1968Commando 167 #1 Posted May 15 (edited) Hello all, I have a k181 Kholer and it seems it’s either wide open and sounding like it’s gonna blow up or it’s gonna idle there’s no in between and when you push it back to idle after it’s wide open it will pop pretty good and it seems to be very delayed to slow down. What do I do? And I have adjusted the governor to the manual specs and it is messed up still but I made progress because originally I couldn’t get the governor arm to move at all so that’s a positive I guess Edited May 15 by 1968Commando Share this post Link to post Share on other sites
squonk 44,096 #2 Posted May 15 I think we need a video of the governor shaft movement. I'm thinking either it's still out of adjustment or that tab on the Governor shaft (which I have seen a lot of) is broken. Share this post Link to post Share on other sites
1968Commando 167 #3 Posted May 15 3 hours ago, squonk said: I think we need a video of the governor shaft movement. I'm thinking either it's still out of adjustment or that tab on the Governor shaft (which I have seen a lot of) is broken. Ok I’ll get a video shortly im having issues with videos sending though Share this post Link to post Share on other sites
1968Commando 167 #4 Posted May 15 3 hours ago, squonk said: I think we need a video of the governor shaft movement. I'm thinking either it's still out of adjustment or that tab on the Governor shaft (which I have seen a lot of) is broken. Well it turns and stops so I assume it’s still there correct or could it be jammed in there? Share this post Link to post Share on other sites
rjg854 12,353 #5 Posted May 15 1 hour ago, 1968Commando said: Ok I’ll get a video shortly im having issues with videos sending though A membership to Red Square would solve that problem Share this post Link to post Share on other sites
1968Commando 167 #6 Posted May 15 7 minutes ago, rjg854 said: A membership to Red Square would solve that problem Yeah…I suppose it would but I’m just not in the market for that right now but in the future definitely Share this post Link to post Share on other sites
1968Commando 167 #7 Posted May 15 6 minutes ago, 1968Commando said: Yeah…I suppose it would but I’m just not in the market for that right now but in the future definitely Cleared some old stuff I’ll come back with a video @squonk and @rjg854 that way maybe you guys can help me out? Share this post Link to post Share on other sites
wallfish 18,423 #8 Posted May 16 2 hours ago, 1968Commando said: but I’m just not in the market for that right now But you are exactly "in the market" right now with needing help and suggestions. It's what keeps the lights on around here and allows people to help you! Take a look at all the names in RED that have been and are currently trying to help you so far. They are supporters. It's not necessarily about whether you can post more pics and videos or not. 2 Share this post Link to post Share on other sites
1968Commando 167 #9 Posted May 16 (edited) 2 hours ago, wallfish said: But you are exactly "in the market" right now with needing help and suggestions. It's what keeps the lights on around here and allows people to help you! Take a look at all the names in RED that have been and are currently trying to help you so far. They are supporters. It's not necessarily about whether you can post more pics and videos or not. Dang you are a great salesman, I am going to consider it now, the issues is I would have to run it by My parents as I am under 18 and am just trying to keep a part of history running and going, I do appreciate all the nice people on here and the help is greatly appreciated especially because I’m just a 16 year old trying to keep these around for people that don’t even know what they are to see Edited May 16 by 1968Commando 1 Share this post Link to post Share on other sites
Racinbob 12,043 #10 Posted May 16 Throttle response throw on every small block K I've had has received this modification. I've posted this picture numerous times. Assuming you have the governor properly adjusted and everything is connected correctly this will do wonders for the tiny throw. Share this post Link to post Share on other sites
1968Commando 167 #11 Posted May 16 3 hours ago, Racinbob said: Throttle response throw on every small block K I've had has received this modification. I've posted this picture numerous times. Assuming you have the governor properly adjusted and everything is connected correctly this will do wonders for the tiny throw. How did you attach that piece is it welded can I figure out someway to do this without a welder? Currently I have no arm and the wire connects right into the holes on the disc Share this post Link to post Share on other sites
