zanepetty
k161 governor
zanepetty
This is stressing me out. Should I drill out the Welch plug? Put a hole n it and pull it out?
rmaynard
If you drill a hole, be careful not to go too deep. Just penetrate it. Punching would probably be safer so as not to get metal fragments.inside the block.
Edited by rmaynard
zanepetty
OK. Well if I can't penetrate the plug I guess it won't do me any good. I guess I could try to keep prying it out with a screw driver. Im just lost as to what to do.
zanepetty
I FINALLY got the plug out. What a pain. I don't see anything that would cause to jam? Anything in particular to look for while the plug is out as far as damage goes?
post-11334-0-43518500-1382920110_thumb.j
rmaynard
PM sent
zanepetty
Is there a good way to check to see if everything is alright in there? I took the retaking screw out so I want to make sure everything is in its right place. Also I had to drill a hole in the Welch plug. I tried my best to b clean about it. Do I need to drain the oil?
JimmyJam
Sorry, but the pic you posted is poor, so we can't see what we are looking at. As Bob has mentioned the retaining screw is nothing more than to secure the governor adjustment "position" on the outside. Looking into the welch plug, you should be able to see the cross shaft and tab. I would recommend replacing oil prior to firing it up again.
zanepetty
I'll take another picture then. That one does look poor. If I post it later tonight could one of u gents take a look?
  • Similar Content
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
