gt14rider 1,242 #1 Posted July 14 Good evening all, @953 nut @Ed Kennell I am looking to buy a Carhold 42s fuel pump, can you give any pros or cons on this pump? I read a mixed review on this. Have you had any issues with your pump. Life time warranty? Facet posi-flo is double in price. Share this post Link to post Share on other sites
peter lena 9,942 #2 Posted July 14 @ gt14rider, been using a carbole low pressure 3.5 psi pumps for years , very similar in shape / size , very solid no issues at all , have mine just in front of engine , very good , pete 1 Share this post Link to post Share on other sites
Ed Kennell 46,580 #3 Posted July 15 (edited) I have the Carbole 42S pumps on all my tractors. The only issue I had was my fault. I tightened the inlet filter too tight and broke the bond between the plastic body and the metal threaded fitting. Do not let them run dry. I always power mine from the ignition or coil tab on the ignition switch. Edited July 15 by Ed Kennell 3 1 Share this post Link to post Share on other sites
Racinbob 13,040 #4 Posted July 15 I use Mr. Gasket 42s pumps on my tractors. I've heard, and they look, like identical pumps but considering that the Mr. Gasket pump is about twice the cost I was curious so I did a few minutes of research before I wrote this. They are NOT the same. So......my glowing report on the Mr. Gasket can be ignored. That being said, I wouldn't hesitate to try a Carbole because of their price point. They do go 'whirrrrr' when running and not 'thumpy, thumpy' like the cheapies. I tried those and had an over 50% failure rate. I try to find a spot near the tank to mount them as it's easier to push the fuel than to suck it. 2 1 Share this post Link to post Share on other sites
953 nut 67,398 #5 Posted July 15 I have had no problems with the Carbole solid state pumps, they cost a bit more than the round "Thumper" pumps but are well worth it in my opinion. 1 1 Share this post Link to post Share on other sites
peter lena 9,942 #6 Posted July 15 @Ed Kennell have also added a single green LED , bulb to my dash to verify pumps operation , years in , very quiet , solid operation , regularly do a series of operational checks / verifications to any experiment I try, basically TWEEKING any point of issue ,. linkages are king for me , how tiny ENHANCEMENTS , can make a train wreck , into a seamless function . enjoy your A/C . pete Share this post Link to post Share on other sites
peter lena 9,942 #7 Posted July 15 @Racinbob no fuel filter from tank ? another just before carb ? collective / repetitive issue ? years in on this , cleaned out tank , clear fuel rated hose , also started using 1 to 2 oz of STA BIL to all my tank top offs , guess what ? never have any fuel hose , break down debris anywhere , isn't that what you want ? clear fuel hose up to carb with a check valve ? so I am looking right at what's going to carb . operational check , what's it doing ? also another great spot to lay in a 5/16 frame length steel brake line . tubing bender for tweaking , about 4 ft , eliminate a lot of hose issue ? why not ? inner frame upper 90 deg angle is perfect hiding spot for this , lots of related holes for trials , tie wraps , let you experiment , have no fuel rated issues at all , years in . love repetitive issues , like bearing failures , its not in the book , just talkin , pete Share this post Link to post Share on other sites
Racinbob 13,040 #8 Posted July 15 2 hours ago, peter lena said: @Racinbob no fuel filter from tank ? another just before carb ? collective / repetitive issue ? years in on this , cleaned out tank , clear fuel rated hose , also started using 1 to 2 oz of STA BIL to all my tank top offs , guess what ? never have any fuel hose , break down debris anywhere , isn't that what you want ? clear fuel hose up to carb with a check valve ? so I am looking right at what's going to carb . operational check , what's it doing ? also another great spot to lay in a 5/16 frame length steel brake line . tubing bender for tweaking , about 4 ft , eliminate a lot of hose issue ? why not ? inner frame upper 90 deg angle is perfect hiding spot for this , lots of related holes for trials , tie wraps , let you experiment , have no fuel rated issues at all , years in . love repetitive issues , like bearing failures , its not in the book , just talkin , pete Shutoff at the tank, one fuel filter before pump, no check valve, booze free fuel, no additives. Never had fuel issues. It's worked for me for decades. 1 1 Share this post Link to post Share on other sites
