ebinmaine 79,745 #1 Posted June 7 Over the next several months I'll be contemplating, designing, and building a unique bed for my 1986 Ford F250. This will be a flatbed mostly designed for hauling tractors. At least 2, maybe 3. Also designed for hauling dirt/mulch/rocks etc... It'll be functional, extremely strong, and very nice in appearance. I've made a BUNCH of notes: "Bed build thoughts: Ideally the size would be for holding two C series fore n aft at the headboard and another tractor crossways at the back. 85" wide across flat inside x 108" - 110" long should work. Do not exceed total length of twice the "cab to axle" measurement. (Bed should be centered over axle) Wood parts should be fully protected from weather and look good. Colored stain(?) on all oak parts. Red tinted to bring out oak color? Full pigment paint on Advantech to hide text. Black? Oak rails bolted through frame. Scribed to follow all curves in steel. Minimum thickness over suspension bump at 2". Front of rails near cab may be closer to 5" thick. Oak cross beams at every stock original location except at/over tire position. May need to add extra beams fore & aft of tire to get support for outer edges of Advantech. Or consider boxing wooden frame there. Cross beams should be bolted through frame combined with fore & aft rails. It would be preferable to bolt the flat surface Advantech as well. Install spacers on top of the frame rail in between all the cross beams for extra support. Side supports at outer edges should be appropriately sized Oak beams as well. Probably four inches tall to match up with cross beams. Consider decorative wheel Arch over tire. Add 12" to 14" of steel at frame rear for support of rearmost oak crossmember. Widen trailer hitch with spacer plates to better match bottom of frame rails. Tie in trailer hitch with new rear frame. Use 1/8" plate steel with tapered bottom corners as end face plate/cap like a commercial truck. Rear bumper?? As part of bed design and build be sure to incorporate splash guards of partially solid, partially soft at bottom, material. Sheet plastic? With rubber bottom? Mount a marker light as low and outside as possible on hard part. Headboard idea: Install direct to frame to increase effective bed length. Attach to far outside of forward cross beam. Come up 12" to 15" vertically. Cap front with Advantech. DO NOT BLOCK MIRRORS. Do not block third brake/courtesy light. Make vertical/angled posts for each side that follow just outside body contour & are 4" taller than cab. Crossbar, 2" lower than top so there's a bump stop on each side to hold materials. Then run verticals lined up with the truck frame for support. Confirm that verticals don't block rear window view too much. Or box to avoid. Use some type of grating to protect glass while preserving view. For the sides and tailgate, some sort of 12" to 14" + tall removable board, as thin as possible. Advantech? Bed should have at minimum, a strip of metal around the outside edge to support lights. Perhaps C channel with lip on the upper side to protect the lights from falling objects." 1 Share this post Link to post Share on other sites
953 nut 67,525 #2 Posted June 7 Take a look at @Pullstart's Norman, that sucker can load four and the removable sides are his ramps. 4 1 Share this post Link to post Share on other sites
ri702bill 12,535 #3 Posted June 7 Rear bumper with integrated hitch receiver?? What about fuel fill access? Fixed illuminated rear licence plate? Pictures of the truck as is would be helpful. 1 Share this post Link to post Share on other sites
pfrederi 20,905 #4 Posted June 7 Now maybe oak is cheaper up there but when I went to the local sawmill a couple years ago just enough to redeck a 5x10 trailer caused me to stop... 2 Share this post Link to post Share on other sites
adsm08 4,821 #5 Posted June 7 If you are looking to build a custom flat bed I would look into the lighting requirements of federal regulations. Even if your state has no inspections it is illegal to operate a vehicle that doesn't meet federal regulations on any road that is owned by or maintained with money from the Feds. 3 1 Share this post Link to post Share on other sites
ebinmaine 79,745 #6 Posted June 7 19 minutes ago, ri702bill said: Rear bumper with integrated hitch receiver?? Not sure what I'm doing there yet. Depends on laws. 19 minutes ago, ri702bill said: What about fuel fill access? Easy. Side fill. 19 minutes ago, ri702bill said: Fixed illuminated rear licence plate? Also easy. I have a pair of Peterbilt cab & chassis rear lamps. 19 minutes ago, ri702bill said: Pictures of the truck as is would be helpful. Share this post Link to post Share on other sites
ebinmaine 79,745 #7 Posted June 7 22 minutes ago, pfrederi said: Now maybe oak is cheaper up there but when I went to the local sawmill a couple years ago just enough to redeck a 5x10 trailer caused me to stop... This is red oak I bought several years ago. Here, red is accessible. White oak is huge $$ Share this post Link to post Share on other sites
ebinmaine 79,745 #8 Posted June 8 10 minutes ago, adsm08 said: If you are looking to build a custom flat bed I would look into the lighting requirements of federal regulations. Already have. Remember my CDL. We do lighting inspections daily. 10 minutes ago, adsm08 said: Even if your state has no inspections it is illegal to operate a vehicle that doesn't meet federal regulations on any road that is owned by or maintained with money from the Feds. We do have annual inspections here. I'm having several different State Inspection Stations give me instruction. This build will exceed every rule. 1 Share this post Link to post Share on other sites
