have all been replaced and tuned in.  The battery is good.  I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours.  The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
      Here's a video of me mowing, this past summer.
      Transporting this haul in one trip will require a pickup truck and a large trailer.
