MainelyWheelhorse 2,327 #1 Posted May 27, 2025 (edited) Ok, the next door neighbor is cleaning out. So, he came over and asked if I wanted an old K series Kohler from a RV generator. He knew I had a Magnum 12 I was working on, and figured I could use the parts if the RV engine was junk. Anyway it has K341 cast into the block on the PTO side. It looks very similar to the K321 14hp I got from @ebinmaine in my parts haul a few weeks back. It has 9 or 10 head bolts depending if you count the grounding spot to attach wires. It looks significantly bigger than the 321, so I figured it was a bigger engine. So what do I have? Thanks! now the pics… Edited May 27, 2025 by MainelyWheelhorse 2 Share this post Link to post Share on other sites
rjg854 12,842 #2 Posted May 27, 2025 With 10 head bolts its a 16hp 4 Share this post Link to post Share on other sites
Treepep 1,060 #3 Posted May 27, 2025 Says K 841. 24 hp??? 1 Share this post Link to post Share on other sites
ineedanother 1,871 #4 Posted May 27, 2025 2 minutes ago, Treepep said: Says K 841. 24 hp??? K341 - 16hp 1 Share this post Link to post Share on other sites
Ed Kennell 44,862 #5 Posted May 27, 2025 The K341G may not have the required axial thrust bearing required for a PTO 1 Share this post Link to post Share on other sites
Achto 30,992 #6 Posted May 27, 2025 Being a generator motor it should have an asymmetrical governor in it. It responds faster the the standard symmetrical governor. Sought after by pullers and no longer available. I wouldn't mind having an engine like that just for that part alone. 2 Share this post Link to post Share on other sites
oliver2-44 11,212 #7 Posted May 27, 2025 Lucky it has the straight shaft, A lot of generator engine have a tapered output shaft. 2 Share this post Link to post Share on other sites
MainelyWheelhorse 2,327 #8 Posted May 28, 2025 (edited) Thanks to all, @Achto @rjg854 @ineedanother @Treepep @Ed Kennell @oliver2-44 Now I know what I have and can get the missing/ worn parts it needs. Maybe it’ll go in the C141😁 Edited May 28, 2025 by MainelyWheelhorse 1 3 Share this post Link to post Share on other sites
Lee1977 7,552 #9 Posted May 29, 2025 On 5/27/2025 at 8:04 PM, MainelyWheelhorse said: Thanks to all, @Achto @rjg854 @ineedanother @Treepep @Ed Kennell @oliver2-44 Now I know what I have and can get the missing/ worn parts it needs. Maybe it’ll go in the C141😁 You may need an electric clutch as most generator engines don't have the ball bearings on the crank shaft. 1 Share this post Link to post Share on other sites
