Similar Content-
			 By tractorboy79 By tractorboy79
			 By BuffaloD200 By BuffaloD200
 '74 D-180
 My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
 I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
 So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
 So my thoughts are grab a BFH or sparky the blue tip wrench.
 Is there an unpublished step 3.5, or some trick?
 Hey all, I need to install a drive belt on my 75 D180 for my snowblower. I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure. The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell. Do I have to remove the PTO pulley? That seems to be a required service item.
 Same question for my 80 D200 as well really.
 Using the recommended 4L490W belt.
 Thanks
			 By ihatephones By ihatephones
 I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
 Where can I get one that's not on eBay for $200?
 I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
