JamesBe1
Cessna FEL Pump
JamesBe1
I have started cleaning up my FEL pump (it's pretty bad), and was disassembling everything today, and am stuck getting the pulley off. I found that it was held in place by a 4mm allen screw on the shaft collar. Got that out, and the pulley won't come off. Tried tapping it off with a hammer, soaking it in BP blaster, and it still won't budge.
Is there something I'm missing? Any ideas you have would be greatly appreciated.
Thanx,
James
B-8074
I had to cut mine off my cessna pump. Then I just took it to my local machine shop and they made a new one for it.
JamesBe1
Ouch! Just curious, where exactly did you cut it? I might consider cutting mine off (it's fairly rusty) if I can pick up a new one easily.
B-8074
I used a 4 1/2" grinder with an 1/8# cut off wheel and cut it in half. You won't be able to cut it completely to the shaft but can get it close. Then I cut around 1/2 the shaft making a few small cuts around the collar in pie shapes. Then used pliers to break off the pieces. Mine was real rusty also. I even tried to press it off in my arbor press. I picked up the pulley/shiver at tractor supply and the machine shop supplied the collar. Good luck
JamesBe1
Thanx B
Sounds like you had a heck of a time with yours.
I think I'll probably try prying and tapping it off this afternoon. Maybe try a little heat from a propane torch. That's about as far as I want to go. The pulley is not so bad that it has to come off. I figured that since I was stripping and repainting everything else, I might as well do this too. If I can't get it off, I'll just wire brush the heck out of it and clean everything up with mineral spirits before I repaint.
It would be nice to get the pulley off, but the effort may not be worth if for cosmetic purposes.
pfrederi
Have you tried a flange puller???
JamesBe1
Er, I have a flywheel pulling kit, but this particular pulley doesn't seem to have an open center. I looked around the internet for pics of flange pullers, but they come in various formats.
What would the flange puller I need look like assuming it is something that can pull a pulley with a closed center?
JamesBe1
My bad. It does not have a closed center on the pulley. I tried my gear puller and heat, and it still won't budge.
I think I am going to leave it in place and clean everything by hand before I paint it.
Thanx,
James
B-8074
It was a pain to get off. I needed to rebuild the pump that's why I needed it off.
JamesBe1
I don't think I will be able to get it off without destroying the pulley. From what I read around the interwebs, it's difficult to find the right pulley. Most people get something close and use a bushing.
Oh well, I just spent half the afternoon with several bottles of cleaners and brushes and rags and cleaned every little crevice that I could find. I guess I'll just add another coat of paint on top of all the rest. There was the original red coat, then someone painted everything blue, then a coat of red on top of that. Mine will be the fourth coat in places, lol.
I'm not looking to win any prizes, I just like to kinda do things right when I can. Sometimes, like now, the effort outweighs the benefit.
JamesBe1
As an extra, here are a couple of pics of the pump:
JamesBe1
OK, so I finally got it apart as much as possible with the exception of the pulley from the pump. I cleaned and repainted everything and installed new hardware. Here is the finished product:
See above for the before pictures.
coldone
Try the puller again. Tighten it as much as you are comfortable with, then whack the center screw with a hammer. The shock will help break it free. I had to pull the hub off my D200 axle that way. It took about 2 hours as It was only giving about 1/16 inch at a time.
JamesBe1
Thanx Coldone (you really need to sign your name for us my friend),
That's some darn good advice, but since it's all painted and put back together, I don't want to tear it all down again.
Besides, last time I started whacking things with a hammer:
I'm a little hammer-shy at the moment
j
coldone
Ouch! Looks like a job for JB and duct tape!
Britt
JamesBe1
Britt
Lol! Maybe even some supre-glue too.
I was thinking of using a j-hook, but since it is broken along the porting itself, I didn't want to take the chance. I found a used block that I am almost ready to reassemble.
I wonder if it's weldable?
Since then, I've been really shy about whacking things with hammers.
coldone
For cast iron welding you need to find an old welder, gray haired and hunch backed preferably. I am not a welder so take it for what it is. I have heard that cast can be welded and there are several methods. The one I think stands the most chance of working is to make a small bead and walk away, come back in an hour or two and make another small bead. Continue to do this until the entire weld is made.
I too am "whacking shy" but it does have it its uses. It has taken years of breaking things with hammers to teach me when and how to whack things. Gallagher was an amateur!
  • Similar Content
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • Nathan W
      By Nathan W
      Does this look factory for 1976
    • wh315-8
      By wh315-8
      Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
      Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
