Followers
0
4on4 Bolt Hub Front Wheel Conversion
By
70sVintageTrikes, in Wheel Horse Tractors
Similar Content
By Keaton
i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
By CasualObserver
Operator manual
Illustrated parts list
6 pages 3.73MB
Illustrated parts list #A-7136
Includes PSB #023 #052 #058 #060 #080
10 pages 938.48KB
Engines used according to Toro
Clinton B1290-1107
Kohler K91-31307A
Kohler K91-31388A
Electric start kit
Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
6-12 tire chains model TC-12 - Listed for 1958 and 1959
Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
Details & Attachments
2 pages 107.33KB
1958 model RJ-58
1958 serial numbers that have shown up for the RJ-58
Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
00005
00251
01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
01188 - Has round rear wheel hubs
01516
01768
01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
01797
01871
02525
03177
03501 - Located in UK
03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
04883
04885
05000
05619
05714
05798
06528 - May be 16528
06749
06771
07633
07649 - Transmission J12-8 October 12, 1958
07725
08440
08612
09284
09337 - Hard to read
10163
11432
11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
11916
12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
12291
14473
14713
16097
16528 - May be 06528
166x6
16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
18348
June 2023
18500 and lower
Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
2 pages 106.94KB
1959 model RJ-59
1959 serial numbers that have shown up for the RJ-59
Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
18501 and up - Possible 1100 units built
20078 - Located in UK
203xx
21033
292xx
21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
K91T-31388A Serial 425251 found on RJ-59
By clip
Wheel Horse RJ-58 with RMR-32 deck and a slot hitch cultivator for sale. I got this cleaned up, motor swapped from a giant old 3hp Briggs (got rid of the spacers the previous owner had under the hood) and rebuilt the mower deck with new bearings, bearing blocks and gear covers, found two sets of NOS blade tips, mowed the yard five or six times and it's ready to go to a new home. Found that the model/serial were hand-stamped on the frame alongside the tag. Weld-repaired some cracks on the RMR-32 and the slot hitch. I don't have the room or time to do a proper restoration. As it sits, it's a solid mowing machine that's ready to work for another 50 years.
The good:
Great running Predator 212cc, trimmed airbox and routed exhaust to work with hood
Cleaned gas tank and new gas line/filter
New shifter boot
New belts
Fresh grease in all fittings
Flushed and fresh gear lube in transmission
New bearings in RMR-32 spindles
New bearing blocks for RMR-32 driveshaft
Solid deck, very few if any rust spots
NOS hi-lift blade tips less than a season old
Additional set of NOS hi-lift blade tips
Smooth-shifting transmission
Original BFGoodrich/Firestone tires
Tag/serial number still attached to frame
Cultivator has been freed up and adjusts properly
The not good:
Weld-repaired front wheels
Rear tire inner sidewalls starting to peel
Hood has a few extra holes cut in
No belt guards
Right rear hub had a bolt driven into the key slot and stripped the threads - I removed it and cleaned up the keyslot, added another threaded hole and put a set screw and fresh key in. The hub has been shimmed on the shaft with brass stock to take up some slack left by the old bolt and shaft wallowing it out slightly.
By Vaughan32850
Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
Many thanks
By Jennifer
Husband wants some advice… lol. So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running! The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice??? It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky.. checked the gap and pull again… same thing over and over! Thanks in advance!
