cafoose 3,883 #1 Posted July 22 (edited) Does anyone know or any diagram available that shows the 9 pin on the 520 where each pin goes on the engine side? Looking for an actual picture of the pin showing the numbers so I can see which pin corresponds to which number on the actual connector. I have the demystification guide and wiring diagrams but they show the 9 pin in a straight line. @lynnmor @cleat @gwest_ca Edited July 22 by cafoose Share this post Link to post Share on other sites
cafoose 3,883 #2 Posted July 22 This correct? 9 6 3 8 5 2 7 4 1 Share this post Link to post Share on other sites
peter lena 10,125 #3 Posted July 22 @cafoose just curious , ever think about changing that hot wire routing issue ? favoring hot engine discharge zone ? drive belt guard , venting , its always there , pete 1 Share this post Link to post Share on other sites
cafoose 3,883 #4 Posted July 22 18 minutes ago, peter lena said: @cafoose just curious , ever think about changing that hot wire routing issue ? favoring hot engine discharge zone ? drive belt guard , venting , its always there , pete Yes that's on the list just trying to determine where the wires go for my Vanguard swap. 1 Share this post Link to post Share on other sites
squonk 48,427 #5 Posted July 22 I chopped that 9 pin right out of there. Used 2 4 flat trailer plug kits with long pigtails. Marked them "A" and "B" changed 1 wire at a time and documented what circuit when onto what pin in what connector. Move the whole thing to the other side of the tractor away from the heat. 3 1 Share this post Link to post Share on other sites
sqrlgtr 4,224 #6 Posted July 22 (edited) demystify.pdf there is a good diagram in here somewhere toward bottom of pdf... i cant get link to work maybe someone else can get for ya.. Its in the manuals section on here Edited July 22 by sqrlgtr 1 Share this post Link to post Share on other sites
cafoose 3,883 #8 Posted July 23 6 hours ago, sqrlgtr said: demystify.pdf there is a good diagram in here somewhere toward bottom of pdf... i cant get link to work maybe someone else can get for ya.. Its in the manuals section on here Got it already Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #9 Posted July 23 I do not know if they are the same but in the first model year 1988 the engine to tractor connector is numbered. Click on the fuzzy picture to see it. 1 Share this post Link to post Share on other sites
953 nut 70,648 #10 Posted July 24 On 7/22/2026 at 4:02 PM, cafoose said: just trying to determine where the wires go for my Vanguard swap. The 9 pin was an Onan thing. It offers no advantages unless you plan on doing frequent engine swaps. I would suggest you are much better off wireing the engine connections from scratch. The Onan is a battery ignition engine and the Vanguard is a magneto ignition so you will probably want to insert a "KILL RELAY" in the rewire. 1 Share this post Link to post Share on other sites
cafoose 3,883 #11 Posted July 24 (edited) 1 hour ago, 953 nut said: you will probably want to insert a "KILL RELAY" in the rewire. Thanks Richard I already consulted Grok AI and have a relay ordered coming here Tuesday Many cheap relays have inconsistent wire colors, so testing the pinouts yourself is the smart way. How to identify the terminals once you have the relay Standard 5-pin Bosch-style pin numbers (look on the bottom of the relay itself): 85 and 86 = Coil (the two that make it click) 30 = Common 87a = Normally Closed (this is the one we need for the kill) 87 = Normally Open (we leave this unused) Simple testing method (with a multimeter or just a 12 V battery) Find the coil (85 & 86) Put 12 V across any two of the small wires/pins. When you hear a solid click, those two are 85 and 86. It doesn’t matter which is which for our purpose. Find 30, 87a, and 87 With the relay not powered (no click): Continuity between 30 and 87a → that is the Normally Closed pair. Power the coil (make it click): Continuity switches to 30 and 87. Mark the wires Once you know: The wire that is always connected to 30 when the relay is off = 87a (Normally Closed) The common wire = 30 Final connections for your kill circuit Vanguard black kill wire → Relay terminal/wire 30 Relay 87a → Chassis ground One coil terminal (85 or 86) → “I” (Ignition) terminal on the 520 switch Other coil terminal → Chassis ground That’s it. Test by turning the key — engine should run in RUN and die in OFF. When the relay arrives, do the click-and-continuity test above and you’ll know exactly which wires to use, regardless of the colors. Let me know the results if you want a double-check. Edited July 24 by cafoose 1 Share this post Link to post Share on other sites
953 nut 70,648 #12 Posted July 24 9 hours ago, cafoose said: How to identify the terminals once you have the relay You will probably be best off buying a five pin relay socket from any good auto parts store. The relay will have the numbers cast into the base. 1 Share this post Link to post Share on other sites
lynnmor 9,081 #13 Posted July 26 Perhaps this might help. Be aware that colors aren't consistent over the years. 2 1 Share this post Link to post Share on other sites