ri702bill 12,535 #9 Posted June 8 And Collosus takes a trip to the back burner - again! Truck frame looks excellent for its age.... 3 Share this post Link to post Share on other sites
Pullstart 70,798 #10 Posted June 8 1 hour ago, 953 nut said: Take a look at @Pullstart's Norman, that sucker can load four and the removable sides are his ramps. Norman will be hauling his deck here in a couple weeks 2 Share this post Link to post Share on other sites
ebinmaine 79,745 #11 Posted June 8 13 minutes ago, ri702bill said: And Collosus takes a trip to the back burner - again! Colossus is doing just fine. Being patient. 13 minutes ago, ri702bill said: Truck frame looks excellent for its age.... This was restored between the early 2000s and 2015. 1 Share this post Link to post Share on other sites
Handy Don 16,989 #12 Posted June 8 (edited) Not really a truck guy. Torn between oak's great retro look (and my personal attraction to wood carpentry) on one hand and what metal can offer on the other. I can heartily appreciate the “stake” sides becoming ramps although the transition from a straight ramp onto the flatbed can challenge the clearance of a tractor with an under-hung implement, e.g. a grader or mower deck. Depending on construction, the sides could help constrain small stuff like lumber. Being able to secure the sides flat on the bed when unused might help aerodynamics (only a highway speed issue). Sturdy enough to support side loading as well as rear loading would be cool. Numerous strongpoints for load tiedowns Hold downs within the flatbed, as opposed to only at the edges, will make both full and LTL (less than a full load) a LOT easier to secure. A plan & tie points for a tarp or other load cover might be “Maine-ly” useful Under-bed storage boxes for straps, tarp, sleepers, etc. Maintenance accessibility for worn/damaged deck member? Work lights for loading/unloading in darkness--cab top mount? Weight, i.e. keep as light as possible to preserve maximum load capacity. Edited June 8 by Handy Don 1 Share this post Link to post Share on other sites
DLF 74 #13 Posted June 8 (edited) My boss bought a 76 250 that the bed was trashed and had a oak bed put on it. I moved the bumper back 16 or 18" and down maybe 8", also cut the ends bumper off just past the frame and mounted the tail lights there. Goodman Lumber Co. built the bed to match the ones on there trucks. Don't have any pictures, left there in 1998. Edited June 8 by DLF 1 Share this post Link to post Share on other sites
ebinmaine 79,745 #14 Posted June 8 7 hours ago, Handy Don said: ..... Torn between oak's great retro look (and my personal attraction to wood carpentry) on one hand and what metal can offer on the other. Me too. That's why I'm adding steel to appropriate places. 7 hours ago, Handy Don said: I can heartily appreciate the “stake” sides becoming ramps although the transition from a straight ramp onto the flatbed can challenge the clearance of a tractor with an under-hung implement, e.g. a grader or mower deck. Methinks that's neat as well but I have a nice set of extra long "up" bowed aluminum ramps. 7 hours ago, Handy Don said: Depending on construction, the sides could help constrain small stuff like lumber. This was my thought process. 7 hours ago, Handy Don said: Being able to secure the sides flat on the bed when unused might help aerodynamics (only a highway speed issue). There are no "highway speeds" for this combo. It's a transmission with no overdrive and 4:10 gears. Top speed is probably 65 without a screaming engine. Most often 55 to 60. 7 hours ago, Handy Don said: Sturdy enough to support side loading as well as rear loading would be cool. Numerous strongpoints for load tiedowns Hold downs within the flatbed, as opposed to only at the edges, will make both full and LTL (less than a full load) a LOT easier to secure. Points of tiedowns are - to an extent - something still in the consideration stage. Type and quantity. I know I'll need 3 across the front and one at each side two ft from the back. Minimum. I'd certainly like more. I know that wherever I choose will be no truck frame so the tiedowns will go through the wood beams as much as possible. THIS IS ONE OF MY MAIN CONCERNS. Steel reinforcement and top quality hardware will be used. 7 hours ago, Handy Don said: A plan & tie points for a tarp or other load cover might be “Maine-ly” useful I see what you did there. And good idea. 7 hours ago, Handy Don said: Under-bed storage boxes for straps, tarp, sleepers, etc. I have room on the passenger's side behind the cab for an under-hung frame mounted box. Definitely a plan for that. The driver's side has the park brake brackets but perhaps a smaller box could hang off the bed...? Also behind the seat... but there will already be a few things taking up space there. Road tool kit. Some extra parts. First aid. Fire extinguisher. Etc... 7 hours ago, Handy Don said: Maintenance accessibility for worn/damaged deck member? Good point here too. The entire assembly will be bolted through each other for strength. Individual piece replacement would still be possible though. 7 hours ago, Handy Don said: Work lights for loading/unloading in darkness--cab top mount? The cab has a third brake lamp. I'm looking at swapping to a modern LED assembly that would have a white light in that. Possibly also at the top corners of the bed/ cab protector/ headboard. 7 hours ago, Handy Don said: Weight, i.e. keep as light as possible to preserve maximum load capacity. This is a concern... but not much. The truck will hold more than I need by weight and I'll be adding capacity in the form of increasing springs. 1 Share this post Link to post Share on other sites