1968Commando 167 #12 Posted May 16 3 hours ago, Racinbob said: Throttle response throw on every small block K I've had has received this modification. I've posted this picture numerous times. Assuming you have the governor properly adjusted and everything is connected correctly this will do wonders for the tiny throw. Last year when the throttle cable my uncle had on this tractor broke it was aftermarket because the original broke, I put a new push pull throttle on it and I honestly didn’t then read the manual I just hooked it back j the bolt that is on the governor arm that the spring goes into and I got way better throttle response then what I have now, should I go back to that or does that make the governor not work right? Share this post Link to post Share on other sites
Racinbob 12,043 #13 Posted May 16 52 minutes ago, 1968Commando said: How did you attach that piece is it welded can I figure out someway to do this without a welder? Currently I have no arm and the wire connects right into the holes on the disc I tapped two of the existing holes in the round disc. I don't remember if I used 6-32 or something a fuzz smaller. You have to be very aware of clearance. I ground some to clear the brass nut. Share this post Link to post Share on other sites
wallfish 18,423 #14 Posted May 16 18 hours ago, 1968Commando said: I do appreciate all the nice people on here and the help is greatly appreciated especially because I’m just a 16 year old Ah, now I see. How about I cover you for becoming a supporter then? I'd prefer you put the money have into your tractor. We need young members as most of us are all old farts. 6 Share this post Link to post Share on other sites
1968Commando 167 #15 Posted May 16 8 hours ago, Racinbob said: I tapped two of the existing holes in the round disc. I don't remember if I used 6-32 or something a fuzz smaller. You have to be very aware of clearance. I ground some to clear the brass nut. A 6.32 tap, so it’s bolted on? Share this post Link to post Share on other sites
1968Commando 167 #16 Posted May 16 12 minutes ago, wallfish said: Ah, now I see. How about I cover you for becoming a supporter then? I'd prefer you put the money have into your tractor. We need young members as most of us are all old farts. No no It’s ok, I can’t ask you to pay for a support membership for me, I will most likely buy it here soon Share this post Link to post Share on other sites
Racinbob 12,043 #17 Posted May 16 Yes. I also used JBWeld. No nuts on the backside. It needs to be ground smooth. Share this post Link to post Share on other sites
1968Commando 167 #18 Posted May 16 Just now, Racinbob said: Yes. I also used JBWeld. No nuts on the backside. It needs to be ground smooth. Ah ok, so tap the holes in the disc, cut a piece of metal and attach it, cut the bolts to fit, and then hookup and go Share this post Link to post Share on other sites
Racinbob 12,043 #19 Posted May 16 Yup, that's it. I just run the bolts thru and let it sit until the JB sets up and then carefully grind the bolts flush. Share this post Link to post Share on other sites
wallfish 18,423 #20 Posted May 16 Just now, 1968Commando said: No no It’s ok, I can’t ask you to pay for a support membership for me, I will most likely buy it here soon You didn't ask, I offered so that's different. Surely you don't want to hurt an old man's feelings do ya? 1 1 Share this post Link to post Share on other sites
1968Commando 167 #21 Posted May 16 49 minutes ago, wallfish said: You didn't ask, I offered so that's different. Surely you don't want to hurt an old man's feelings do ya? Well okay if you would really like too buy it for me and gift it to me, I would greatly appreciate the kind gift, thank you for the kind gesture sir. 1 Share this post Link to post Share on other sites
1968Commando 167 #22 Posted May 16 50 minutes ago, wallfish said: You didn't ask, I offered so that's different. Surely you don't want to hurt an old man's feelings do ya? In your profile picture is that your loader tractor? Share this post Link to post Share on other sites
wallfish 18,423 #23 Posted May 16 13 minutes ago, 1968Commando said: In your profile picture is that your loader tractor? It was. @ebinmaine Eric owns it now. 1 Share this post Link to post Share on other sites
wallfish 18,423 #24 Posted May 16 21 minutes ago, 1968Commando said: Well okay if you would really like too buy it for me and gift it to me, I would greatly appreciate the kind gift, thank you for the kind gesture sir. 20 hours ago, 1968Commando said: Dang you are a great salesman, YUP ! Sold, your name is now red so your storage should make it easier to post pics and videos. We mostly upload videos to Youtube and then link them here as videos can suck up a lot of storage space. 2 Share this post Link to post Share on other sites
ebinmaine 73,612 #25 Posted May 16 54 minutes ago, wallfish said: It was. @ebinmaine Eric owns it now. Really? >> me? << Or is it Trina's?? 1 Share this post Link to post Share on other sites
