Keaton
RJ 59 throttle help
Keaton
i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
Keaton
anyone got any ideas?
peter lena
@Keaton   snoopin around  mainly looking for related pictures , found this  , mix and match  , might get you started , pete
squonk
Lever is on the right side of the hood sitting on the tractor cable goes across the hood to the left and through the hole in the hood. Then down the left side of the engine then loops across the bottom and then goes up the right side of the engine from the bottom to the throttle linkage.
Keaton
 @squonk that will not fit through the hood with that tab and it will not move at all, i will try to put it in a vice and put some pennatrating oil on it and try to work it around and see if it will move, where does it hook on down below? does it hookup to that circle on the govner?
squonk
Pry off that tab and recrimp after you get the cable to move and you get it through the hole. Yes it connects to the circle disc.
wallfish
Just going by pics but it's hard to tell
Is that long bracket welded to the disc? If so, it's WAY too long.
Is there another smaller bracket hanging down behind the disc? That's the bracket in which the cable conduit and that tab connects to in order to hold it. The wire connects to the disc but havingb a short bracket on the disc allows for a much easier throttle control
squonk
@Lane Ranger You have any pics to help him out?
Keaton
@wallfish that is a long bracket, just got it dont know what it is for
Keaton
@Pullstart i know you have a few RJs u got a few pics or could you take a few if you would not mind.
Pullstart
Here you go!  I kept forgetting to go snap some pictures for you, thanks for the tag :handgestures-thumbupright:
Pullstart
I found another K91 in the shop, with a different routing.
I think the one I posted earlier is correct, but the engine won’t care if you have to change it up.
peter lena
@Pullstart  that tractor  rop of dash cable routing also supports / enhances , cable lube , been experimenting with  3 in 1 penetrating oil  very good creep action , have also experimented with cable spring to close action , that way , at connection point you always have a spring assist to improve movement . have that on my 3 units , cables move with out effort , pete
wallfish
I know it's a long bracket. It just doesn't belong there. Again, is it welded to the disc?
squonk
My RJ had the cable coming down the front of the engine on the recoil side and looped across from the bottom and attached like this picture.
Keaton
@wallfish that is welded on there, i might cut it off and re drill that out from the back, i need to get it done before sauterday for a car show to put in the back of my friends truck
wallfish
OK, Since it's already on there leave about 1 inch of it on the disc if you cut it off. That way you can always drill a small hole for the throttle wire about 3/4 inch away from the disc edge. That extra length away from the disc will give it much better throttle control vs connecting the wire directly to the disc. But you don't need to do that right away just to get it going.
Loosen that brass nut with a 3/4" wrench so that other bracket behind the disc will swivel, so now you can connect the conduit to it like the pics above with that clamp. Notice how it is not positioned directly straight down like yours is? Connect the wire directly to the disc like above to get her going. If you find the throttle control is to sensitive and fast, then you can still use that other bracket on the disc to better control the throttle response.
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • wh315-8
      By wh315-8
      Grandpa wouldn't line up in right way.  Stubborn. Nice day today, got some of my herd out. 315-8 w/42" deck to mow. D200 to disc w/tandem disc. 520H w/36" tiller. And RJ59 with 36" Parker Sweeper. These horses done me well today.
    • 12 hp Kohler
      By 12 hp Kohler
      Picking up an rj59 tomorrow that’s missing the drive belt. What size should the belt be ?
      Thanks in advance.
    • Robert Concato
      By Robert Concato
      Hi I'm new to site. I am looking for a gas tank for an RJ 35 Tractor any help would be great thanks!
    • wh315-8
      By wh315-8
      Looking for the measurements for items #69 mounting bracket and #79 lifting rod. So that I could fabricate and be able to install on my RJ59. Any pics of the mounting bracket would be a big help.
