AHS 1,544 #1 Posted July 20 Im having trouble finding out where i want it. Do the do better at pushing or pulling fuel? On a 312 to Kohler 18 magnum! Show pictures of all of “em! Especially twins… i just cant find space, unless the fuel pump is right under the shift lever! And go!! Share this post Link to post Share on other sites
squonk 43,769 #2 Posted July 20 Push! Put it as close to the tank as possible. 1 Share this post Link to post Share on other sites
wallfish 18,076 #3 Posted July 20 As long as it's located below the tank fuel will gravity feed to the inlet. 1 1 Share this post Link to post Share on other sites
oldlineman 1,537 #4 Posted July 20 Not a twin but this is where I put mine holes already there! 6 Share this post Link to post Share on other sites
oldlineman 1,537 #5 Posted July 20 Have since replaced the fuse holder with a weather tight one, as recommended by members here. Bob 5 Share this post Link to post Share on other sites
Ed Kennell 41,896 #6 Posted July 20 1 hour ago, AHS said: Do they do better at pushing Yes, keep it as close to the tank and as low as possible. And replace the 30yo valve and clogged screen in the tank. And keep the tank full. The goal is to never allow the pump to run dry. If you run out of fuel, the engine will stop, but the fuel pump will continue to run, overheat and die. 3 Share this post Link to post Share on other sites
adsm08 3,198 #7 Posted July 20 @Ed Kennell has it spot on. Electric pumps want to push, they are very bad at pulling because the impeller doesn't produce vacuum like a mechanical diaphragm pump will. The closer to the tank, and the lower on the tractor you can mount it, so that it gets fuel very quickly, and gravity does most of that work, the better, and don't run it dry. This is why on cars we put them right in the tank. 2 Share this post Link to post Share on other sites
953 nut 59,878 #8 Posted July 20 In my opinion the best electrical supply for your pump will be the wire feeding the volt meter / hour meter because it is fuse protected and is off when the ignition switch is off. 2 Share this post Link to post Share on other sites
squonk 43,769 #9 Posted July 20 I fuse a wire right off the coil primary wire from the switch 1 1 Share this post Link to post Share on other sites
midpack 1,009 #10 Posted July 20 The last one I put in right under the seat pan, not sure if took a pic but I'll look 1 Share this post Link to post Share on other sites
midpack 1,009 #11 Posted July 20 This is where I put it (excuse the mess, it's a worker) 3 Share this post Link to post Share on other sites
AHS 1,544 #12 Posted July 20 @midpack that’s alright! Aren’t Wheelhorses supposed to be workers? 1 1 Share this post Link to post Share on other sites
lynnmor 7,812 #13 Posted July 20 5 hours ago, midpack said: This is where I put it (excuse the mess, it's a worker) But that is where the rear lift goes. 1 Share this post Link to post Share on other sites
pfrederi 18,643 #14 Posted July 20 If you want a rock shaft that location will not work... But only 2 out of my 18-20 horses use the rock shaft...so that is where i put my pumps. 1 Share this post Link to post Share on other sites
c-series don 9,984 #15 Posted July 21 10 hours ago, AHS said: @midpack that’s alright! Aren’t Wheelhorses supposed to be workers? Answer: NOPE 🤣🤣🤣 6 Share this post Link to post Share on other sites
kpinnc 14,620 #16 Posted July 21 Both mine are like this: 1 Share this post Link to post Share on other sites
oldlineman 1,537 #17 Posted Monday at 12:16 PM I fed mine from the headlight circuit since I rarely use headlights, I simply unplugged the ground side of the headlights and I have a kill switch using the headlight switch. Bob 1 Share this post Link to post Share on other sites
Ed Kennell 41,896 #18 Posted Monday at 12:35 PM I feed mine from the plus side of the coil. I also put a switch in line and sometimes turn off the pump after start up. Some tractors run W/O a pump. 1 Share this post Link to post Share on other sites
adsm08 3,198 #19 Posted Monday at 10:27 PM Not sure if the points would handle the load, but personally I'd prefer to run the hot right off the battery and piggyback the coil's ground. That way if the engine ain't spinnin' the pump isn't running, regardless of key position. Although I'm not sure if a 312 has points. Share this post Link to post Share on other sites
kpinnc 14,620 #20 Posted Tuesday at 03:33 AM All the magneto key switches have the light or accessory tab. Pretty easy to run direct from that to the pump. If the key is off, the pump is off. Only down side is the voltmeter takes a hit. When you flip the keyswitch into the first detent, the pump drags down the battery voltage to about 11VDC. 2 Share this post Link to post Share on other sites
midpack 1,009 #21 Posted Tuesday at 10:17 AM I tapped into the light circuit to power a relay that draws directly from the battery to run electric fuel pumps. Less drain on old wiring 1 Share this post Link to post Share on other sites
953 nut 59,878 #22 Posted Wednesday at 12:08 AM On 7/20/2025 at 9:33 AM, squonk said: I fuse a wire right off the coil primary wire from the switch This is a magnum. 20 hours ago, kpinnc said: pump drags down the battery voltage to about 11VDC. Indicated voltage as seen by the meter, battery voltage should not be affected. The low pressure pumps draw one amp or less, shouldn't be a problem. 2 Share this post Link to post Share on other sites
702854boy 80 #23 Posted Wednesday at 02:22 AM This is on an 854 that we just got the other day and it was not installed by us. 1 Share this post Link to post Share on other sites
squonk 43,769 #24 Posted Wednesday at 10:33 AM 10 hours ago, 953 nut said: This is a magnum. I don't own a Magnum so that's where I put it. 1 Share this post Link to post Share on other sites
AHS 1,544 #25 Posted Wednesday at 10:57 AM @c-series don if i had a 420LSE…..it would be hard to find a place for it, there is worker wheel horses everywhere! I would have to find room for it where the workers are not, so the workers wouldn’t get jealous!! 1 Share this post Link to post Share on other sites
