sjoemie himself
Quickie: flotation wheelbarrow
sjoemie himself
Soo.. yet another idea that floated around in my head for way too long was to build a wheelbarrow with a 'big' wheel.
We're hauling horse manure from several places, some more muddy than others. When doing so with a 'normal' wheelbarrow the frontwheel tends to cut through the mud instead of rolling on top. My idea was to mount a single wide wheel to have more flotation so the wheelbarrow would be easier to push through the mud.
To start things of I convinced my SO to donate her wheelbarrow to the good cause.
This is what I started out with:
Solid, narrow, single wheel. Yes it is crooked because the bearings are gone.
More in next post.
sjoemie himself
Wanted to use as much of the old frame as possible. This again was the starting position.
Had this wheel laying around. Bought a couple of them a while back and this was a solo one. Perfect candidate for the wheelbarrow.
This is the difference between the two wheels.
That's not going to fit. So marking where the frame has to be cut to make room for the bigger wheel.
and then.. things escalated a bit.
ri702bill
Nothing wrong there! Good for another 10 years as is!
Did you consider going to two outboard wheels like a Contractor's Wheelbarrol? I converted mine that way - MUCH more stable on uneven ground.. Had to make up a new axle & spacers.
sjoemie himself
Cut most of the front half of the frame off. Welded some square tubing in it's place. Added some bracing. Made a new axle and brackets for said axle. Mounted a new innertube, twice, since I punctured it the first time round.. Repaired it, mounted it again. Gave it a quick sand, wipedown and rattlebomb paintjob and here it is: bigfoot wheelbarrow.
Side to side with a regular wheelbarrow.
Handles pretty well, bit heavier on the nose but that's okay.
Feel free to shoot me any questions or feedback.
Testing commences tomorrow.
Greetings from the Netherlands, Mark
  • Like 5
  • Excellent 2
sjoemie himself
10 minutes ago, ri702bill said:
two outboard wheels
We have one of those but I have'nt exactly became friends with that yet.
I find the steering a bit awkward. Stability, yes, no worry about tipping it on it's side in normal circumstances. Because it has a bigger load capacity than a normal wheelbarrow it doesn't perform very well in the mud.. two narrow wheels digging in making it hard to push or pull.
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our online store and reach out to us through there.
      Https://greystone-3d.square.site
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • Burnerman
      By Burnerman
      I’m building a lowered 300 series wheelhorse. So far it’s a combination of 3 scrap tractors.
      the frame, trans and tins are from a GT2500 anniversary special given to me by a neighbor with a trashed Briggs. The Kohler M12 is from a junkyard 312 that was roached. The parts tractor I’m using for the build was another older 312. I’ve got the k301 in the garage. The trans was toast. Both axles wallowed out keyways and 1 axle actually broken.
      Anyway! I needed a project and a toy to putt around the neighborhood. I couldn’t find any other posts on how to do the whole thing. I’m trying to keep it cheap using stuff I have on hand and looking as “stock but cooler” as possible. So here we go.
      I’ll update this as I go along.
