Moohampshire 11 #1 Posted May 18 Rebuilding a 77 C-160 and need bushing 7879 for the PTO linkage as old bushing is defunct. Need spacer 3765 as well. Linkage was very floppy and loose. Thanks Share this post Link to post Share on other sites
ri702bill 9,378 #2 Posted May 18 Welcome!! Please post this in the Classifieds section under "Wanted". It wii get the attention it deserves there.... Share this post Link to post Share on other sites
dclarke 4,082 #3 Posted May 18 A quick search came up with this if you can’t find one. 1 Share this post Link to post Share on other sites
Lee1977 7,190 #4 Posted May 20 I drilled out mine to 5/8" and installed a brass bushings on my C-120. 1 Share this post Link to post Share on other sites
peter lena 9,251 #5 Posted May 20 @Lee1977 @dclarke lee agree with you on that , also that entire shift gate plate area , underside , likes lubrication and functional detailing , something that has always amazed me is the MOVEMENT EASE IMPROVEMENT , to linkage and levers , with minor help. sure you have seen it , weather its a cable spring pull assist , or a shoulder bolt swing point , original set up was production line fast , saving money on washers / fasteners , adds up . the 2 that I regularly , relish using , are the PTO LEVER SET UP and the , plow lever quadrant , set up , no play at all , move with out effort , spring assist cabling movement , once you correct a bad spot , you go on the hunt . stay at it , @dclarke hillman also has the machine bushings for front wheel play , # H 882395 ALSO H 882394 . put that together with lucas green chassis grease in the bearings , spindle ,related ,tell me how it works , pete Share this post Link to post Share on other sites
Moohampshire 11 #6 Posted May 20 DCklarke: Went to Ace hardware and got a 1/2 axle cap and group off bottom and then did some grinding to get off tabs and it worked great. Cost $1.19. This forum is great. 1 1 Share this post Link to post Share on other sites
dclarke 4,082 #7 Posted May 20 2 hours ago, Moohampshire said: DCklarke: Went to Ace hardware and got a 1/2 axle cap and group off bottom and then did some grinding to get off tabs and it worked great. Cost $1.19. This forum is great. Glad it worked out. @MikesRJ came up with that idea and shared it. Thanks, Mike! Share this post Link to post Share on other sites
MikesRJ 558 #8 Posted May 22 On 5/20/2025 at 3:23 PM, dclarke said: Glad it worked out. @MikesRJ came up with that idea and shared it. Thanks, Mike! Glad I could help another. 1 Share this post Link to post Share on other sites
