cafoose
520-HC 9 pin
cafoose
Does anyone know or any diagram available that shows the 9 pin on the 520 where each pin goes on the engine side? Looking for an actual picture of the pin showing the numbers so I can see which pin corresponds to which number on the actual connector. I have the demystification guide and wiring diagrams but they show the 9 pin in a straight line. @lynnmor @cleat @gwest_ca
Edited by cafoose
cafoose
This correct?
9    6    3
8    5    2
7    4    1
peter lena
@cafoose  just curious , ever think about  changing that  hot wire  routing issue ?  favoring hot engine discharge  zone ?  drive belt  guard , venting , its always there , pete
cafoose
 :text-thankyouyellow: Yes that's on the list just trying to determine where the wires go for my Vanguard swap.
squonk
I chopped that 9 pin right out of there. Used 2 4 flat trailer plug kits with long pigtails. Marked them "A" and "B" changed 1 wire at a time and documented what circuit when onto what pin in what connector. Move the whole thing to the other side of the tractor away from the heat.
sqrlgtr
demystify.pdf there is a good diagram in here somewhere toward bottom of pdf... i cant get link to work maybe someone else can get for ya.. Its in the manuals section on here
Edited by sqrlgtr
sqrlgtr
try this one
cafoose
Got it already :handgestures-thumbupright:
gwest_ca
I do not know if they are the same but in the first model year 1988 the engine to tractor connector is numbered. Click on the fuzzy picture to see it.
953 nut
The 9 pin was an Onan  thing. It offers no advantages unless you plan on doing frequent engine swaps. I would suggest you are much better off wireing the engine connections from scratch. The Onan is a battery ignition engine and the Vanguard is a magneto ignition so you will probably want to insert a "KILL RELAY" in the rewire.
cafoose
Thanks Richard I already consulted Grok AI and have a relay ordered coming here Tuesday :handgestures-thumbupright:
Many cheap relays have inconsistent wire colors, so testing the pinouts yourself is the smart way.
How to identify the terminals once you have the relay
Standard 5-pin Bosch-style pin numbers (look on the bottom of the relay itself):
85 and 86 = Coil (the two that make it click)
30 = Common
87a = Normally Closed (this is the one we need for the kill)
87 = Normally Open (we leave this unused)
Simple testing method (with a multimeter or just a 12 V battery)
Find the coil (85 & 86)
Put 12 V across any two of the small wires/pins.
When you hear a solid click, those two are 85 and 86.
It doesn’t matter which is
which for our purpose.
Find 30, 87a, and 87
With the relay not powered (no click):
Continuity between 30 and 87a → that is the Normally Closed pair.
Power the coil (make it click):
Continuity switches to 30 and 87.
Mark the wires
Once you know:
The wire that is always connected to 30 when the relay is off = 87a (Normally Closed)
The common wire = 30
Final connections for your kill circuit
Vanguard black kill wire → Relay terminal/wire 30
Relay 87a → Chassis ground
One coil terminal (85 or 86) → “I” (Ignition) terminal on the 520 switch
Other coil terminal → Chassis ground
That’s it. Test by turning the key — engine should run in RUN and die in OFF.
When the relay arrives, do the click-and-continuity test above and you’ll know exactly which wires to use, regardless of the colors. Let me know the results if you want a double-check.
Edited by cafoose
