Pullstart 71,561 #1 Posted July 20 I have a task. I would like to add auto fill to the pool. If anyone recalls, I only have the top skimmer working currently, and there is still a small leak in the bottom of the pool. When we need to replace the liner in the next year or so, that issue will be fixed. There is an auto fill kit for the tune of $1,000 and I realize there is some safety and security involved here. This kit uses a sensor that hangs in the skimmer box. It uses continuity to satisfy the call for water, and shutting off a fill valve (that will tie into the piping). I imagine it is ultra low voltage. 24? 5? I am not sure. What is really stumping me, is how a normally open circuit will make a call for heat. A closed circuit will shut down the system. @8ntruck? Any thoughts? Water and electricity don’t mix… I’d like to not test this on guinea pigs, or even Uncle Jim. Share this post Link to post Share on other sites
Pullstart 71,561 #2 Posted July 20 This is the fill system sensor. It is to hang in a stand pipe, or skimmer box. I have a 3/4” conduit piped into the skimmer box and into the pump house. Share this post Link to post Share on other sites
squonk 48,427 #3 Posted July 20 That sensor works like a Manitowoc Ice Machine water level sensor. As long as water is touching both probes the board it's connected to senses water conductivity and knows there's enough water. When the level drops the conductivity stops and the board trips a relay that turns on the water supply. Probably 24 volts 2 1 1 Share this post Link to post Share on other sites
Pullstart 71,561 #4 Posted July 20 @squonk so you’re saying I need more Wisconsin in my water? 2 Share this post Link to post Share on other sites
squonk 48,427 #5 Posted July 20 3 minutes ago, Pullstart said: @squonk so you’re saying I need more Wisconsin in my water? Toss some cheese in it! 2 Share this post Link to post Share on other sites
ri702bill 13,391 #6 Posted July 20 2 hours ago, Pullstart said: @squonk so you’re saying I need more Wisconsin in my water? No, he means that you can lick your fingers, touch both probes & still live to talk about it since it's 24 VDC... 1 Share this post Link to post Share on other sites
wallfish 20,744 #7 Posted July 20 (edited) 4 hours ago, Pullstart said: What is really stumping me, is how a normally open circuit will make a call for heat. A closed circuit will shut down the system. We do some radon water systems that have a mechanical fill and off system. Like a toilet does. Pretty simple and no electrical components. Edited July 20 by wallfish 1 Share this post Link to post Share on other sites
ri702bill 13,391 #8 Posted July 20 1 hour ago, wallfish said: Like a toilet Somehow, pool & toilet do not play well in the same sentence..... 6 Share this post Link to post Share on other sites
wallfish 20,744 #9 Posted July 20 Just in case you're interested in trying a mechanical fill valve 2 Share this post Link to post Share on other sites
8ntruck 9,420 #10 Posted July 21 (edited) I'll agree with @squonk. Probably 24v dc. That will probably run a relay that operates the valve. By the way @Pullstart, what have you got going the next couple of weeks? I've got to come see you. I'm good maybe Wednesday or Thursday this week or after Wednesday next week. Edited July 21 by 8ntruck 1 Share this post Link to post Share on other sites
wh500special 2,474 #11 Posted July 21 (edited) 10 hours ago, Pullstart said: … This kit uses a sensor that hangs in the skimmer box. It uses continuity to satisfy the call for water, and shutting off a fill valve (that will tie into the piping). I imagine it is ultra low voltage. 24? 5? I am not sure. What is really stumping me, is how a normally open circuit will make a call for heat. A closed circuit will shut down the system. @8ntruck? Any thoughts? Water and electricity don’t mix… I’d like to not test this on guinea pigs, or even Uncle Jim. I’ll agree that in this case water and electricity shouldn’t be mixed. You can “steer” the logic of your switched circuit using either normal open (NO) or normally closed (NC) relays. Valves too are available either NC or NO, so you have options there. (Edit: terminology might also use the words Direct Acting and Reverse Acting.) in the case of a valve, you may also see it listed as a Fail Close or Fail Open, meaning when the control signal goes away it will either close (fail closed) or open (fail open). Usually valve direction is chosen to give you a failsafe condition. For instance, if you lose control power you probably want the valve to reliably close and stay that way lest you overflow the pool and flood the basement. So you’d work out the logic that the valve closes if the power goes out, somebody pulls the plug, etc. The manufacturer of the automatic fill device probably has the logic planned out using whatever combination of switching (the one in the water), relay (if used), and valve actuator they’ve determined to be the best failsafe combination. They