sjoemie himself
Case International 585
sjoemie himself
Aaand then a gust of wind took out one of the doors. Definetely NOT what I was planning to do this afternoon..
Note: yes the door, what's left of it anyway, is in horrible condition and I would love to replace it. Some hurdles to take before that can happen though.
  • Sad 3
sjoemie himself
Posted (edited)
First official upgrade to the Case International. It needed some front fenders badly. Took the tractor out in the rain a few times, last time together with one of my  nephews and we got plenty of water and mud flung onto our faces.. no bueno.. although my nephew did'nt seem to care :lol:
Gathered up some flat bar stock and started puzzeling. Turns out nothing is flat, square and/or plumb on a front axle like this so there were quite a few tricky angles to get right.
My dad rolled a hoop which I used to make part of the main frame with.
Looked at some pictures on the interwebs for inspiration and (imho) improved the design to my liking. Top bolts onto an exsisting bolt which I replaced with an longer one. The bottom wraps around the wheelhub with an exhaust bolt (if that even is a word in English).
Bolted the fenders to the brackets with some carriage bolts and self locking nuts.
Done! Don't know why but I always really like the look of front fenders on 2wd tractors.
Thanks for watching!
Edited by sjoemie himself
Added picture
  • Like 3
  • Excellent 4
  • Heart 1
sjoemie himself
Posted (edited)
Have been busy the last couple of weeks. The Inter is running well until it did'nt.. fuel issue.. the tank was al plugged up with dirt and debris. I unclogged it and installed a see though pre-filter along with new fuelfilters. Runs much better now.
Still have to properly clean the tank though.
Also carried out maintenance on the entire machine, changed all the fluids and filters minus coolant.
Also fixed both leaky PTO seals.
Bearings are excellent, shafts do have some minimal wear but nothing a new shaft seal won't fix.
Now no more leakage detected.
After that it was time for the first 'real' test.. cleaning up years of accumulated dirt, grass, weeds and what not to uncover the concrete slabs that were hidden underneath.
I thoroughly enjoyed this little job and the tractor did excellent. I'm kinda getting why all you guys are always going on about 'seat time' :D
Added info
  • Excellent 4
sjoemie himself
Gave the Inter the 'ol greasy @peter lena oil rubdown treatment, shined her right up!
  • Excellent 4
peter lena
@sjoemie himself  as you know , a lubrification rub down / recovery  , is so simple  / easy to do , once its in  place , its steadily  gaining  / correcting  neglect .  usually do that first on , any  mechanical pick up . forget about it , get on with the serious stuff , then  rub it down , re apply  you're good . have to mention , obviousely  do not  personally know you , but back in the day , having you  as a solid work partner , would be my first choice  !  always thinking out of the box , adapting to any issue , think  i would turn those carriage fender bolts over,  have nuts top side , reduce nut crud pick up . thank you for your regular , idea sharing  , pete
  • Thanks 1
sjoemie himself
Thank you for your kinds words Peter, much appreciated!
I agree with you that the bolts turned the other way around would pick up less junk but in this Case (pun intended) I chose form over function, I just like the shiny smooth side up better.
I will however, after you pointing this out, give the bolts a proper coppergrease/neversneeze coating when I definitifely install the fenders, still gotta get them painted or powdercoated after some final tweaks.
sjoemie himself
Played in the dirt today. The goal was to loosen the paddock so that it would dry quicker. Looking promising so far and had a BUNCH of fun ofcourse.
  • Excellent 2
sjoemie himself
After playing in the dirt last time I found that the cultivator/implement was a little long for my liking. Especially in the corners and near fence posts this is not ideal.
So I decided to shorten it and re-mount the tines on the two front rows of the cultivator.
Before, five rows of tines:
After, two (and a half) rows of tines:
Before:
After:
Also added some reinforcements on the upper lifting point since it was showing some cracks.
Still some room for improvements but I like it a lot better now. Much more nimble and less rear swing (don't know the right word) when working close to the fence.
Still want to add a roller of some sorts to 'crumble' the clumps a bit more.
  • Excellent 1
ebinmaine
That's a perfectly fine word assortment to me. Nice work on that implement.
  • Thanks 1
bds1984
On 3/15/2024 at 9:33 AM, sjoemie himself said:
Seeing this makes me remember the headaches from sanding, all the dust, and the smell even with a mask on!  I hope your vacuum attached to that is able to keep up!
sjoemie himself
The itching and the headaches from the smell were something else, I might have lost a few braincells in the process :scratchead:
One of my el-cheapo shop vacs gave up the ghost during sanding, kinda says something about the nasty dust. To be honest though it was on it's way out before this job..
  • Similar Content
    • PWL216
      By PWL216
      I have for sale a 1984 C-105 with deck and Snowblower. I got this as part of a package. There’s no battery and I haven’t tried to start it. I’m selling it as a project. The deck has one spindle out, but with it, as prior owner claims bearing was replaced. The snowblower has the flag and looks to be in very good condition. All but 1 tire holds air. The mower is complete. Includes mule drive. The extra hood (c-175) you see in the picture can go with the tractor for an additional $50. Thx for looking.
    • OldWorkHorse
      By OldWorkHorse
      Working on a custom light bar for the recently restored 314-8
    • JZilla024
      By JZilla024
      Hello everyone!
      I recently inherited my grandpa's
      Wheel Horse 753. I remember it running before his health declined about 15 years ago. My intentions are just to get it running and do a mild restoration, it'll stay in the family.
      Without further ado, here it is!
      Having a hard time with pictures due to no phone service at my shop. I'll be sure to update soon.
    • Rollerman
      By Rollerman
      I find myself checking out the "Other Brands" thread quiet a lot....& feel a little guilty for not being a Wheel Horse purist.
      The three Horse's I have do me fine, sure I'd like to have a couple more round hoods when & if I ever get my pull barn up....maybe a Speedex, one of them green round fenders, Powerking, etc, etc...
      So to get this thread on track & end my rambling, I like the odd ones, hand built or obscure GT's that never caught on (see my Homesteader thread).
      Whatchamacalit, I'm not sure what else to call this or what thread this should go under.
      But Odd & Obscure fit it pretty good.
      I believe it was built as a parade car?
      It's 11' long & 55" wide, powered by an 8HP B&S, with a belt driven 3 speed car trans &  a car type rear axle.
      No suspension & with all the weight towards the front, if the front end dips low enough to lift a back tire....there it sits.
      What I have....a 22HP Predator engine, a HD 8 speed from a C series, a pair of Samurai axles & driveshaft's.
      Maybe some 26" ag's or bigger, have to do some math, see what kid of gearing I would have in the axles & at the drive from the engine to the trans.
      For suspension I'm thinking maybe a transverse leaf at the front & golf cart leaf springs in back.
      Anyone seeing where I'm going with this?
      Isn't it fun to dream & ramble.....
