mmmmmdonuts
Raider 12 axle leaking
mmmmmdonuts
Alright running into two small problems but I think I may have identified the location and reason why the leak was there in the first place. First problem I am having is removing the axle gear from the shaft. I don't want to break it but which way does it come on or off the shaft? The location right at the end of the shaft where the C Clip was seems to be raised relative to the other sections. Is that the way it comes off?
Also, it looks like where the axle was leaking was missing a few of the needle bearings in the axle. How easy are these to pop in and is there any special technique to do it? Was probably going to go to ace hardware/ tractor supply to find the 1-1/8 needle bearings. Any part number to find them or does it have to be from wheel horse? (I assume p/n 1526) Thanks.
stevasaurus
Bob. if you have not seen it, here is the thread I did with videos for the #5060 transmission.  :)
http://www.wheelhorseforum.com/topic/49386-6-speed-5060-10-pinion-ls-trans-rebuild/
Be sure to put new nuts on those differential bolts.  The bearing you want is #1526...crosses to KOYO or Torrington # B1816.  NAPA may have it, but I bet they will have to order it for you...same for Motion Industries.   Use a good punch, or arbor to tap out the bearing by working your way around.   That axle gear should come off the splin end of that axle.  File it a little if you have to.  :)
Edited by stevasaurus
mmmmmdonuts
Thank you for the help. I watched the videos you did and you did an excellent job. That's how I have gotten this far thus far. I must of missed some of the parts about this stuff. I will see what I can get done.
mmmmmdonuts
Just wanted to do a little follow up. I completed the teardown and clean up and I put it back together. Believe it or not part of my biggest issue at the end was receiving wrong axle seals. I got a ball bearing in my SKF6105 seal and the seal that goes on the axle one of them was a 1/8 ID seal, but the other axle one was correct.
One last question. Is the input pulley mounted the correct way or should it of been reversed?
Everything is spinning in all gears and looks great. Now just have to mount it on the tractor. Hopefully today. Thank you everyone for all your help.
stevasaurus
Transmission looks great.  I think the pulley is OK...take a look at it when you put the belt on...everything should be in line.  It looks like the input shaft is not flush with the outside on the input pulley though.  Was it like that when you took it apart??    :)
mmmmmdonuts
That's what I am trying to figure out. I honestly don't remember. I took a few pictures but none of them show how it was seated. I found it weird as well that the pulley is a lot wider than the actual shaft. I guess I will find out when I try and connect the axle. I might just reverse it quickly to see how it sits that way, because the one side seems much flatter than the other side of the pulley (the outside of the pulley, the way I currently have it.
Edited by mmmmmdonuts
diamondred
On 6/5/2015, 4:47:04, mmmmmdonuts said:
Sorry for the confusion. I meant I got the oil seal shipped to my house. I did not get it onto the tractor yet. Sorry for the confusion. I am just going to get the grinder going and see what I can do.
Always be careful of the gas fumes if nothing else.
stevasaurus
I think you would have noticed it when you took it apart...it is the same input gear right??  I went back and looked at your earlier photos...every angle except the one we need.  It is the right pulley...something is not right.  What does it look like when you turn it??  :)  I don't think I would put it on the horse until you figure it out.  Does the hi/low shifter work??  Just asking.  :eusa-think:
diamondred
I hope that either the needle bearings worked their way outward and not inward. And if they did, that you found all of them. I had a 8spd eat itself up because there was needle bearings inside of the the transaxle. But get this, I looked at EVERY bearing in that transmission, and not one bearing was missing any. I have a feeling it happened at the factory during installation of one of the bearings that went wrong and they never retrieved the 8 loose needles.
mmmmmdonuts
I found all the needles. It was completely blown out and scrubbed out after I removed the needle bearings and replaced them. That stinks it came from the factory like that. I have seen that happen before at work with screws shorting electronics out.
I reversed the pulley. It now sits flush against the case, but the input shaft is still probably 3/8" from the end of the pulley. The whole input shaft extends out probably 1-1/2" out of the case. The high low gear seems to work. It stops in both positions and the wheels rotate at different rates on the same gear (2nd gear/ on both high and low). I can take a picture of the two positions of the high/low gear. When I took apart the case I never really changed the position of that shaft, since the shifting was very smooth as it was. The input pulley lines up with the rest of the tractor pulley's when it is seated this way. Basically is it a concern that the shaft does not extend out the length of the pulley?