squonk 47,448 #15 Posted June 8 Shall we get a " Poll" started? Chicken or Egg? Bed or Colossus? 1 8 Share this post Link to post Share on other sites
ebinmaine 79,745 #16 Posted June 8 15 minutes ago, squonk said: Bed or Colossus? Bed.... probably. Share this post Link to post Share on other sites
953 nut 67,525 #17 Posted June 8 11 hours ago, ebinmaine said: This is red oak I bought several years ago. Here, red is accessible. White oak is huge $$ White oak is well worth the extra money because white oak is significantly more rot-resistant than red oak. Red oak is porous open grained wood and will warp and rot as a result. It is fine for interior use like cabinets but not for outdoor use. 1 Share this post Link to post Share on other sites
ebinmaine 79,745 #18 Posted June 8 29 minutes ago, 953 nut said: White oak is well worth the extra money because white oak is significantly more rot-resistant than red oak. Red oak is porous open grained wood and will warp and rot as a result. It is fine for interior use like cabinets but not for outdoor use. I realize that and thank you. This particular application is going to be a little different from most. The truck is stored indoors and likely will never see winter. Most people probably aren't aware of it, but there are thousands of wooden flatbeds on the road that are made out of red oak. As long as it is well treated and/or allowed to dry thoroughly, it lasts for years. This bed will do both. Share this post Link to post Share on other sites
Sparky-(Admin) 25,964 #19 Posted June 8 Personally I would opt for a manufactured aluminum or steel flatbed. Just bolt it on and go after it gets back from having the rear axle done. This way you can start using it, as opposed to having it still outa commission for weeks/months/years etc. This is just an example, plenty of less expensive steel ones for sale. 8 Share this post Link to post Share on other sites
peter lena 9,954 #20 Posted June 8 @ebinmaine nice project , suggest https://www.google.com/search?q=wood+anti+rot+lubrication&rlz=1C1CHBF_enUS866US866&oq=wood++anti+rot+lubrication+&gs_lcrp=EgZjaHJvbWUyBggAEEUY also very related is the totally open body seam areas , now is the time , with total access to every concealed , seam moisture holding area / spot area , lubrication in a closed , area will literally show you its tracking , those dry rusty leaf springs , fords , no drain moisture holding , frame mounts , every spot welded , connection , has a lubrication related , lower , vent drain area , VERIFYING , creep / tracking . basic , lighter aerosol creeping penetrant , finds / shows you the way , then open gear / chain and cable lubrication . for me its a no brainer ? none of my stuff has body rot / rust , eliminate the starting areas . trucks are an awesome opportunity , to stop rust , glairing to me , now is the opportunity , oily pete 1 Share this post Link to post Share on other sites
squonk 47,448 #21 Posted June 8 58 minutes ago, Sparky said: still outa commission for weeks/months/years etc. Situation normal! 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,808 #22 Posted June 8 3 hours ago, squonk said: Bed or Colossus? This will be the trail cam pic at @ebinmaine's place shortly after Colossus makes its first run... 5 Share this post Link to post Share on other sites
dodge78 135 #23 Posted June 8 Here is a bed I built some years ago. The sides would come off by loosening 2 bolts. In had a pin at the top with 2 clamps at the bottom and was as solid as a stock box. Solid enough I used the stock hardware to make a functioning tailgate. I cut the end of a box off that had the catches and straps to hold the tailgate. I used strap hinges so I could remove the tailgate and put a solid rod into to lock in the ramps. I put metal over the tires to keep the height lower and were removable so I could put in a flat piece if needed. But I do not think I ever needed to. This was built the size of a bed liner so it was smaller. 3 1 Share this post Link to post Share on other sites
JoeM 10,101 #24 Posted June 8 worked with a guy that had an old Chevy square body custom deluxe, His wood bed was pretty simple. Just put 4x4's across notched for u bolts and screwed on 2x8's on the top. He left the step bumper on. Only mistake, he did not measure between the axle stops and the axle. ended up notching out some wheel wells. If he used a 4x6 as cross pieces it would have cleared and the bed would have been nice and flat. with no wheel wells. He used treated lumber. I know he had that truck running at least 10 years and never rotted. 1 Share this post Link to post Share on other sites
ebinmaine 79,745 #25 Posted June 8 7 hours ago, Sparky said: Personally I would opt for a manufactured aluminum or steel flatbed. Not into steel but aluminum looks ok. Pricewise though .. it's just not happening. Note the size I want. That's not a standard. Specially built beds are several thousand dollars. 7 hours ago, Sparky said: Just bolt it on and go after it gets back from having the rear axle done. There's no simple installation here. In order to install a 7 x 9 bed I need a pair of rear frame extensions. Those will be custom pieces. 7 hours ago, Sparky said: This way you can start using it, as opposed to having it still outa commission for weeks/months/years etc. Not having a bed doesn't matter for towing or test driving. I can drive it legally as soon as I get proper rear lamps and splash guards installed. Share this post Link to post Share on other sites