also might have selected the action of the switch to be in the direction it is to avoid false triggers due to splashes or waves from wind or swimmers. I also suspect there is some timing action going on with their control. They may require the switch to be open for X minutes before triggering the valve to open. Likewise, and to avoid rapid cycling, they may have a minimum time interval that triggers the valve to open and let water in also to avoid short cycling. These are timer relay functions. If you piece together a diy system you’ll have to work out the logic that seems the most logical and failsafe to you. A mechanical toilet valve sort of thing takes away the risk of electrical malfunction. If you do chose the electric route there is a range of marine/boating products that can be used to trigger an event. For instance a solid state automatic bilge pump switch can get you there, although the action (NO) is probably the reverse of what you’d normall be looking for. as for mixing electricity and a swimming pool, you’re on your own there especially if you source the power (or tie it in any way) to your house AC power. There are ways to achieve safe isolation, but it’s not intuitive and I would venture is not in the playbook of a typical electrician. Keep in mind that even if you were to, for instance, power your system from a battery charger or AC to DC power supply and that even if you have 12V between your DC leads there is often nothing anchoring either lead (+ or -) to a safe reference/ground. You may end up with that 12V supply floating at some dangerous potential relative to the water and the people in it. I’d probably just buy the off the shelf solution. good luck! Steve Edited July 21 by wh500special 1 2 Share this post Link to post Share on other sites
8ntruck 9,420 #12 Posted July 21 @wh500special brings up a very good point about a safe reference/ground. That didn't enter this retired mechanical engineer's mind. In Lake of the Ozarks in Mo. there are many electrified docks in that lake. Over the years there have been a few deaths and many occasions where something went wrong with the wiring or whatever was plugged into it where people got shocked. An insufficient or floating ground was the cause of most of those incidents. 1 Share this post Link to post Share on other sites
squonk 48,427 #13 Posted July 21 I looked at the manual for this thing. The sensor reads just like I said. Same technology is used for boiler water level sensing. Electronics read water touching the probes through conductivity. The electric to the probes is 24 v DC at 1 amp. 3 Share this post Link to post Share on other sites
Pullstart 71,561 #14 Posted July 21 Lots of good information here, and though I enjoy ribbing, it’s the meat and potatoes here that I was looking for! There is a lot of thoughts to chew on. One- false senses. I would build this on a timer, so it only operates between midnight and 3am, or similar. That should cut down on the waves and pump actions. Two- Toilet fill. I have thought about this often too. I could easily just build a drop in system and stick the hose on it. I have limited space in the skimmer box, and I have a feeling that when my brother in laws come over for their self proclaimed cannon ball contest, the water may have the ability to break the mechanical valve. Three - low water cut off sensor. There is a float sensor in commercial water heating that I may be able to sneak through the conduit that’s plumbed into the box. It’s small and stainless steel, and quite rigid. It runs on 24vdc logic in the water heating industry as well. That I am used to, in my previous life. Four - liability and fail safe. Self explanatory there. I don’t want to get someone hurt. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,919 #15 Posted July 21 My BIL has a fail safe system. Works every time. No electricity involved. Hose in pool. Turn on. Drink adult beverage of your choice. Turn off. Sometimes automatic stuff is way more desirable in a theoretical sense than reality... 4 Share this post Link to post Share on other sites
Pullstart 71,561 #16 Posted July 21 2 minutes ago, SylvanLakeWH said: Hose in pool. Turn on. Drink adult beverage of your choice. Turn off. I think my check liver light would come on! I realize that right now I am in a unique situation, and can’t let the water get too low. I also travel on occasion and can’t let it go a few days. 3 Share this post Link to post Share on other sites
WHX?? 58,387 #17 Posted July 21 20 hours ago, Pullstart said: Uncle Jim. 19 hours ago, Pullstart said: need more Wisconsin in my water? Yep ... pool party with lots of and we'll fill it. Throw some steaks on we'll even fill it with baby ruths ... 5 Share this post Link to post Share on other sites
SylvanLakeWH 32,919 #18 Posted July 21 There's your answer... @WHX?? as your pool boy... all summer... in a speedo... oh... no... 3 2 Share this post Link to post Share on other sites
