RJC1965 173 #1 Posted October 28, 2023 I am in need of replacing my front and rear tires on my 520h with a Kwik-Way loader. Many on here have suggested the Vredstein V-61. When reading the information on these they seem to suggest you need to install with inner tubes. Is it necessary to put tubes in these or are you ok going tubeless. Thanks 1 Share this post Link to post Share on other sites
ebinmaine 79,021 #2 Posted October 28, 2023 Can you link that info here? Why not use tubes? I now install tubes in every tire I swap, new or used. It makes setting the bead a non issue and fluid filling easier to accomplish. I don't see a negative to using tubes... BUT.... we don't have sharp thorns or things to cut tires other than occasional rocks. 2 1 Share this post Link to post Share on other sites
RJC1965 173 #3 Posted October 28, 2023 1 hour ago, ebinmaine said: Can you link that info here? Why not use tubes? I now install tubes in every tire I swap, new or used. It makes setting the bead a non issue and fluid filling easier to accomplish. I don't see a negative to using tubes... BUT.... we don't have sharp thorns or things to cut tires other than occasional rocks. 1 Share this post Link to post Share on other sites
RJC1965 173 #4 Posted October 28, 2023 I have a screen shot it recommends putting them in. I guess I will I tend to struggle putting them on. Maybe I will have these mounted professionally. I will likely fill them good point taken on tubes for filling. 2 Share this post Link to post Share on other sites
ebinmaine 79,021 #5 Posted October 28, 2023 50 minutes ago, RJC1965 said: it recommends putting them in. To my mind a "recommendation" is something one should do, but may do without. They used the word "required". That's a non negotiable term. I'd absolutely agree with getting the tires and tubes professionally mounted. Preferably by the same place that would fluid fill them. That way you KNOW the tubes are the proper ones for their machines. 6 Share this post Link to post Share on other sites
AHS 1,675 #6 Posted October 30, 2023 @ebinmaine i have AG’s filled with citrus, non tubed….i wish they were tubed!!! 3 Share this post Link to post Share on other sites
Tonytoro416 1,366 #7 Posted October 30, 2023 Do you then fill the tubes with fluid? I don’t have tubes in any of my loaded tires. I use Rimguard beet juice product which weighs at least a few pounds more per gallon than washer fluid etc. 3 Share this post Link to post Share on other sites
pfrederi 20,613 #8 Posted October 30, 2023 If you have Black locust or other thorny plants it is easier to plug a tubeless tire than to demount and patch/replace a tube... 3 Share this post Link to post Share on other sites
Pullstart 70,025 #9 Posted October 30, 2023 I mounted some ribbed tires for my loader project WITHOUT tubes and still fluid filled them. Why? For experimental purposes. Normally I load the tubes with fluid using some sort of pump or air over fluid. 2 Share this post Link to post Share on other sites
ebinmaine 79,021 #10 Posted October 30, 2023 27 minutes ago, Tonytoro416 said: Do you then fill the tubes with fluid? I don’t have tubes in any of my loaded tires. I use Rimguard beet juice product which weighs at least a few pounds more per gallon than washer fluid etc. On 10/28/2023 at 8:49 AM, ebinmaine said: I now install tubes in every tire I swap, new or used. IT MAKES SETTING THE BEAD A NON ISSUE and fluid filling easier to accomplish @Tonytoro416 I used tubes for the above reason and also because a tubed type it's easier FOR ME to fill with more fluid. Install the tire. Inflate to set the bead. Deflate the tube as much as possible preferably using a vacuum system. When you fluid fill the tire, the tube will be able to hold more fluid with the machinery that we use here. 17 minutes ago, pfrederi said: If you have Black locust or other thorny plants it is easier to plug a tubeless tire than to demount and patch/replace a tube... Definitely a thing that needs to be accounted for. 1 Share this post Link to post Share on other sites
Streetrodchev 1,124 #11 Posted October 30, 2023 I have two sets of the V61 tires in service, I mounted them without tubes several years ago. I now have tubes in two of the tires, intermittent leaks at the bead, I’m not sure if it was from dirt getting in there (from moldboard plowing), but it was the right side tire on each tractor that got a tube. 3 Share this post Link to post Share on other sites
WHX?? 56,662 #12 Posted October 30, 2023 If I am not mistaken all V-61s require tubes. My tire guy said tires with small ribs on the bead area require tubes. Usually tires are marked tubeless if you can run them without tubes. Great fronts for a loader BTW. 18.50 x 8s 2 Share this post Link to post Share on other sites
953 nut 66,317 #13 Posted October 30, 2023 One thing you should consider is that the tire manufacturer wants to have a happy customer. They know what works well with their tire and what won't. If you buy tubes be sure to avoid the cheap no-name brands because lots of people have been reporting new inner tubes coming apart at the seams when first inflated. 2 Share this post Link to post Share on other sites
ebinmaine 79,021 #14 Posted October 30, 2023 10 minutes ago, 953 nut said: reporting new inner tubes coming apart at the seams when first inflated. Agreed. We had one that was installed for a few months or a year and slowly losing air most of that time. Turns out the rubber circle that holds the valve stem in place was delaminated. 1 Share this post Link to post Share on other sites
