Similar Content
By Berco
Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
By gfullz
Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
By Berco
I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
By katanski
Can someone tell me how long is the drive belt from the engine to the mower deck is? 522xi with a 52" side discharge mower deck.
By Berco
I have a transaxle from a 518XI that i have as a spare. I would like to put some caps on the two open hydraulic lines, but i am having some hard time figuring out the thread and type to mate with the existing tubing. Does anyone know the specs for can point me to a fitting that will work? thanks!
