72072 266-HE Snowthrower Attachment
By
nicholsoncw11, in Implements and Attachments
Similar Content
By FarmallFarmer09
I recently purchased my first wheel horse with a number of new attachments, And included in that bundle was a Wheel Horse snow blower. I would love to use it, But as it seems, Its missing a few key components to use it. Its missing the 2 side caster wheels, Along with the lift rod. does anyone know where i could potentially pick up either of these things?
By dave who poos
Hello!
I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
By blu_stang
Hi All, It's time for me to sell the D-250 I've had for the last 8 years. It’s useable as is, or would be a great project bundle for further restoration.
I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains. Also included is an extensive part collection, nearly a second tractor worth. I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine. I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts. There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
The tractor engine runs smooth. There are around 1050 original hours on it; It’s a 1976 edition. Everything works, except the dash lights and the rear lights (disconnected b/c of fender). I just haven't sorted out the wiring, but it is all there. Headlights are good and working, as are all of the gears and levers. The four tires are nearly new Carlisle Multi Trac, with nubs still on them. The rear tires have been filled (ballasted) with Rim Guard for extra traction. The hydraulic pump, front PTO clutch and brakes operate but could use a tune up. I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat. The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings. The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows. The rear fender needs a repair, but all pieces are available. The plow and tiller are due for restoration. The Points, Condenser and rotor have all been replaced and tuned in. The battery is good. I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours. The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
Here's a video of me mowing, this past summer.
Transporting this haul in one trip will require a pickup truck and a large trailer.
By mmmmmdonuts
Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