lynnmor 9,081 #14 Posted July 26 On 7/24/2026 at 8:44 AM, 953 nut said: The 9 pin was an Onan thing. It offers no advantages unless you plan on doing frequent engine swaps. I would suggest you are much better off wireing the engine connections from scratch. The Onan is a battery ignition engine and the Vanguard is a magneto ignition so you will probably want to insert a "KILL RELAY" in the rewire. The 9 pin is a Wheel Horse thing, they wanted a plug and play wiring system so they came up with the 9 pin nonsense to allow attaching the headlights and tach along with engine needs. 2 1 Share this post Link to post Share on other sites
953 nut 70,648 #15 Posted July 26 8 hours ago, lynnmor said: The 9 pin is a Wheel Horse thing, they wanted a plug and play wiring system so they came up with the 9 pin nonsense to allow attaching the headlights and tach along with engine needs. I respectfully disagree, Kohler powered and Kawasaki powered Wheel Horses don't have 9 Pin connectors, they are an Onan thing. Share this post Link to post Share on other sites
lynnmor 9,081 #16 Posted July 27 2 hours ago, 953 nut said: I respectfully disagree, Kohler powered and Kawasaki powered Wheel Horses don't have 9 Pin connectors, they are an Onan thing. Do you really think that Onan sold engines with headlight wiring? Wheel Horse may have had Onan install wires a certain way. Perhaps the other engine brands didn’t want to deal with wiring that belongs in a radio. 1 Share this post Link to post Share on other sites
953 nut 70,648 #17 Posted July 27 9 hours ago, lynnmor said: Do you really think that Onan sold engines with headlight wiring? Wheel Horse may have had Onan install wires a certain way. Perhaps the other engine brands didn’t want to deal with wiring that belongs in a radio. OK, I will play your silly game. The first wiring diagram is from a 1997 KOHLER powered Wheel Horse, please show me the Nine Pin Connector. The second wiring diagram is from a 1997 ONAN powered Wheel Horse, not all of the pins in the nine pin connector were used by Wheel Horse. The third drawing is from a Kawasaki powered Wheel Horse, please show me the nine pin connector. Share this post Link to post Share on other sites
pfrederi 21,342 #18 Posted July 27 Ideal design is when nothing needs to be added and nothing can be taken away. To me a garden tractor does not need 9 circuits. 2 1 Share this post Link to post Share on other sites
lynnmor 9,081 #19 Posted July 27 2 hours ago, 953 nut said: OK, I will play your silly game. The first wiring diagram is from a 1997 KOHLER powered Wheel Horse, please show me the Nine Pin Connector. The second wiring diagram is from a 1997 ONAN powered Wheel Horse, not all of the pins in the nine pin connector were used by Wheel Horse. The third drawing is from a Kawasaki powered Wheel Horse, please show me the nine pin connector. I’m not playing a silly game, I just don’t have so much hate for Onan that I need to place blame on them for things created by Wheel Horse. 1 Share this post Link to post Share on other sites
squonk 48,427 #20 Posted July 27 2 hours ago, pfrederi said: Ideal design is when nothing needs to be added and nothing can be taken away. To me a garden tractor does not need 9 circuits. Ignition, charging and lights. That's it! 1 1 Share this post Link to post Share on other sites
953 nut 70,648 #21 Posted July 27 (edited) 15 hours ago, lynnmor said: 18 hours ago, 953 nut said: I respectfully disagree, Kohler powered and Kawasaki powered Wheel Horses don't have 9 Pin connectors, they are an Onan thing. Do you really think that Onan sold engines with headlight wiring? Wheel Horse may have had Onan install wires a certain way. Perhaps the other engine brands didn’t want to deal with wiring that belongs in a radio. 3 hours ago, lynnmor said: I’m not playing a silly game, I just don’t have so much hate for Onan that I need to place blame on them for things created by Wheel Horse. I do not HATE Onan, I do strongly dislike misinformation. A substantial number of wiring problems that members bring to the forum are directly related to the 9 pin connector and I wish that Wheel Horse had used their own wiring harness rather than adapting it to Onan's. The website I have linked to the Onan 9 Pin doesn't mention Wheel Horse so I seriously doubt that it is a Wheel Horse thing. https://www.smallenginesprodealer.com/part-onan-323-1846-06/?srsltid=AfmBOooBu4-JjyTeEvq3yVuhZIbteH_HDZ1Bq0Q9JZCRyAk1IndKoX16 The ONON 9 Pin had an extra slot available and Wheel Horse used it for the headlight connection, so be it. My objective when responding to @cafoose was to point out the differences in wiring the two engines and that the 9 pin has its shortcomings. If you want to go through life thinking Wheel Horse invented the 9 pin rather than ONAN, that is fine. If you want to convince me that Wheel Horse developed the 9 pin connector please show me your research. Edited July 27 by 953 nut Add link Share this post Link to post Share on other sites
cafoose 3,883 #22 Posted July 27 This it? https://yakimagenerator.com/product/onan-338-3490-02/ Share this post Link to post Share on other sites
cafoose 3,883 #23 Posted July 28 Got the relay today, wired it up and it works great just like it should Also wired up the oil pressure switch and the lights pigtail. All that's left is the tach wire in the 9 pin. Would be cool if I could get the tach working. Any ideas? 1 Share this post Link to post Share on other sites
