ebinmaine 80,708 #26 Posted July 11, 2025 @PWL216 This chassis look familiar? 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #27 Posted August 18, 2025 (edited) Oops it’s been a while since I updated the thread… Since the last update I have Put the hood on, Tightened down the sheet metal. built a battery hood down and an exhaust pipe with a brace. Made a lexan headlight lens and got the head lights working. Painted the rims. Then, started in painting the sheet metal. That’s where I’m at today. Edited August 18, 2025 by MainelyWheelhorse 1 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #28 Posted August 20, 2025 This was today’s progress after work. Four coats of Rust - Oleum IH red paint by spray gun. It’s a worker so I’m not necessarily going for show quality. Almost at the finish line. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #29 Posted August 20, 2025 Excellent 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #30 Posted August 21, 2025 Today’s progress, just decals, throttle and choke handles with some fine tuning now. Inching closer to the finish but it’s now a runner. 9 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #31 Posted August 24, 2025 With the exception of a few small things My 1978 C-141 Frankenstein is done. I would like to thank everyone who chimed in to assist in getting it running and painted. @ebinmaine @953 nut @pfrederi definitely contributed to getting the tractor going especially the wiring. There were many more contributions by other members as well. Just for you late arrivals it went from this, to this. In 3 1/2 months. THANKS!!! 7 Share this post Link to post Share on other sites
ebinmaine 80,708 #33 Posted August 24, 2025 1 hour ago, SylvanLakeWH said: Excellent transformation!! 1 1 Share this post Link to post Share on other sites
kpinnc 18,965 #34 Posted August 24, 2025 6 hours ago, MainelyWheelhorse said: In 3 1/2 months. And gain another 30-40 years of service. Not a bad trade! 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #35 Posted August 24, 2025 9 minutes ago, kpinnc said: And gain another 30-40 years of service. Not a bad trade! Yeah, that’s the plan, now to figure out what do do with it.😁 1 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #36 Posted October 18, 2025 (edited) After a bit of a hiatus, I bought some decals.These should finish the tractor off nicely, with the exception of the hydraulics. Edited October 18, 2025 by MainelyWheelhorse 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #37 Posted October 18, 2025 1 minute ago, MainelyWheelhorse said: the hydraulics. I might just have that set up here! Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #38 Posted October 19, 2025 7 minutes ago, ebinmaine said: I might just have that set up here! @ebinmaine Cool, I didn't forget EB, That's the next big thing to complete. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #39 Posted October 28, 2025 I made a bit more progress on the C-141 tonight. I received my full decal kit from Redo your Horse (Terry) and began the process of installing it. It definitely changes the look of the tractor in a good way. 1 3 Share this post Link to post Share on other sites
ebinmaine 80,708 #40 Posted October 28, 2025 8 minutes ago, MainelyWheelhorse said: definitely changes the look of the tractor in a good way. Niiiiice!!! 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #41 Posted October 2 (edited) So after a bit of a hiatus, I got the hydraulics from @ebinmaine for the C-141. After getting the belcrank out of the 520 center section, I cleaned it up, and installed it in the C-141. I then cleaned up the valve block, and after building a plate to mount it I semi temporarily installed it. It was a bit of a PITA to put in. While I was working on the valve bock and bell crank. I painted the hydraulic ram and installed it after the paint dried. The only thing left is to install the hard lines if possible, with some adapters. Or and the more likely route, some rubber lines to be able to snake the connections around the C-141’s slightly different mounting locations. And that’s where I am now. Edited October 2 by MainelyWheelhorse 4 1 Share this post Link to post Share on other sites