WHX?? 58,387 #19 Posted July 21 13 hours ago, ri702bill said: pool & toilet do not play well Wanna bet?!?!?! 1 Share this post Link to post Share on other sites
WHX?? 58,387 #20 Posted July 21 1 minute ago, SylvanLakeWH said: in a speedo And the missus in a bikini ... 1 Share this post Link to post Share on other sites
squonk 48,427 #21 Posted July 21 1 hour ago, SylvanLakeWH said: There's your answer... @WHX?? as your pool boy... all summer... in a speedo... oh... no... 2 Share this post Link to post Share on other sites
wallfish 20,744 #22 Posted July 21 (edited) 11 hours ago, Pullstart said: Two- Toilet fill. I have thought about this often too. I could easily just build a drop in system and stick the hose on it. I have limited space in the skimmer box, and I have a feeling that when my brother in laws come over for their self proclaimed cannon ball contest, the water may have the ability to break the mechanical valve. The valve I posted works with a cord from the valve to the float so there's no rigid connection to the valve. They can cannonball all they want and the cord will flex. Plus the float is filled with water to adjust the swing from fill to full so It doesn't just completely float on the surface. Waves and such wouldn't be an instant hard shock to the float and it will bob on the surface. If you set it up so the float hangs inside of a piece of 3" PVC pipe, it won't be affected by waves at all. Edited July 21 by wallfish 2 Share this post Link to post Share on other sites
wh500special 2,474 #23 Posted July 22 On 7/20/2026 at 9:25 PM, 8ntruck said: @wh500special brings up a very good point about a safe reference/ground. That didn't enter this retired mechanical engineer's mind. In Lake of the Ozarks in Mo. there are many electrified docks in that lake. Over the years there have been a few deaths and many occasions where something went wrong with the wiring or whatever was plugged into it where people got shocked. An insufficient or floating ground was the cause of most of those incidents. You bring up an excellent point. LOZ makes the news for lots of weird things. It’s a hotspot of activity for the citizenry of MO where drinking, boating, and bad judgement collide. And there is a lot of haphazard DIY work going on. Dock shock incidents seem to happen with grizzly regularity there. Swimmers around docks are fine, then suddenly one (or more of them) perish while in the water. Many times, the victims aren’t even swimming around a dock that has power. It can be a neighbor’s dock or even one across the cove. What’s been found is that all it takes is for an electrical leak to enter the water somewhere in the vicinity. Water itself isn’t electrically conductive, the things ionized into it make it conductive. Heterogeneous concentrations of conductive agents mean that current isn’t conducted predictably between the leaking electrical source and its grounding point and instead can meander around finding the ever changing paths of least resistance on its way to ground. if a swimmer happens to get into one of those meandering paths, it is tragic. Several deaths have occurred when the victim approached or grabbed the ladder to climb back out of the water as the current had been using the ladder as its path back home. It is incredibly unpredictable where it might go. The poor conductivity of freshwater makes the current path for any leakages a wild animal. A properly functioning GFCI on every supply can reduce the tendency for these phantom electrical currents to claim victims, but their placement is critical and they need to be on every supply. In light of how tragic this has been in recent summers it’s a bad idea to swim around any docks that have power routed to them. Steve 1 Share this post Link to post Share on other sites
Pullstart 71,561 #24 Posted July 22 @wallfish I love your drawings! They are always so straight to the point. I am sure I’m probably over engineering a small issue. I found out about wet patches for pools. They work under water, and don’t require draining. I’m pretty decent at snorkeling. Here in the next week or two I’ll let the water get low so the bottom is closer to the surface. I’ll try out the wet patch and see if our water level issue slows. 1 1 Share this post Link to post Share on other sites
Wayne0 1,666 #25 Posted July 23 On 7/22/2026 at 8:30 AM, Pullstart said: @wallfish I love your drawings! They are always so straight to the point. I am sure I’m probably over engineering a small issue. I found out about wet patches for pools. They work under water, and don’t require draining. I’m pretty decent at snorkeling. Here in the next week or two I’ll let the water get low so the bottom is closer to the surface. I’ll try out the wet patch and see if our water level issue slows. I patched a good size hole (think 1/2 dollar size) with a piece of liner and a can of vinyl adhesive. Under water. Just goop up the patch, take it down and smooth it on. 1 Share this post Link to post Share on other sites