Added photos
stevasaurus
3/8" isn't as bad as it looked.  I think flipping that pulley was the right thing to do.  If it shifts and turns freely, I would think you are OK...put it together and go for a ride.  :)
mmmmmdonuts
Alright. Thanks for the advice. It looked really off to me and once I flipped it, it looked quite a bit better. Hopefully I will be taking it for a ride sometime tomorrow. (Or at least that's the goal)
stevasaurus
We want pictures of riding around.  :)
mmmmmdonuts
Got it mounted but am 1 bolt short in the front. I am going to have to run out and get a 3/8-16 bolt sometime tonight. I did have one more question and it is regarding the parking brake. I never had it working before and I really would like to get it working this time around. From what I remember it would go down, it would just never stay engaged. Thoughts? Definitely will post some pictures riding around.
stevasaurus
You probably have this, but if you don't, download the 3rd PDF...it shows and explains the parking brake and how to adjust it.  Good pictures.  :)
http://www.wheelhorseforum.com/files/file/1830-tractor-1968-raider-12-late-production-da-om-ipl-wiring-snpdf/
mmmmmdonuts
Just wanted to thank everyone for all the help. Finally got it all back together. Got a new drive belt because the other one was stretched really bad. Got new tires for the rear as one tire was not holding any air and when I brought it to the mechanic to patch it and he laughed at me because they were both so far dry rotted, and destroyed.
Took it for a ride about an hour ago before it got to dark and the only thing I got to further adjust is the brake. It is way to loose for my taste, but the shifting was much smoother than before. Need to put my wheel weights on and the snowblower and it should be good when the snowflakes fly.
  • Similar Content
    • Row Cropper
      By Row Cropper
      I have been buying and selling Wheel Horse equipment since 1980.  I have moved to a retirement home and closed my shop!  Over the course of years I have accumulated significant WH parts and pieces which still have value to the right people!   The good stuff includes, 4 or 5 mule drives, a front axle off a C-120, PTO clutch parts, deck hardware from various decks,  a hood, wheels, etc.  I have several additional items and just want to get them into the hands of a WH guy who knows what they are for!   Asking $300 for the lot!   Come take a look and see for yourself the value in this offering!!!!!   Photos below show examples of Mule drive and type hood I have.
    • AndyZ
      By AndyZ
      Operator manual #A-5274
      Wiring
      6 pages 7.31MB
      Illustrated parts list link
      Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
      For 1970 electric clutch use Electro 12 model 1-7255
      2 pages 282KB
      We also have the 1971 tractor parts manual that followed
      1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
      1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
    • stevasaurus
      By stevasaurus
      I finally got a chance to rebuild a transmission with a hi/low mechanism.  This is a 6 speed #5060 transmission with the 10 pinion limited slip differential.  Notice the brake shaft comes out the hole closest to the axle housing.  The 8 speeds brake shaft comes out of the cluster shaft hole.  I did a series of videos for this thread along with some pictures.  The videos are split up between different phases of rebuilding...ie...the differential, the hi/low shift mechanism, the rest of the gears 1 & 2 (my batteries died in the camera).  Most of the information will be in the videos...be advised that I did some struggling while doing these videos and I left them as is because it is not always easy.    Hope this helps you guys.
      correction...
      According to the manual the bolts that hold the differential together are in backwards in the video.  The nuts should be on the input shaft side (right side) of the transmission.  Sorry, I missed that.
      Just got the trans split.  I use a 1" old wood chisel to start and then work the case apart with a pry bar.
      A couple shots after getting the case half off...trans is in neutral.
      The trans case works as a work bench for the differential...very cool
      Here is the reason the trans needed to be opened.  An axle gear lost it's teeth and the pieces were lodged in the pinions.
      Finished and back together.
      The rest are the videos...1st on is the differential...
      Next 2 are dealing with the hi/low mechanism...1st one taking apart and the 2nd on putting together...be nice...it was my first time.
      Now, 2 videos putting the rest of the trans together...batteries died just before I finished the first video.
      Thanks for looking
    • mmmmmdonuts
      By mmmmmdonuts
      My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
      Thoughts?
    • Ralpho711
      By Ralpho711
      I have a 1976 C-120, 8 speed, that has had a bad rear axle key way for about 35 years.The plastic steel we put in to keep things together finally gave up the ghost last year. I tried some welding but that hasn't held up either. My question is will the rear axles from a C-81 8 speed fit in my transmission? According to the parts lists I found on this site, both trans have 1 1/8" axles and 8 pinion diffs, but the axle part numbers are different.  Any help is greatly appreciated. I'm brand new to the site and think its great!