C-85 792 #15 Posted October 30, 2023 The tubes I've recently been buying are usually made by Firestone (at least that's what's on the tube), and they're made in Vietnam. I haven't had any problems yet with these. C-85 3 Share this post Link to post Share on other sites
RJC1965 173 #16 Posted October 30, 2023 9 hours ago, 953 nut said: One thing you should consider is that the tire manufacturer wants to have a happy customer. They know what works well with their tire and what won't. If you buy tubes be sure to avoid the cheap no-name brands because lots of people have been reporting new inner tubes coming apart at the seams when first inflated. What is a good brand of tubes to buy I would rather pay more and not have future headaches. Thanks Share this post Link to post Share on other sites
RJC1965 173 #17 Posted October 30, 2023 10 hours ago, WHX?? said: If I am not mistaken all V-61s require tubes. My tire guy said tires with small ribs on the bead area require tubes. Usually tires are marked tubeless if you can run them without tubes. Great fronts for a loader BTW. 18.50 x 8s I am going to put tubes in and the 18.5 X 8. What size and brand on the rear. How are they in snow. Did you see any advantage to adding the front hubs I saw some on here do that and yours are still the hub type. My 520H is a 1996 so should have the 1 inch spindles. Thanks Share this post Link to post Share on other sites
953 nut 66,317 #18 Posted October 30, 2023 5 minutes ago, RJC1965 said: What is a good brand of tubes to buy I would rather pay more and not have future headaches. Thanks Like @C-85, Firestone has worked well for him. I have bought a couple at the local Good Year store that were very nice. I would not want to buy from an online outlet because if the tube fails you will have to have a replacement shipped to you and that puts you out of operation. Share this post Link to post Share on other sites
RJC1965 173 #19 Posted October 30, 2023 Thanks for all the information I am going to tube the fronts which will likely be the V-61. Still not sure for the rear tires what I will get.I was considering doing the trailer hub style fronts with studs just not sure for the money. I hear the V-61 are tough to mount would most suggest going to a tire shop and what shops mount the small tractor type tires. On my other 520H I mounted the Kenda Terra Trac I have a harbor freight tire changer but you can use it on the fronts and those were tough. Thanks Share this post Link to post Share on other sites
RJC1965 173 #20 Posted October 30, 2023 24 minutes ago, RJC1965 said: I am going to put tubes in and the 18.5 X 8. What size and brand on the rear. How are they in snow. Did you see any advantage to adding the front hubs I saw some on here do that and yours are still the hub type. My 520H is a 1996 so should have the 1 inch spindles. Thanks Are those tires the 18-8.5 X 8 I was looking at the Greater Cleveland Tire they said to use a 8X7 rim are those the same size you have and are yours on the stock rims. Thanks Share this post Link to post Share on other sites
WHX?? 56,662 #21 Posted October 31, 2023 (edited) 1 hour ago, RJC1965 said: I am going to put tubes in and the 18.5 X 8. What size and brand on the rear. How are they in snow. Rears are just Carlisle True Powers in 10.5-12. Loaded and weighted to beat the band. Inside Cub weights and outside whatever I had laying around. I lose traction alot with a heavy load but always on a uphill climb but I live on a sand hill. Got chinamen looking up at up at me the ruts she'll dig. Fronts are on stock rims & since they already tapered Timkens I see no reason to go to trailer hubs. Edit... To answer the snow? She doesn't see much snow action so really can't answer that. Couple of times I did have it out in snow very respectfully but it was just mostly pushing banks back with tires on clean asphalt. Edited October 31, 2023 by WHX?? Add Share this post Link to post Share on other sites
WHX?? 56,662 #22 Posted October 31, 2023 (edited) 1 hour ago, RJC1965 said: have a harbor freight tire changer but you can use it on the fronts and those were tough. Thanks HF mini changer works for me on all tires up to 6 ply. Struggle yes but works. Spoons are a great help. No problems on 4 ply or less. Only 6-12s but still. V-61s are not hard to mount at all with this tool. I don't take them to a tire shop as it takes days and they bend me over. Best advice is get thet tire in the sun or warm and use lube. Edited October 31, 2023 by WHX?? 1 Share this post Link to post Share on other sites
Wild Bill 633 936 #23 Posted October 31, 2023 (edited) Edited October 31, 2023 by Wild Bill 633 2 6 Share this post Link to post Share on other sites
ebinmaine 79,021 #24 Posted October 31, 2023 11 hours ago, RJC1965 said: How are they in snow 10 hours ago, WHX?? said: Edit... To answer the snow? She doesn't see much snow action so really can't answer that. Couple of times I did have it out in snow very respectfully but it was just mostly pushing banks back with tires on clean asphalt. @RJC1965 Do you have an asphalt driveway? If no asphalt, metal chains ⛓️ ⛓️ ⛓️ . If you do have a tarred area, get rubber chains. 1 Share this post Link to post Share on other sites
RJC1965 173 #25 Posted October 31, 2023 11 hours ago, ebinmaine said: @RJC1965 Do you have an asphalt driveway? If no asphalt, metal chains ⛓️ ⛓️ ⛓️ . If you do have a tarred area, get rubber chains. I have a concrete pad and majority is gravel. I have some V-Bar chains I could run those no need to go on the concrete part . 2 Share this post Link to post Share on other sites
