ebinmaine
Wooden truck bed build thoughts
ebinmaine
Over the next several months I'll be contemplating, designing, and building a unique bed for my 1986 Ford F250.
This will be a flatbed mostly designed for hauling tractors. At least 2, maybe 3.
Also designed for hauling dirt/mulch/rocks etc...
It'll be functional, extremely strong, and very nice in appearance.
I've made a BUNCH of notes:
  "Bed build thoughts:
Ideally the size would be for holding two C series fore n aft at the headboard and another tractor crossways at the back.
85" wide across flat inside x 108" - 110" long should work.
Do not exceed total length of twice the "cab to axle" measurement. (Bed should be centered over axle)
Wood parts should be fully protected from weather and look good.
Colored stain(?) on all oak parts.
Red tinted to bring out oak color?
Full pigment paint on Advantech to hide text. Black?
Oak rails bolted through frame. Scribed to follow all curves in steel. Minimum thickness over suspension bump at 2". Front of rails near cab may be closer to 5" thick.
Oak cross beams at every stock original location except at/over tire position. May need to add extra beams fore & aft of tire to get support for outer edges of Advantech.
Or consider boxing wooden frame there.
Cross beams should be bolted through frame combined with fore & aft rails.
It would be preferable to bolt the flat surface Advantech as well.
Install spacers on top of the frame rail in between all the cross beams for extra support.
Side supports at outer edges should be appropriately sized Oak beams as well. Probably four inches tall to match up with cross beams. Consider decorative wheel Arch over tire.
Add 12" to 14" of steel at frame rear for support of rearmost oak crossmember.
Widen trailer hitch with spacer plates to better match bottom of frame rails.
Tie in trailer hitch with new rear frame.
Use 1/8" plate steel with tapered bottom corners as end face plate/cap like a commercial truck.
Rear bumper??
As part of bed design and build be sure to incorporate splash guards of partially solid, partially soft at bottom, material. Sheet plastic? With rubber bottom?
Mount a marker light as low and outside as possible on hard part.
Headboard idea:
Install direct to frame to increase effective bed length.
Attach to far outside of forward cross beam.
Come up 12" to 15" vertically.
Cap front with Advantech.
DO NOT BLOCK MIRRORS.
Do not block third brake/courtesy light.
Make vertical/angled posts for each side that follow just outside body contour & are 4" taller than cab. Crossbar, 2" lower than top so there's a bump stop on each side to hold materials.
Then run verticals lined up with the truck frame for support. Confirm that verticals don't block rear window view too much. Or box to avoid.
Use some type of grating to protect glass while preserving view.
For the sides and tailgate, some sort of 12" to 14" + tall removable board, as thin as possible. Advantech?
Bed should have at minimum, a strip of metal around the outside edge to support lights. Perhaps C channel with lip on the upper side to protect the lights from falling objects."
953 nut
Take a look at @Pullstart's Norman, that sucker can load four :wh: and the removable sides are his ramps.
ri702bill
Rear bumper with integrated hitch receiver?? What about fuel fill access? Fixed illuminated rear licence plate?
Pictures of the truck as is would be helpful.
pfrederi
Now maybe oak is cheaper up there but when I went to the local sawmill a couple years ago just  enough to redeck a 5x10 trailer caused me to stop...
adsm08
If you are looking to build a custom flat bed I would look into the lighting requirements of federal regulations.
Even if your state has no inspections it is illegal to operate a vehicle that doesn't meet federal regulations on any road that is owned by or maintained with money from the Feds.
ebinmaine
Not sure what I'm doing there yet. Depends on laws.
Easy. Side fill.
Also easy.
I have a pair of Peterbilt cab & chassis rear lamps.
ebinmaine
This is red oak I bought several years ago.
Here, red is accessible. White oak is huge $$
ebinmaine
Already have. Remember my CDL. We do lighting inspections daily.
We do have annual inspections here.
I'm having several different State Inspection Stations give me instruction.
This build will exceed every rule.
ri702bill
And Collosus takes a trip to the back burner - again!
Truck frame looks excellent for its age....
Pullstart
Norman will be hauling his deck here in a couple weeks :handgestures-thumbupright:
ebinmaine
Colossus is doing just fine. Being patient.
This was restored between the early 2000s and 2015.
Handy Don
Not really a truck guy. Torn between oak's great retro look (and my personal attraction to wood carpentry) on one hand and what metal can offer on the other.
I can heartily appreciate the “stake” sides becoming ramps although the transition from a straight ramp onto the flatbed can challenge the clearance of a tractor with an under-hung implement, e.g. a grader or mower deck. Depending on construction, the sides could help constrain small stuff like lumber. Being able to secure the sides flat on the bed when unused might help aerodynamics (only a highway speed issue).
Sturdy enough to support side loading as well as rear loading would be cool.
Numerous strongpoints for load tiedowns
Hold downs within the flatbed, as opposed to only at the edges, will make both full and LTL (less than a full load) a LOT easier to secure.
A plan & tie points for a tarp or other load cover might be “Maine-ly” useful
Under-bed storage boxes for straps, tarp, sleepers, etc.
Maintenance accessibility for worn/damaged deck member?
Work lights for loading/unloading in darkness--cab top mount?
Weight, i.e. keep as light as possible to preserve maximum load capacity.
Edited by Handy Don
DLF
My boss bought a 76 250 that the bed was trashed and had a oak bed on it.  I moved the bumper back 16 or 18" and down maybe 8", also cut the ends bumper off just past the frame and mounted the tail lights there.
Goodman Lumber Co. built the bed to match the ones on there trucks.  Don't have any pictures, left there in 1998.
Edited by DLF
ebinmaine
7 hours ago, Handy Don said:
..... Torn between oak's great retro look (and my personal attraction to wood carpentry) on one hand and what metal can offer on the other.
Me too. That's why I'm adding steel to appropriate places.
Methinks that's neat as well but I have a nice set of extra long "up" bowed aluminum ramps.
This was my thought process.
There are no "highway speeds" for this combo. It's a transmission with no overdrive and 4:10 gears. Top speed is probably 65 without a screaming engine. Most often 55 to 60.
Points of tiedowns are - to an extent  - something still in the consideration stage. Type and quantity.
I know I'll need 3 across the front and one at each side two ft from the back. Minimum.
I'd certainly like more.
I know that wherever I choose will be no truck frame so the tiedowns will go through the wood beams as much as possible.
THIS IS ONE OF MY MAIN CONCERNS.
Steel reinforcement and top quality hardware will be used.
I see what you did there. And good idea.
I have room on the passenger's side behind the cab for an under-hung frame mounted box. Definitely a plan for that.
The driver's side has the park brake brackets but perhaps a smaller box could hang off the bed...?
Also behind the seat... but there will already be a few things taking up space there. Road tool kit. Some extra parts. First aid. Fire extinguisher. Etc...
Good point here too. The entire assembly will be bolted through each other for strength. Individual piece replacement would still be possible though.
The cab has a third brake lamp. I'm looking at swapping to a modern LED assembly that would have a white light in that. Possibly also at the top corners of the bed/ cab protector/  headboard.
This is a concern... but not much. The truck will hold more than I need by weight and I'll be adding capacity in the form of increasing springs.
squonk
Shall we get a " Poll" started?
Chicken or Egg?
Bed or Colossus?
6671055021avatar
  • Haha 2
ebinmaine
15 minutes ago, squonk said:
Bed or Colossus?
Bed.... probably.
953 nut
White oak is well worth the extra money because white oak is significantly more rot-resistant than red oak. Red oak is porous open grained wood and will warp and rot as a result. It is fine for interior use like cabinets but not for outdoor use.
