WHX?? 57,110 #1 Posted 9 hours ago (edited) So the enclosed trailer that @Achto and I took out to the BS needs new shoes in ST205-75R 15 but on the fence about what to get. If money was no object I would get Goodyear Endurance but at $186 a tire it's a tough pill to swallow for a trailer that sits most of the time. Or go with a cheaper probably offshore one. The price range on tires is so wide... $70 apiece to $190. No matter what brand load range D speed rating 80 minimums. Keep in mind I have three tandems to keep shoes on plus two singles. Camper toy hauler always gets the premiums do to the damage that is possible with a blow out. @Pullstart and @jeremi3210 might know a thing or two about that. Trailer gurus say change tires every three years with better ones every five years. I do generally carry a spare especially on long hauls. Pics for attention. Edited 9 hours ago by WHX?? 1 Share this post Link to post Share on other sites
Kenneth R Cluley 683 #2 Posted 9 hours ago I have also experienced the dreaded blow out and "collateral damage". I bit the bullet and got the Endurance for both my trailers that get used most often but put chinesium's on the travel trailer that we don't move from our property possibly two to three times a year. Difficult for me to replace a tire at three or five years that shows little or no wear, but I guess that's the price we pay for peace of mind. I feel better on the highway towing with the Goodyears. We had a flat then a blowout on travel trailer (spare was really old) and thought "Good Sam" roadside would save us. They quoted $795.00 and three hour wait to bring me a Walmart trailer tire. So remember to upgrade spare as well. 1 1 Share this post Link to post Share on other sites
WHX?? 57,110 #3 Posted 9 hours ago 3 minutes ago, Kenneth R Cluley said: Difficult for me to replace a tire at three or five years that shows little or no wear, Right?? They say the sun does more damage than anything. 1 Share this post Link to post Share on other sites
ri702bill 12,331 #4 Posted 8 hours ago (edited) 48 minutes ago, WHX?? said: Right?? They say the sun does more damage than anything. That's why you see the tire cover booties on motorhomes & campers. There is no excuse not to check & adjust the cold tire pressures before heading out.... and being adequately prepared to loose one (or two) along the way. Besides, do you really want to listen to your better half constructively carring on (whining) while you change a flat?? Edited 8 hours ago by ri702bill 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,624 #5 Posted 8 hours ago 42 minutes ago, WHX?? said: They say the sun does more damage than anything. I run Goodyear and change every 5 years or so... Plus I think anecdotally, the quality is not what it used to be... I am actually thinking of selling my trailer and just renting one when I need it... 2-3 times a year ain't worth tires bearings and storage... probably won't but ... 3 Share this post Link to post Share on other sites
ri702bill 12,331 #6 Posted 8 hours ago 2 minutes ago, SylvanLakeWH said: I run Goodyear and change every 5 years or so... Plus I think anecdotally, the quality is not what it used to be... I am actually thinking of selling my trailer and just renting one when I need it... 2-3 times a year ain't worth tires bearings and storage... probably won't but ... Ah, but how old are the tires on the rental???!! 3 Share this post Link to post Share on other sites
WHX?? 57,110 #7 Posted 7 hours ago 28 minutes ago, ri702bill said: while you change a flat?? That's no problem long hauls I always throw a torque wrench in. It's the collateral damage when running the mayblow brand. 29 minutes ago, SylvanLakeWH said: selling my trailer and just renting one when I need it... That's what @Andy N. said once now lookit what he bought. He showed up more than once at show with a u haul. It's actually not a bad idea for the 2-3 but I come from the I need it it's there school. 29 minutes ago, ri702bill said: Ah, but how old are the tires on the rental???!! And who checks the tire pressure lug nuts?!? I typically run 5 psi less than max figuring going to max when running the interstate at 70 and 90 out. 2 Share this post Link to post Share on other sites
