Cameron670
got #4 today
Cameron670
So far I have run it about a half hour. Power steering was cool......at first.....then when I began mowing,  I realized it is not "tight".   It doesn't hold a straight line.... Anyway.   52" deck 800 hrs.  The purpose of this post is the next question.
           the hydro is jerky & odd at low speeds.......lunges & bucks constantly.  At mowing speed, no trouble.  I would not do forward and reverse work with anyone watching.. It would be embarasing. The previous owner changed the hydro filter, (toro brand)..... Deck lift is crisp and fast. Nothing is getting abnormally warm. (also have a 520xi).    I will post pics a little later.   I have tried to research these symptoms earlier today, but couldn't find much. Probably wrong search words. I am sure there are a number of  (clears throat....) "words"  used to discuss this topic.  I plan on taking the seat, tank, and tin off, to clean it early next week. Trying to poll the audience to get a game plan.   Overall, got a fair deal.
KJC
KC9KAS
So tell me....what model tractor you talking about?
elliot ness
Pics and what is it?:icecream:
ztnoo
We would rather be overwhelmed with model info by an owner, that left scratching our heads and speculating over vague descriptions.
We're a picky bunch about that sort of stuff....... ;-)
"got #4 today" tells us zero, zip, nada...............
Edited by ztnoo
Cameron670
522xi..........................look in the little tag thinger.....    22 HP Kohler OHV twin
ztnoo
Ah yes, the language mysteries continue..........
Racinbob
I'm not familiar with that series or hydro trannys but the first thing I'd do is flush out the fluids and refill with the specified amount. Get everything adjusted according to the manual and see what that does for it. :)
ztnoo
OK....I know I'm probably the Bad Guy here for somewhat harassing your initial, and subsequent statements.
All I'm going to add is: if you have a question, ask it in such a way it doesn't unnecessarily create questions about what you really mean.
I.E.   .......................don't be cute and evasive.
Don't talk about "tags" when you get asked about what model you are referring to.
Just say what you have.
Comprendo???
It really isn't that difficult.....
If you are more straightforward, you'll begin to really unearth the treasure of info here at RS.
Regards,
Steve
Cameron670
Comprendo???
Regards,
Steve
Steve,
Wasn't trying to be cute or evasive..(deep sigh)....Short & direct, definitely.....I don't like to waste others time.  My original question is posted clearly in the second paragraph of my original post.
            Furthermore,  I asked a very similar & direct question in the transmission section, with zero helpful responses.
     It is difficult to convey "tone of voice" in situations such as this.  The condescending nature of our first interaction is noted.
KJC
fatboycowen
I hope you find a solution, and I'm curious what the problem is.
Google bucking or jerky hydrostatic transmission, and you will get lots of people having similar problems with other transmissions. So, it may not be unique to the xi. Maybe you can find a solution that way.
  • Similar Content
    • Jrodgers04
      By Jrodgers04
      Selling a nice deck for the 5xi line. Starting it at $500 on FB Marketplace, open to offers.
      Model Number: 78395
      Good shape, ready to put to work. Does not include pulley box.
      Recently sold the tractor. Was going to make a coffee table out of it but the wife is not interested.
      Overall good operating condition. Cuts well, spindles, pulleys, rollers, and wheels are in good shape. Deck is solid, no rot. Very heavy duty, weighs over 300lbs. The only piece not functional is the install wheel. This does not affect the operation of the deck, just installation/removal.
      Located in Beverly, MA. Delivery available for right price.
      Video is from a week ago.
      My Movie.mp4
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • gfullz
      By gfullz
      Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
      so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
    • Berco
      By Berco
      I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
    • katanski
      By katanski
      Can someone tell me how long is the drive belt from the engine to the mower deck is? 522xi with a 52" side discharge mower deck.