JoeM 10,093 #9 Posted July 15 I have had the cheap and the expensive. I have had both fail. I have installed more of the $15 ones (4) and they been running fine. I believe price is not always a factor of quality. I like lean toward the square one....not sure why. 2 Share this post Link to post Share on other sites
gt14rider 1,242 #10 Posted July 15 Got another question, best place you've found for the pump? Near tank( maybe under tank) or in front of engine? I'll make a bracket for mounting. Sorry for the bad artwork Share this post Link to post Share on other sites
JoeM 10,093 #11 Posted July 16 Best (I think a must) if the pump is lower than the tank. It is not easy but with a little creativeness can be done On this one the filter is back near the tank and the shift plate can be taken off to change filters. I do use an automotive wix filter that has a large capacity. Rear pump mounting on an xi, not some of my best work. It was a cheap pump and worked really nice. 1 Share this post Link to post Share on other sites
gt14rider 1,242 #12 Posted July 16 @JoeM nice work, first Pic, where's the battery go?⁰ Share this post Link to post Share on other sites
JoeM 10,093 #13 Posted July 16 (edited) This one has the battery up on top and rear tank. Your doing the right thing just putting the pump in a place and seeing if it is workable. These machine sometimes are tight on space. Edited July 16 by JoeM 1 Share this post Link to post Share on other sites
Racinbob 13,040 #14 Posted July 16 11 hours ago, gt14rider said: Got another question, best place you've found for the pump? Near tank( maybe under tank) or in front of engine? I'll make a bracket for mounting. Sorry for the bad artwork Every tractor is different. It's best to have it below the tank. On my 2005 Classic (pic above) the location was almost a no brainer. But it can't happen on a hydro. On my 76 I didn't like anything under the hood. The fuel tank and battery took up a lot of the space. I ended up mounting it under the seat and running the extra fuel line. This is the original install. That's a cheapie pump which failed about 3 football fields from the garage. A 42s has replaced it. 1 Share this post Link to post Share on other sites
gt14rider 1,242 #15 Posted July 16 Pump should be here today, I'll get the torch and BMFH ready. Nothing some duct tape and bubble gum can't fix. I'll take pictures 2 Share this post Link to post Share on other sites
sqrlgtr 3,256 #16 Posted July 17 first pick is 520H with Facet metal pump 2nd pick is Facet plastic pump that went on 312-8 in same place as 520h, I cant find pic of 312 pump mounted but you get the idea. Both work great but believe I prefer the metal cube type better just because it takes up a little less space than the plastic pump. 1 Share this post Link to post Share on other sites
Ed Kennell 46,580 #17 Posted July 18 I like to get the fuel lines out of the center tunnel and keep the run as short as possible to the carb. On the 312H I ran it along the outside of the right frame rail. On the 520 I had to run it on the left side as the right side is crowed with a foot control, a blade angle lever, and a cab heat houser. 1 Share this post Link to post Share on other sites
gt14rider 1,242 #18 Posted Sunday at 05:37 PM Hi all, got another question. The tank out let and fuel shut off valve are 1/4" the 42s pump calls for 5/16" line ,any problem with that. Don't want to starve the pump, or am I over thinking it. Share this post Link to post Share on other sites
Ed Kennell 46,580 #19 Posted Sunday at 05:45 PM 4 minutes ago, gt14rider said: Don't want to starve the pump, As long as the shut off valve and the mesh screen in the tank are clean and fully open, there will be plenty of fuel at the pump inlet. 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,785 #21 Posted 5 hours ago I am with Mike on this. I have one on the 856 and 1057 both work well. The old saying is you get what you pay for. Share this post Link to post Share on other sites