JoeM 10,065 #8 Posted 7 hours ago And then there is the guy who goes to the junk yard, removes a couple tires from a crown vic and never has any issues! I know when pulling with a load I stop every couple hours and put my hand on the tires and hubs checking for excessive heat. There was one time i found a hot one and it was under inflated. must have missed it when I was doing the pre-trip. I had one of those cheep o compressors and 20 minutes later good to go, next stop no heat. 5 1 Share this post Link to post Share on other sites
Achto 32,003 #9 Posted 6 hours ago (edited) Some top 10 suggested trailer tires along with some basic use aplications. Goodyear Endurance Often considered the gold standard for travel trailers and heavy cargo loads. It features Goodyear's Durawall technology for sidewall protection and runs cooler over long hauls. It is Speed Rated "N" (up to 87 mph). [1, 2, 3, 4, 5] Carlisle Radial Trail HD A staple for boat, RV, and livestock trailers. Known for its exceptional heat dissipation, heavy-duty ply construction, and resistance to curb impact and punctures. [1, 2, 3, 4] Trailer King RST II An upgraded version of the popular Trailer King RST, known for its excellent heat-dissipation design and steady, straight-line tracking. It is highly favored for continuous highway travel. [1, 2, 3, 4] Sailun S637T An all-steel radial tire designed specifically for heavy-duty commercial applications, large multi-axle trailers, and heavy RVs. Highly durable and able to handle massive weight capacities. [1] Power King Towmax STR II A reliable choice designed for travel trailers and high-capacity towing. It provides superior stability and boasts a robust tread design that ensures extended tire life. [1, 2, 3, 4] Westlake ST100 Equipped with dual steel belts, making it a great option for heavy RVs, toy haulers, and flatbeds. It resists uneven wear and handles highway speeds well. [1] Gladiator QR25-TS Built with a highly robust construction designed to handle 5th wheelers and heavy cargo hauling safely. It prioritizes sturdy load ratings and impact resistance. [1] Thunderer ST Radial R501 Features deep tread optimized for long-haul highway towing, ensuring smooth rolling over thousands of miles. [1] Triangle TR653 A multi-purpose utility trailer tire recognized for solid shock absorption and reliable traction in both dry and wet road conditions. [1] Kenda Loadstar (Bias/Radial) A versatile option that is offered in both radial and bias-ply options, highly popular for boat, snowmobile, and utility trailers. They feature a flatter tread profile for better weight distribution and wear. [1, 2, 3, 4] Edited 6 hours ago by Achto 1 1 Share this post Link to post Share on other sites
ebinmaine 79,317 #10 Posted 6 hours ago We bought the carlstars. Seems good. Barring unforeseen issues I'd buy those again. Share this post Link to post Share on other sites
jeremi3210 746 #11 Posted 3 hours ago 6 hours ago, WHX?? said: jeremi3210 might know a thing or two about that. Yes I do! Remember when I picked.the truck up with my new trailer and we talked about my spare tire on it being one of the take offs from my camper. The other day I walked past it to find it blown out hanging as a spare ive got 2 brand new Carlisle now.for spares. No more messing the them junk tires... 1 Share this post Link to post Share on other sites
ebinmaine 79,317 #12 Posted 3 hours ago 6 minutes ago, jeremi3210 said: Yes I do! Remember when I picked.the truck up with my new trailer and we talked about my spare tire on it being one of the take offs from my camper. The other day I walked past it to find it blown out hanging as a spare ive got 2 brand new Carlisle now.for spares. No more messing the them junk tires... That's pretty much what we did. When we bought the new camper last fall one of the immediate modifications was to put larger and more heavy duty tires on it. I went from a 14 to a 15 and if I recall correctly, two sizes wider. That stepped up my Tire carry capacity quite a lot. I also bought two extras. Four new rims and four new tires total. I'm hoping I never have to use one, much less both. And if that's the case it was still worth every cent just for the Peace of mind. But they will be rotated into the wear pattern for about 5 to 7 years depending on cracking. After that, yard usage or trash. Share this post Link to post Share on other sites
