cafoose
520-HC 9 pin
cafoose
Does anyone know or any diagram available that shows the 9 pin on the 520 where each pin goes on the engine side? Looking for an actual picture of the pin showing the numbers so I can see which pin corresponds to which number on the actual connector. I have the demystification guide and wiring diagrams but they show the 9 pin in a straight line. @lynnmor @cleat @gwest_ca
Edited by cafoose
cafoose
This correct?
9    6    3
8    5    2
7    4    1
peter lena
@cafoose  just curious , ever think about  changing that  hot wire  routing issue ?  favoring hot engine discharge  zone ?  drive belt  guard , venting , its always there , pete
cafoose
 :text-thankyouyellow: Yes that's on the list just trying to determine where the wires go for my Vanguard swap.
squonk
I chopped that 9 pin right out of there. Used 2 4 flat trailer plug kits with long pigtails. Marked them "A" and "B" changed 1 wire at a time and documented what circuit when onto what pin in what connector. Move the whole thing to the other side of the tractor away from the heat.
sqrlgtr
demystify.pdf there is a good diagram in here somewhere toward bottom of pdf... i cant get link to work maybe someone else can get for ya.. Its in the manuals section on here
Edited by sqrlgtr
sqrlgtr
try this one
