![DaleLicht](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
C-165 Clutch Pedal takeoff and braking too suddenly
By
DaleLicht, in Transmissions and transaxles
Similar Content
By drewd
Hi All, I have a 71 or 72 Model # 101006, Serial # 790336. Model number chart says 71 but the paper for the engine has a print code 72. The closest I could find was for models 1-3745 & 1-3741.
Two questions. I finally need to replace the drive belt. This manual list the belt as # 1576.
Two questions:
1) Does anyone know what size that translates to? I do have the old belt but the inside edge is falling apart so it will measure a little longer than it should.
2) This tractor has the electric clutch. What is the best way to remove the belt?
As always...Thanks!
By Mike Compton
Hi there, sorry if this is a repeat question. Anyone have a pic or diagram of how to reassemble the pulleys / tensioner, and how to route the belt? One more...what are the 4 holes for at the rear of the seat deck (above the logo decal)?
Cheers,
Mike
By Reeferred
Need help,. 244-h model 72041 newer. The drive belt keeps coming off is it to lose, to tight? Any ideas would be great
By RJ Hamner
Its been a while since I was able to work on my 416-8 rebuilt and right now the few brain cells are having a tough time.
I am in the process of putting the wiring harness back in and the problem is the clutch safety switch.
The arm with the idler wheel that engages the switch is over ridding the switch arm.
I had tried adjusting the rod from the peddle to the arm but no matter my adjustment I still have the problem
I am kinda at my wits end on this one.
Any help will be greatly appreciated
Bob
By midpack
I had a drive belt let go on a 1980 C-175 Sundstrand hydro. After searching the manuals it looks like either an 83" or an 85 1/2" belt is called for.
Anyone know the right length off the top of their head?
Thanks
