lynnmor 7,786 #101 Posted April 12, 2024 All of my mower deck mule drives are tilted out leaving plenty of slack in the specified belt when tension is released. I suppose this is by design to make it easy to remove and install the deck. 1 Share this post Link to post Share on other sites
ebinmaine 72,330 #102 Posted April 12, 2024 Loaded up and ready! 2 1 Share this post Link to post Share on other sites
ebinmaine 72,330 #103 Posted April 13, 2024 Delivered the C121 today! Got to say hi in person to @PWL216. Great to see you as always. My father got a quick lesson in operations and drove across the yard to the new home. He mentioned it would be a learning curve but that he did like the Motion Control Lever setup.. 1 2 Share this post Link to post Share on other sites
ebinmaine 72,330 #104 Posted September 2, 2024 Folks I could use a little help with adding appropriate safety switches. My mom wants to have a good mower on hand so various people can use it. These people would be known good operators with common sense and instruction. Mom doesn't want anyone to be taking chances so we're considering adding whatever switches would run the PTO and foot pedal. How do I find these switches? What years range would they have been on? Maybe a schematic diagram available? 2 Share this post Link to post Share on other sites
c-series don 9,959 #105 Posted September 2, 2024 (edited) @ebinmaine There’s three, one for the PTO, one for the brake pedal and one for the seat switch. You’ll need to get the wiring schematic which as you know is available here. Brian at K+B Wheel Horse Parts may have what you need. Edited September 2, 2024 by c-series don 1 1 Share this post Link to post Share on other sites
953 nut 59,716 #106 Posted September 2, 2024 Eric, as shown in the wiring diagram for the C-XX1 there were PTO, seat, and brake peddle switches on the tractor as built. We should be able to find good replacement switches by going through the IPL for the C-121. I don't remember if you covered your wiring in this post but the diagram below shows how the safety switches fit into your wiring. I will go back through this thread to refresh my memory about your wiring. 1 1 Share this post Link to post Share on other sites
953 nut 59,716 #107 Posted September 3, 2024 On 12/11/2023 at 8:18 PM, Sparky said: Tractor looks pretty darn good in the pics… I estimate it’ll take a 42 page thread to complete Anyone else wanna take a guess ! So far we are only up to five pages and it has been nearly a year.........Lets get to work boys and girls, @Sparky wants thirty seven more pages of posts and we only have three months to do it! 4 Share this post Link to post Share on other sites
SylvanLakeWH 28,296 #108 Posted September 3, 2024 11 minutes ago, 953 nut said: So far we are only up to five pages and it has been nearly a year.........Lets get to work boys and girls, @Sparky wants thirty seven more pages of posts and we only have three months to do it! That will be a colossal task... involving feats of literary endurance that only Colossus could perform... 4 Share this post Link to post Share on other sites
953 nut 59,716 #109 Posted September 3, 2024 Eric, having looked over the photos in your post it appears you used the wiring from the C-121 so the PTO switch may be there already. Any single pole normally open momentary pushbutton switch that will be activated by the seat pushing down on its springs will be fine for the seat switch. Without weight in the seat the two springs will hold the seat up far enough to keep the switch open and cut off power to the coil. https://www.google.com/search?q=single+pole+normally+open+momentary+push+button+switch&rlz=1C1JZAP_enUS981US981&oq=single+pole+normally+open+momentary+&gs_lcrp=EgZjaHJvbWUqBwgFECEYqwIyCQgAEEUYORifBTIHCAEQIRigATIHCAIQIRigATIHCAMQIRigATIHCAQQIRigATIHCAUQIRirAtIBCTQyNzEzajBqN6gCALACAA&sourceid=chrome&ie=UTF-8 A very similar switch could be mounted to a shop built bracket where the switch would be compressed when the brake pedal is depressed all the way. The wire from the "S" terminal of the ignition switch that goes to the solenoid would go through this switch. With the brake pedal pushed down the switch would close allowing power to go from the ignition switch to the solenoid, if the pedal is not pushed down the key switch will not be able to close the solenoid. Hope this helps you. 2 Share this post Link to post Share on other sites
ebinmaine 72,330 #110 Posted September 3, 2024 1 minute ago, 953 nut said: Hope this helps you You bet it does!! 1 hour ago, SylvanLakeWH said: That will be a colossal task... involving feats of literary endurance that only Colossus could perform... You'll be happy to know that my thought processes about processing thoughts are still in play on that Beast. 1 3 Share this post Link to post Share on other sites
ebinmaine 72,330 #111 Posted September 3, 2024 The Ugly Bruce got a good scrubbin today in preparation for being shown at @JCM Jim's Meet n Greet this weekend. 6 Share this post Link to post Share on other sites
gt14rider 942 #113 Posted September 23, 2024 The safty swicth 101845. Toro has them $60/$80. Found and used one of these Cole horse neutral safty switch, works great. Also found some on Amazon 1 2 Share this post Link to post Share on other sites
ebinmaine 72,330 #114 Posted November 23, 2024 Got me a parts tractor to make The Ugly Bruce a hydro lift. 2 4 Share this post Link to post Share on other sites
Bar Nuthin 1,013 #115 Posted November 23, 2024 On 12/11/2023 at 8:18 PM, Sparky said: Tractor looks pretty darn good in the pics… I estimate it’ll take a 42 page thread to complete Anyone else wanna take a guess ! I'll take the over bet 4 Share this post Link to post Share on other sites
Bar Nuthin 1,013 #116 Posted November 23, 2024 3 hours ago, ebinmaine said: Got me a parts tractor to make The Ugly Bruce a hydro lift. Wait! You can do that? 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,296 #117 Posted November 23, 2024 10 minutes ago, Bar Nuthin said: I'll take the over bet Way over... 1 4 Share this post Link to post Share on other sites
ebinmaine 72,330 #118 Posted November 23, 2024 11 minutes ago, Bar Nuthin said: Wait! You can do that? I can. I'm magic. 2 Share this post Link to post Share on other sites
Ed Kennell 41,763 #119 Posted November 24, 2024 15 minutes ago, ebinmaine said: I can. I'm magic. Eric The Magic Bear 5 Share this post Link to post Share on other sites
Bar Nuthin 1,013 #120 Posted November 24, 2024 3 hours ago, ebinmaine said: Got me a parts tractor to make The Ugly Bruce a hydro lift. Following! 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,296 #121 Posted November 24, 2024 20 minutes ago, Ed Kennell said: Eric The Magic Bear Oh man... visuals alert... My eyes... my eyes... can't feel my eyes...!!! 1 1 1 Share this post Link to post Share on other sites
Ed Kennell 41,763 #122 Posted November 24, 2024 41 minutes ago, SylvanLakeWH said: Oh man... visuals alert... My eyes... my eyes... can't feel my eyes...!!! Oh, now I see it...the seat. 3 Share this post Link to post Share on other sites
ebinmaine 72,330 #123 Posted November 28, 2024 The BBT aka Local Computer Personnel spent some time helping me 🐻 download and print a few things today. Thanks to @pfrederi for sharing the link to the Sundstrand manual. Thanks to @cleat for posting his fantabulous threads. Excellent information. Also thanks to those that commented on my other thread about making an assisted lift. Share this post Link to post Share on other sites
