WHX??
Trailer Tires
WHX??
So the enclosed trailer that @Achto and I took out to the BS needs new shoes in ST205-75R 15 but on the fence about what to get. If money was no object I would get Goodyear Endurance  but at $186 a tire it's a tough pill to swallow for a trailer that sits most of the time. Or go with a cheaper probably offshore one.
The price range on tires is so wide... $70 apiece  to $190.
No matter what brand load range D speed rating 80 minimums.
Keep in mind I have three tandems to keep shoes on plus two singles.
Camper toy hauler always gets the premiums do to the damage that is possible with a blow out. @Pullstart and @jeremi3210 might know a thing or two about that.
Trailer gurus say change tires every three years with better ones every five years.
I do generally carry a spare especially on long hauls.
Pics for attention.
Edited by WHX??
Kenneth R Cluley
I have also experienced the dreaded blow out and "collateral damage".  I bit the bullet and got the Endurance for both my trailers that get used most often but put chinesium's on the travel trailer that we don't move from our property possibly two to three times a year. Difficult for me to replace a tire at three or five years that shows little or no wear, but I guess that's the price we pay for peace of mind. I feel better on the highway towing with the Goodyears. We had a flat then a blowout on travel trailer (spare was really old) and thought "Good Sam" roadside would save us. They quoted $795.00 and three hour wait to bring me a Walmart trailer tire. So remember to upgrade spare as well.
WHX??
Right??
They say the sun does more damage than anything.
ri702bill
48 minutes ago, WHX?? said:
Right??
That's why you see the tire cover booties on motorhomes & campers.
There is no excuse not to check & adjust the cold tire pressures before heading out.... and being adequately prepared to loose one (or two) along the way.
Besides, do you really want to listen to your better half constructively carring on (whining) while you change a flat?? :auto-camptrailer:
Edited by ri702bill
SylvanLakeWH
:text-yeahthat:
I run Goodyear and change every 5 years or so...
Plus I think anecdotally, the quality is not what it used to be... :confusion-shrug:
I am actually thinking of selling my trailer and just renting one when I need it... 2-3 times a year ain't worth tires bearings and storage... probably won't but ...
ri702bill
2 minutes ago, SylvanLakeWH said:
:text-yeahthat:
Ah, but how old are the tires on the rental???!!
WHX??
That's no problem long hauls I always throw a torque wrench in. It's the collateral damage when running the mayblow brand.:angry-jumpinganger:
That's what @Andy N. said once now lookit what he bought. He showed up more than once at show with a u haul.
It's actually not a bad idea for the 2-3 but I come from the I need it it's there school.
And who checks the tire pressure lug nuts?!? :lol:
I typically run 5 psi less than max figuring going to max when running the interstate at 70 and 90 out.
JoeM
And then there is the guy who goes to the junk yard, removes a couple tires from a crown vic and never has any issues!
I know when pulling with a load I stop every couple hours and put my hand on the tires and hubs checking for excessive heat.
There was one time i found a hot one and it was under inflated. must have missed it when I was doing the pre-trip. I had one of those cheep o compressors and 20 minutes later good to go, next stop no heat.
  • Like 5
Achto
Some top 10 suggested trailer tires along with some basic use aplications.
  1. Goodyear Endurance
    Often considered the gold standard for travel trailers and heavy cargo loads. It features Goodyear's Durawall technology for sidewall protection and runs cooler over long hauls. It is Speed Rated "N" (up to 87 mph).
    [1, 2, 3, 4, 5]
  1. Carlisle Radial Trail HD
    A staple for boat, RV, and livestock trailers. Known for its exceptional heat dissipation, heavy-duty ply construction, and resistance to curb impact and punctures.
    [1, 2, 3, 4]
  1. Trailer King RST II
    An upgraded version of the popular Trailer King RST, known for its excellent heat-dissipation design and steady, straight-line tracking. It is highly favored for continuous highway travel.
    [1, 2, 3, 4]
  2. Sailun S637T
    An all-steel radial tire designed specifically for heavy-duty commercial applications, large multi-axle trailers, and heavy RVs. Highly durable and able to handle massive weight capacities.
    [1]
  3. Power King Towmax STR II
    A reliable choice designed for travel trailers and high-capacity towing. It provides superior stability and boasts a robust tread design that ensures extended tire life.
    [1, 2, 3, 4]
  4. Westlake ST100
    Equipped with dual steel belts, making it a great option for heavy RVs, toy haulers, and flatbeds. It resists uneven wear and handles highway speeds well.
    [1]
  5. Gladiator QR25-TS
    Built with a highly robust construction designed to handle 5th wheelers and heavy cargo hauling safely. It prioritizes sturdy load ratings and impact resistance.
    [1]
  6. Thunderer ST Radial R501
    Features deep tread optimized for long-haul highway towing, ensuring smooth rolling over thousands of miles.
    [1]
  7. Triangle TR653
    A multi-purpose utility trailer tire recognized for solid shock absorption and reliable traction in both dry and wet road conditions.
    [1]
  8. Kenda Loadstar (Bias/Radial)
    A versatile option that is offered in both radial and bias-ply options, highly popular for boat, snowmobile, and utility trailers. They feature a flatter tread profile for better weight distribution and wear.
    [1, 2, 3, 4]
Edited by Achto
ebinmaine
We bought the carlstars. Seems good. Barring unforeseen issues I'd buy those again.
