AUTO 18 FEL CLUTCH TO ENGAGE ARK 550 WORN OUT?
By
wheelhorse-c-161-1979, in Implements and Attachments
Similar Content
By Fordiesel69
I need the large metal pulley that houses the needle bearing and ball bearing with the two grooves. The outer bearing seemingly wallowed out its hole and my welder guy cannot revive it.
Shipping to Erie PA. 16509.
By Southern_Secret
Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
I will post Pics as soon as I reinstate my membership
By the jeep driver
My daughter was using the Wheel Horse rider to mow, I was push mowing. She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving. I disengage the blades, and re-engage... nothing. No movement from the belt nor clutch. Then I notice the smell, and look closer, the belt is so hot is melting on the clutch. Or rather, the clutch is so hot it's melting the belt. Melting occurred.
While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
So, what did I do now? Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall. I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad. I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
Some pictures of the clutch, can anyone tell if it's usable from them?
By RJ Hamner
Its been a while since I was able to work on my 416-8 rebuilt and right now the few brain cells are having a tough time.
I am in the process of putting the wiring harness back in and the problem is the clutch safety switch.
The arm with the idler wheel that engages the switch is over ridding the switch arm.
I had tried adjusting the rod from the peddle to the arm but no matter my adjustment I still have the problem
I am kinda at my wits end on this one.
Any help will be greatly appreciated
Bob
By John A
The clutch spring on my 308-8 broke, so the tractor stopped dead. It was easy to see the broken red spring, after I removed the right rear wheel. I was able to order a replacement spring which I replaced today. Problem now there is too much slack on the drive belt. The tractor will move, but barely as if the drive belt is not tight and slipping. It seems that the clutch pulley isn't applying enough force against the belt. I have tried adjusting the clutch rod but that doesn't seem to make a difference. It only changes the position of the clutch pedal . I don't see any other adjustment option to put more pressure on the drive belt. The belt is old, but seems acceptable. Before the clutch spring, broke, the tractor would jump out in any gear. No slippage.
